    MMM-voice
    voice control
    329 Posts 55 Posters 999.0k Views 50 Watching
      Baltibu @strawberry 3.141
      This post is deleted!
      • G Offline
        gismo2006
        @strawberry-3-141
        I have tested your post an I will say Thnks!!! It has install correctly… Now i will test the module.
        But I have a little question, too. On Github I see some translation files for Englich and German. But how can I use your module in German? Have I antything to chance in module code?
        greets gismo
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @gismo2006
          @gismo2006 it’s not supported to recognize other language commands than english, just the messages are translated
          • G Offline
            gismo2006
            @strawberry-3-141
            Ok, no problem…
            I have tested this module now for a several time. And I do not know what is wrong but I decieded to didn’t use it at the moment.
            The install progress was fine, the config file was fine and the mirrror started. everything is displayed fine. But the behaviuor is the problem. Sometimes it didn’t regonize anything. Sometimes it will do at first nothing and then some minuts later suddenly the module, for example “hide modules”. Oh and in the error log was only 11111 written
            Greets gismo
              @gismo2006 here are some tips to improve the experience:
              • it’s necessary to have a proper power supply, in order to decrease the response time, otherwise the cpu will be underclocked and this is contra productive for an cpu intensive task (for rpi 3 it’s recommended to use at least 2.5A for normal usage, I’m using 3A)
              • look into the MMM-voice.dic file how you need to spell the words correctly, the language model is based for native speakers and dialects can lead to false positives.
              • a cheap microphone can lead to false positive as well, by sending an unclean audio stream.
              • speaking louder gave me better results.
              • pocketsphinx also tries to match background noise to words, so short words like on, off, one, etc. are getting recognized without saying anything
              • so those false positives get spread within your commands and will lead to unwanted actions e.g. you say MAGIC MIRROR VOICE to enter the voice mode it propably recognizes MAGIC ON MIRROR VOICE and then the mirror wont start because the keyword must be recognized together without any other word between or it recognizes MAGIC MIRROR OF VOICE and then it will not switch to mode voice because the mode has to be right after the keyword or sentence
              • the error log gets created from pocketsphinx, so those numbers are not from my side
              • in order to test what the mirror detects, you can use the config option debug: true but don’t use this in production it will generate a huge logfile over time
              • G Offline
                gismo2006
                @strawberry-3-141 Thank you for your tipps. I didn’t mean anything angy. I know it is a hard work to code something like that. And I really happy and thankfull that there a coder like you which share it whit the community. And helping if there are any questions. :-)
                I will test aggain at he few next day, and im sure there are somme new questions.
                Greets gismo
                  strawberry 3.141 Project Sponsor Module Developer @Nonamexp
                  @Nonamexp said in MMM-voice:
                  I’ve the next problem: On the Mirror shows the message ‘Error’ , ‘No Moduls identified’.
                  in the Error Log: Error: spawn pocketsphinx_continuous ENOENT-2
                  help me pls ;(
                  his problem was that somehow his ~/.bashrc file got overwritten and then he missed the path to pocketsphinx files
                  • ? Offline
                    A Former User
                    Hmm… getting errors when trying to install the dependencies … can you advise is this known?
                      strawberry 3.141 Project Sponsor Module Developer @Guest
                      @wjdw87 Looks like you’er using a Mac. Not sure about Mac has a Package Manager as apt-get, the installer was Designed for raspbian
                      • ? Offline
                        A Former User
                        ah… yes using mac… (will move over to windows based later, but just getting all the customisation out of the way on here and learning how it all works before doing additional functions etc)… anyway… i take it there is no ‘easy/guided way to install on here?’
                        Thanks @strawberry-3-141
                          @wjdw87 you can read your way through the installer and install the dependencies manually, only the first step is based on apt-get, maybe the rest is working on a Mac as well, then you can comment out step one and rerun the installer
                          • P Offline
                            plumcraft
                            Hello,
                            I’m trying the MMM-voice but no luck for now.
                            I got “Error” on the Magic mirror and i have the following error in the debug.log :
                            INFO: continuous.c(295): Specify ‘-infile <file.wav>’ to recognize from file or ‘-inmic yes’ to recognize from microphone.
                            ERROR: “cmd_ln.c”, line 641: Duplicate argument name in arguments: -adcdev
                            ERROR: “cmd_ln.c”, line 704: Failed to parse arguments list
                            And got “12712712712712712712712711111111111111111111” in error.log
                            I already tried couple of things :
                            • reinstall the module by deleting the node_modules folder and rerun the dependencies.sh script.
                            • upgrade everything with apt-get upgrade
                            • Configure the usb microphone by creating .asound.rc file
                            I’m using a standart usb microphone (http://www.banggood.com/fr/USB-Microphone-For-Raspberry-Pi-p-993726.html)
                            I’ve found couple of differents versions how to setup an usb microphone on a RPI3 but no luck either to have a clear sound when i’m recording wav file to test it with following command :
                            • arecord -D plughw:1,0 test_mic.wav
                            Is there a excellent microphone for RPI3 ?
                            Really looking forward to use this module.
                            Thanks for your help
                            • P Offline
                              plumcraft
                              With @strawberry-3-141 help, thanks again by the way, it’s working now :)
                              If you got the same issue, here the solution :
                              • delete the node_modules folder and then rerun the installer.
                              • remove the words.json file on root module folder and restart the magic mirror.
                                (It’s going to be regenerated when the module starts)
                              That should be it.
                              • W Offline
                                witschi87
                                Hey guys,
                                i’ve installed the plugin but getting this error:
                                pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                                Any suggestions?
                                • bheplerB Offline
                                  bhepler Module Developer @witschi87
                                  @witschi87 Did you follow the installation instructions in the module’s readme.md file? Because it sure looks like you do not have PocketSphinx installed.
                                  • iMAGiCI Offline
                                    iMAGiC
                                    finally got it work… due to command behavior, all set, but don’t know how it works.
                                    @strawberry-3-141 is it possible that you could spend time to build a simple music player for MMM-voice module?
                                    all I need is random play mp3 in a folder, no need to select, just play and stop is OK via voice command.
                                    thanks in advance.
                                    Choice * Judgment * Values
                                      strawberry 3.141 Project Sponsor Module Developer @iMAGiC
                                      We could get Around the issue of @witschi87 but we dont know yet what the problem actually is. When he starts his mirror with DISPLAY=:0 nohup npm start & it works, with pm2 start mm not, but i have seen a couple using it with pm2 already
                                      @iMAGiC sry I my Time is pretty Limited due to my Bachelor thesis, but i will have a look if i can adjust the Existent Music player to Voice commands easily
                                      • G Offline
                                        gismo2006
                                        Some time ago @tyho help me a lot to to use voice commands in the module “Simple music Player” So I can use Start Stop Forward and back. I know in my case snoword hotword Detection was use but maybe it can help. If it was ok for @tyho I can post the code.
                                        Maybe it will be an option for the first time, till @strawberry-3-141 have more time. :-)
                                        Greets gismo
                                          DirkS
                                          Hi, in my case it does not stop blinking and only shows “initialisiere…”
                                          I tried
                                                   microphone: 1,
                                          and
                                                   microphone: '1',
                                          but no effect.
                                          iMAGiCI 1 Reply Last reply Reply Quote 0
                                          • iMAGiCI Offline
                                            iMAGiC @DirkS
                                            @DirkS please say " magic mirror" at the first. when it flashing say “voice”, when it changes to Voice mode, you can say command.
                                            • 16
                                            • 17
                                            • 3 / 17
