    MM and UBUNTU. Made for each other.
    28 Posts 12 Posters 21.6k Views 11 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @Mykle1
      @Mykle1
      I had version 18.xx installed, up and going just fine on my dev machine
      I am used to dealing with vulnerabilities, since I mainly work with Windows
      But, I just have my mindset to run npm audit fix --force & npm i lodash@4.17.5 -g & npm i acorn@^6.0.0 -g after every install of MM2. only takes a few minutes extra and it fixes all the vulnerabilities. Except for a few that come with some of the modules. With Ubuntu 18.xx, if I remember, I think just the npm audit fix --force was all I needed to do.
      “Life’s Too Short To Dance With Ugly People”
      Jim Hallock - 1995
        Mykle1 Project Sponsor Module Developer @justjim1220
        @justjim1220
        Yes, as I said, I too had ubuntu 18.xx and MM up and running. I just prefer NOT to deal with any vulnerabilities which 16.04 doesn’t have. I don’t know of any benefit to running 18.xx over 16.04 and, as I stated, I’m not a fan of the new UI in 18.xx. I ran MM over Windows when I first started. The disadvantages quickly became apparent. Hello-Lucy never would have happened if I didn’t leave Windows behind. I never looked back. :-)
          By popular demand
          Install ubuntu 16.04LTS (internet connection HIGHLY recommended)
          You MUST (check box) “Install 3rd Party Drivers” during installation
          Fully update the installation via the software manager after installation (It often needs to)
          Install node (includes npm) (I use node 8 )
          1. curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
          It will ask you if you want to install curl (gives you the command). Do so. Then run #1 again
          1. This will complete the installation of node and npm
          sudo apt-get install -y nodejs
          1. Check for success of node and npm installation in your terminal.
          run node -v (this will show your version)
          run npm -v (this will show your version)
          Now install MM
          Run git clone https://github.com/MichMich/MagicMirror.git in your terminal
          You may be asked to install git here. Do so. Use the command presented to you in the terminal
          Then run git clone https://github.com/MichMich/MagicMirror.git again
          Then cd MagicMirror and run npm install
          Then run your mirror npm start
          • Cliff365C Offline
            Cliff365
            I know this thread is quite old, hoping @Mykle1 or someone still looks at it.
            I followed the instructions and have a MM running on my Acer Revo. However, when I start MagicMirror, all I see is a blank screen. I have pm2 and electron installed, where do I find the logfile to try to track down the issue?
            S Cliff365C 2 Replies Last reply Reply Quote 0
              sdetweil @Cliff365
              @cliff365 is it before adding any modules? or after?
              if after see here
              if before do
              pm2 stop all
              pm2 flush
              pm2 start 0
              pm2 logs --lines=50
              • Cliff365C Offline
                Cliff365 @Cliff365
                Thanks @sdetweil , I entered the lines, but I had a bit of a problem getting MM to not restart while I tried to capture the logs. Hope this provides some insight:
                0|MagicMirror  | Starting server on port 8080 ...
                0|MagicMirror  | [17.12.2021 16:25.52.307] [LOG]
                0|MagicMirror  | Server started ...
                0|MagicMirror  | [17.12.2021 16:25.52.312] [LOG]
                0|MagicMirror  | Connecting socket for: updatenotification
                0|MagicMirror  | [17.12.2021 16:25.52.316] [LOG]   Sockets connected & modules started ...
                0|MagicMirror  | (electron:4583): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
                0|MagicMirror  | (electron:4583): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
                0|MagicMirror  | [4583:1217/162552.823896:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
                0|MagicMirror  | [4583:1217/162552.824839:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
                0|MagicMirror  | [17.12.2021 16:25.52.921] [LOG]
                0|MagicMirror  | Launching application.
                0|MagicMirror  | [4583:1217/162553.058857:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
                0|MagicMirror  | [4613:1217/162553.640227:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                0|MagicMirror  | [17.12.2021 16:26.01.616] [LOG]
                0|MagicMirror  | Shutting down server...
                0|MagicMirror  | [17.12.2021 16:26.01.618] [LOG]   Stopping module helper: updatenotification
                PM2            | App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2            | App [MagicMirror:0] starting in -fork mode-
                PM2            | App [MagicMirror:0] online
                0|MagicMirror  | > magicmirror@2.17.1 start /home/cliff/MagicMirror
                0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                0|MagicMirror  | [17.12.2021 16:26.06.425] [LOG]
                0|MagicMirror  | Starting MagicMirror: v2.17.1
                0|MagicMirror  | [17.12.2021 16:26.06.446] [LOG]
                0|MagicMirror  | Loading config ...
                0|MagicMirror  | [17.12.2021 16:26.06.466] [LOG]
                0|MagicMirror  | Loading module helpers ...
                0|MagicMirror  | [17.12.2021 16:26.06.487] [LOG]
                0|MagicMirror  | No helper found for module: alert.
                0|MagicMirror  | [17.12.2021 16:26.06.550] [LOG]
                0|MagicMirror  | Initializing new module helper ...
                0|MagicMirror  | [17.12.2021 16:26.06.555] [LOG]
                0|MagicMirror  | Module helper loaded: updatenotification
                0|MagicMirror  | [17.12.2021 16:26.06.559] [LOG]   No helper found for module: clock.
                0|MagicMirror  | [17.12.2021 16:26.06.563] [LOG]   All module helpers loaded.
                0|MagicMirror  | [17.12.2021 16:26.06.846] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.06.895] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.06.900] [LOG]   Connecting socket for: updatenotification
                0|MagicMirror  | [17.12.2021 16:26.06.905] [LOG]   Sockets connected & modules started ...
                0|MagicMirror  | (electron:4673): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
                0|MagicMirror  | (electron:4673): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
                0|MagicMirror  | [4673:1217/162607.415011:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
                0|MagicMirror  | [4673:1217/162607.415886:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
                0|MagicMirror  | [17.12.2021 16:26.07.530] [LOG]
                0|MagicMirror  | [4673:1217/162607.651240:ERROR:bus.cc(393)] Failed to connect to the bus: Failed to connect to socket /tmp/dbus-rSguYNpjNi: Connection refused
                0|MagicMirror  | [4705:1217/162608.260106:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                0|MagicMirror  | [17.12.2021 16:26.09.807] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.09.811] [LOG]   Stopping module helper: updatenotification
                ^A0|MagicMirror  | [17.12.2021 16:26.14.742] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.14.762] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.14.779] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.14.787] [LOG]   No helper found for module: alert.
                0|MagicMirror  | [17.12.2021 16:26.14.838] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.14.843] [LOG]
                0|MagicMirror  | [17.12.2021 16:26.14.848] [LOG]   No helper found for module: clock.
                0|MagicMirror  | [17.12.2021 16:26.14.851] [LOG]   All module helpers loaded.
                  sdetweil @Cliff365
                  @cliff365 this post seems to imply installing as root and running as user or vice versa.
                  https://forum.magicmirror.builders/topic/8464/back-screan-when-start-up-an-errors
                  delete the mm folder and use my script
                  do NOT use sudo , and use a normal user, not logon as root
                  Cliff365C 1 Reply Last reply Reply Quote 1
                  • Cliff365C Offline
                    Cliff365 @sdetweil
                    @sdetweil You are amazing! I wish I knew Linux as well I know Windows, but so it goes. Your suggestion worked! Thanks again!
