    Black screen after MM v2.4.0 update.
    32 Posts 17 Posters 25.4k Views 17 Watching
    • joela85J
      joela85
      Black screen after updates. Followed the commands below.
      sudo nano /boot/config.txt
      added this to the bottom and saved.
      dtoverlay=vc4-kms-v3d
      then…
      nano ~/.config/lxsession/LXDE-pi/autostart
      @xrandr --output HDMI-1 --rotate right
      Then the install…
      cd MagicMirror
      and
      sudo git pull && npm install
      successful install and rebooted to see a black screen.
      Have I missed anything?
      B 1 Reply Last reply
      • yawnsY
        yawns Moderator
        According to another similar thread please set this instead:
        dtoverlay=vc4-fkms-v3d (with an additional f )
        Reply Quote 1
        • joela85J
          joela85
          Thanks for the reply, I will try that when I get home.
          • C
            Charley Module Developer
            I also have a black screen.
            Tried both options
            and
            MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
            Reply Quote 2
            • M
              Mo
              I have a similar problem, after starting the MM the screen freezes, only way to unfreeze it is to close electron. Have tried both options too.
              After enabling either of the OpenGL drivers i get the followed errors:
              > magicmirror@2.4.0 start /home/pi/MagicMirror
              > sh run-start.sh
              libGL error: MESA-LOADER: failed to retrieve device information
              Starting MagicMirror: v2.4.0
              Loading config ...
              Loading module helpers ...
              No helper found for module: MMM-Cursor.
              Module helper loaded: MMM-Buttons
              Module helper loaded: MMM-DWD-WarnWeather
              Module helper loaded: MMM-DHT-Sensor
              No helper found for module: helloworld.
              Module helper loaded: MMM-Remote-Control
              Module helper loaded: MMM-MyWeather
              No helper found for module: MMM-SimpleLogo.
              Module helper loaded: MMM-PiLights
              All module helpers loaded.
              Server started ...
              Connecting socket for: MMM-Buttons
              Starting node helper for: MMM-Buttons
              Connecting socket for: MMM-DWD-WarnWeather
              MMM-DWD-WarnWeather helper started...
              Connecting socket for: MMM-DHT-Sensor
              MMM-DHT-Sensor helper started ...
              Connecting socket for: MMM-Remote-Control
              Starting node helper for: MMM-Remote-Control
              Connecting socket for: MMM-MyWeather
              MMM-WunderGround helper started ...
              Connecting socket for: MMM-PiLights
              [2018-07-03 15:42:24] [MMM-PiLights] Starting node_helper
              Launching application.
              (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined
              (node:1057) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
              (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined
              (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined
              (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined
              (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined
              (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property 'refs' of undefined
              (node:1057) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property 'refs' of undefined
              Edit: MM works without any OpenGL Drivers, but CPU usage is pretty high and the Node errors are still there.
                A Former User
                After 2.4.0, Asus Tinker Board cannot display MM. I think it might be related with this openGL issues. Is there any way to solve this?
                ATB has no openGL desktop driver like vc4-kms-v3d. Fake vc4-kms-v3d does not help.
                • joela85J
                  joela85
                  I can’t access my mirror remotely anymore. Will I need to format my sd card and try again?
                  bheplerB 1 Reply Last reply
                  • K
                    Kastore
                    I am having the same issues and tried alot right now.
                    Tried the
                    dtoverlay=vc4-fkms-v3d as well as dtoverlay=vc4-kms-v3d as well as deleting that phrase
                    I downgraded electron to npm install electron@1.4.15 since i found that helped in the V2.30 problems.
                    I cant currently show the log from starting MagicMirror since i remotly access it and the MM just goes “all black” over the remote-access-page and I cant close it.
                    I really just want to downgrad the MM to 2.3 since it worked absolutly fine with it…
                    Additional software I use is MM-PIR
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @Kastore
                      @kastore
                      https://github.com/MichMich/MagicMirror/releases
                      K 1 Reply Last reply
                      • K
                        Kastore @Mykle1
                        @mykle1
                        Thanks Mykle1
                        Just how do i tell my pi to get the specific version? I am not versed in programming or coding or anything and couldnt find something online that told me how to install a specific version
                        • KimzerK
                          Kimzer
                          Did anyone find a fix here? just updated and same thing here. Hopefully i can get this back working tomorrow.
                          Reply Quote 1
                          • Mykle1M
                            @kastore
                            One way is to go to that link I gave you and download the version you want and install it manually.
                            • pyrosmileyP
                              pyrosmiley
                              Bumping this because I’m also having issues. A lot of time on google says it’s not just a MagicMirror issue, but lots of people have problems with the OpenGL drivers. My screen is blanking after some time no matter what, but I also found the hard way that it messes with tvservice (like the Remote Control module uses) – turning my HDMI off straight up insta-shut down my pi! Gonna have to keep researching for sure.
                              • joela85J
                                joela85
                                I just updated and this is shown at the end of the install.
                                MagicMirror installation successful!
                                > magicmirror@2.4.1 install-fonts /home/pi/MagicMirror
                                > cd fonts && npm install
                                npm WARN postcss-html@0.12.0 requires a peer of postcss-less@>=1.1.0 but none was installed.
                                npm WARN postcss-html@0.12.0 requires a peer of postcss-scss@>=1.0.0 but none was installed.
                                npm WARN postcss-html@0.12.0 requires a peer of sugarss@>=1.0.0 but none was installed.
                                npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                                pi@raspberrypi:~/MagicMirror $
                                I applied
                                to the config.txt ( also tried with fkms)
                                Reboot and I get a black screen.
                                When I remove dtoverlay=vc4-kms-v3d then the mirror boots up.
                                Any suggestions?
                                • K
                                  Kastore @Mykle1
                                  @mykle1
                                  Just found your guide: https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
                                  Going at it now and see if it works - thanks for the patience and writing that guide!
                                  Reply Quote 1
                                  • Mykle1M
                                    @kastore said in Black screen after MM v2.4.0 update.:
                                    You’re welcome, sir. :-)
                                    • KimzerK
                                      Kimzer
                                      Got my mirror working again. Had to go over the opengl drivers again and using the fake kms driver did the trick. However one problem remains, i had to also disable the MMM-Pir-Sensor module because that was messing with the system. But also my custom.css is not being used atm, and i cant figure out why its not grabbing it.
                                      • KimzerK
                                        Kimzer
                                        Anyone else struggling with using MMM-Pir-Sensor after the new update?
                                        T 1 Reply Last reply
                                        • T
                                          thenameiwantedwastaken @Kimzer
                                          Yes, I am having the same black screen. I have to disable PIR to be able to use MM at all. I also noted that after I installed PIR I could no longer SSH into the Pi from my desktop computer, whereas I could from my mobile phone. Anyway, the black screen is the main concern right now. I’ll post if I discover anything helpful.
                                          • G
                                            grantc66
                                            Not sure if I’m having the same issue, stupidly updated electron as npm was claiming 1.7.13 had a critical vulnerability (after installing MMM-voice) Then got the backscreen issue. rolled back electron to 1.7.13 & the issue persists.
                                            Node v9.11.1
                                            npm 6.1.0
                                            Thought I’d uploaded the log file but not sure if others can see it. That snippet below is the first error after ALL_MODULES_STARTED
                                            13:01:19.440 main.js:40 Uncaught TypeError: Cannot read property ‘appendChild’ of undefined
                                            at main.js:40
                                            at Array.forEach ()
                                            at createDomObjects (main.js:24)
                                            at Object.modulesStarted (main.js:471)
                                            at startModules (loader.js:59)
                                            at loader.js:40
                                            at HTMLLinkElement.stylesheet.onload (loader.js:203)
                                            (anonymous) @ main.js:40
                                            createDomObjects @ main.js:24
                                            modulesStarted @ main.js:471
                                            startModules @ loader.js:59
                                            (anonymous) @ loader.js:40
                                            stylesheet.onload @ loader.js:203
                                            13:01:20.056 TypeError: Cannot read property ‘getElementsByClassName’ of null
                                            at moduleNeedsUpdate (main.js:176)
                                            at main.js:144
                                            at Promise ()
                                            at updateDomWithContent (main.js:137)
                                            at main.js:119
                                            at
                                            Promise rejected (async)
                                            (anonymous) @ main.js:121
                                            Promise resolved (async)
                                            (anonymous) @ main.js:118
                                            updateDom @ main.js:109
                                            updateDom @ main.js:514
                                            updateDom @ module.js:358
                                            Any pointers as to how to get it working again? It was working perfectly before MMM-voice & buggering around with electron.
                                            Tried a fresh install with the same result :(
