    First mirror built! DIY frame :P
    8 Posts 7 Posters 5.6k Views 6 Watching
      spooke
      alt text
      https://imgur.com/a/AzUgA7E
      Made my first Magic Mirror using an old Samsung LED 24" monitor, some 3mm Silver See-Thru Mirror Acrylic and of course a Raspberry Pi 3 Model B, finished with a DIY frame which didn’t turn out too badly…
      It’s pretty slimline at around 1.5" thick! Cant really wall mount it because of the monitor used but I’m happy to just rest it.
      The acrylic mirror is pretty decent but it is a bit distorted - I think that’s because it’s a bit of a tight fit in the frame and the frame isn’t 100% true.
      I’ve set it up more since so I’ll post a newer photo tomorrow which shows the current setup.
      Thanks!
      Mykle1M zdenekZ 2 Replies Last reply Reply Quote 2
        Mykle1 Project Sponsor Module Developer @spooke
        @spooke said in First mirror built! DIY frame :P:
        Sure you can. Give it some thought. :-)
        I like the natural grain of the wood, too. :-)
        • idoodlerI Offline
          idoodler Module Developer
          Looks nice! You could use a VESA mount, I am sure your monitor is VESA compatible.
            spooke @Mykle1
            @Mykle1 said in First mirror built! DIY frame :P:
            Thanks, I’ll figure something out, need some 90 degree connectors first though :P
            @idoodler said in First mirror built! DIY frame :P:
            Thank you, but it’s not VESA mount :(
            SexyTroggS 1 Reply Last reply Reply Quote 0
            • SexyTroggS Offline
              SexyTrogg @spooke
              @spooke I recently ran into a similar issue. I used a french cleat on the back of my frame. That stuck out just enough to make the frame and the monitor roughly stick out the same distance so the mirror was flat when I hung it.
              • bheplerB Offline
                bhepler Module Developer @idoodler
                @idoodler I found out the hard way that the VESA mounts are incorporated into the plastic cover to the monitor. If you remove the back then you lose the VESA mounts.
                • Snow ZhangS Offline
                  Snow Zhang
                  Woooow, that’s very cool!
                  So you put a battery on the back or does it have to stay on charge all the time?
                  • zdenekZ Offline
                    zdenek @spooke
                    @spooke sure u can. I’ve wooden frame as well. I bought this https://www.obchodprodilnu.cz/paska-montazni-pozinkovana-1071.html (sure u can buy it in hobby market for about 5 Euro or somthing like that), cut the piece as the width of your frame (u can use 2 pliers and bow few times) use 2 screws to mount to back side fo frame (use the whole in the metal plate), use 2 screws into the wall and “hang” it like a picture… it works - I can send my pic… Instead of wall-screws u can use hooks…
