    Weather forecast only displays 'invalid date'
    21 Posts 9 Posters 91.8k Views 8 Watching
    • C Offline
      Canterrain
      Update
      This issue is solved in v2.4.1.
      https://forum.magicmirror.builders/topic/7548/v2-4-0-update/2
      ===Begin original post===
      This started happening after updating my MM recently and adding the motion detection module (https://github.com/alexyak/motiondetector), but not sure if either are related.
      Every time the mirror starts up (even if I use pm2 to restart, or unplug and full reboot), my weather forecast just shows the words invalid date).
      This had been working for well over a year. The only change to config I made was to add the new module. But I ran the config checker and it says I have no syntax errors.
      I can see one other person opened this as an issue after updating, but they never provided logs or anything and thus it was closed.
      https://github.com/MichMich/MagicMirror/issues/1292
      I’ve generated logs starting at a pm2 restart, and I see no issues flagged:
      mm-0 Starting MagicMirror: v2.4.0-dev
      mm-0 Loading config ...
      mm-0 Loading module helpers ...
      mm-0 No helper found for module: alert.
      mm-0 Initializing new module helper ...
      mm-0 Module helper loaded: MMM-Motion-Detection
      mm-0 No helper found for module: clock.
      mm-0 No helper found for module: MMM-Nest.
      mm-0 Module helper loaded: calendar
      mm-0 No helper found for module: currentweather.
      mm-0 No helper found for module: weatherforecast.
      mm-0 Module helper loaded: newsfeed
      mm-0 All module helpers loaded.
      mm-0 Starting server on port 8080 ...
      mm-0 Server started ...
      mm-0 Connecting socket for: MMM-Motion-Detection
      mm-0 Starting module helper: MMM-Motion-Detection
      mm-0 Connecting socket for: calendar
      mm-0 Starting node helper for: calendar
      mm-0 Connecting socket for: newsfeed
      mm-0 Starting module: newsfeed
      mm-0 Sockets connected & modules started ...
      mm-0 Launching application.
      mm-0 Create new calendar fetcher for url: h
      mm-0 Create new news fetcher for url: http://feeds.arstechnica.com/arstechnica/index/ - Interval: 300000
      mm-0 Create new news fetcher for url: http://www.npr.org/rss/rss.php?id=1001 - Interval: 300000
      mm-0 [MMM-Motion-Detection] Motion Detection started...
      mm-0 [MMM-Motion-Detection] --------------------
      mm-0 [MMM-Motion-Detection] Webcam starting...
      mm-0 [MMM-Motion-Detection] motion detected
      The only editing I did was to take out the calendar URL from the posted log. Anyone else seen this or have any ideas?
      • justjim1220J Offline
        justjim1220 Module Developer
        might be easier to help if you could post your config.js. But please hide any personal info before posting it.
        Jim Hallock - 1995
        • C Offline
          Canterrain
          Sure, I can post that. The config checker doesn’t find any issues. Any help appreciated.
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'en',
          	timeFormat: 12,
          	units: 'imperial',
          			module: 'alert',
          			module: 'MMM-Motion-Detection',
          			module: 'clock',
          			position: 'top_left'
          			module: 'MMM-Nest',
          			position: 'bottom_right',
          				token:"xxx"
          			module: 'calendar',
          			header: 'Calendar',
          			position: 'top_left',
          						symbol: 'calendar-check-o ',
          						url: 'xxx'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: 'xxx',  //ID from http://www.openweathermap.org
          				appid: 'xxx'
          			module: 'weatherforecast',
          			header: 'Weather Forecast',
          	            appid: 'xxx'
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "ArsTechnica",
          						url: "http://feeds.arstechnica.com/arstechnica/index/",
          						title: "NPR",
          						url: "http://www.npr.org/rss/rss.php?id=1001"
          				showSourceTitle: true,
          				showPublishDate: true
          justjim1220J 1 Reply Last reply Reply Quote 0
            justjim1220 Module Developer @Canterrain
            @canterrain
            2 things to try…
            try putting a comma after the motion detection module
            module: ‘MMM-Motion-Detection’,
            Jim Hallock - 1995
            • C Offline
              Canterrain
              No luck adding the comma unfortunately.
              You mentioned 2 things to try, what was the second?
              Thanks for looking at this.
              • yawnsY Offline
                yawns Moderator
                appid in currentweather module is missing a ’
                Time and date on your raspberry are fine, right?
                  @canterrain
                  Not sure how I missed that… weird, I swear I put it in there…
                  Check the time and date of your devices…
                  Jim Hallock - 1995
                  • C Offline
                    Canterrain
                    Thanks for the helpful suggestions.
                    Date and time are correct on my pi, and the mirror even shows the right date and time.
                    The config did have the missing ’ in current weather, I apparently accidentally deleted it when I was removing personal info. I edited the above to reflect the current status of my config file.
                    This was working fine before. About the time I updated the mirror to latest version and added the motion detection module. But it didn’t happen immediately after those events. It was a few days later. I did find a logged issue (that was closed) describing the same thing, after updating the mirror.
                      Bob
                      I’m having the same issue as @Canterrain
                      Snipp from Clock and Weather modules are below
                       // Clock
                      			module: "clock",
                      			position: "top_center",
                      				displayType: "digital",
                      				displaySeconds: false,
                      				showPeriod: true,
                      				showPeriodUpper: false,
                      				clockBold: false,
                      				showDate: true,
                      				showWeek: false,
                      				dateFormat : "dddd, MMMM Do YYYY",
                      // Calendar// Weather - ID from http://www.openweathermap.org/help/city_list.txt
                      			module: "weatherforecast",
                      			header: "7 Day Forecast for ",
                      				fade: false,
                      				maxNumberOfDays: 7,
                      				showRainAmount: true,
                      				colored: true,
                      				locationID: "2655603",
                      				appid: "xxx"
                      Issue only occurred once I did an update to the MM system to v.2.4.0
                        Richard238
                        Same issue here
                        • K Offline
                          killing joke
                          same here.
                          Is there a possibilty to erase the comma and country code behind the location in the header?!
                            AgP42 Project Sponsor Module Developer
                            Hello,
                            same problem for me since the update in 2.4.0… So general update issue probably (looking forward for a solution !:slightly_smiling_face: )
                            To answer @killing-joke said in Weather forecast only displays ‘invalid date’:
                            same here.
                            I did change the following on the file “/MagicMirror/modules/default/weatherferecast/weatherforecast.js” :
                            // Override getHeader method.
                            getHeader: function() {
                            if (this.config.appendLocationNameToHeader) {
                            //line to change
                            //return this.data.header + " " + this.fetchedLocationName;
                            return "Prévisions Météo Nogent"; // write here what you want...
                            return this.data.header;
                            Here is the result :
                            20180702_220235_resized
                            You can of course change the line on the way you want to remove only the part you need.
                            • K Offline
                              killing joke @AgP42
                              @agp42 said in Weather forecast only displays ‘invalid date’:
                              Thanks a lot. I got it.
                              I found a solution on https://github.com/MichMich/MagicMirror/commit/0e2e8d2e2aca2f8d0f1f2eb7b213577fcc4f623a
                              But I had to change the lines 338 and 339 instead of 336 and 337
                              var day = moment(forecast.dt_txt, "YYYY-MM-DD hh:mm:ss").format("ddd");
                              var hour = moment(forecast.dt_txt, "YYYY-MM-DD hh:mm:ss").format("H");
                              into
                              var day;
                              var hour;
                              if(!!forecast.dt_txt) {
                              } else {
                              	day = moment(forecast.dt, "X").format("ddd");
                              	hour = moment(forecast.dt, "X").format("H");
                              It works for my MM.
                              • C Offline
                                Canterrain
                                Looks like the recent changes here are the culprit. They already figured out what needs to be changed, fixed in an upcoming update. Pull request is in. Get ready to update your mirrors.
                                  SoleLo @Bob
                                  @bob how did you get you icons to change color as well as your text?
                                    AgP42 Project Sponsor Module Developer @killing joke
                                    into
                                    var day;
                                    var hour;
                                    } else {
                                    It works for my MM.
                                    Works fine, thank you for the advice !
                                    • MichMichM Offline
                                      MichMich
                                      Ive just merged the fix by @jannekalliola into the develop branch which should solve this issue: https://github.com/MichMich/MagicMirror/pull/1341
                                      Can you guys please test this develop branch? If this solves the issue, I’ll release an intermediate 2.4.1 release.
                                      To tryout the develop branch, use the following git command on your terminal (from within the MagicMirror folder):
                                      git checkout develop
                                      git pull
                                      Thanks for testing!
                                        SoleLo
                                        I edited the code snippet and now my time is stuck on 8:01 on the current forecast…
                                          Richard238
                                          Stuck time might be the sunset time. Mine is 21:17, so not stuck al all.
                                            SoleLo @Richard238
                                            @richard238 hahaha you are right, I’m a imbecile.
