    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      A Former User
      Hmm… getting errors when trying to install the dependencies … can you advise is this known?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Guest
        @wjdw87 Looks like you’er using a Mac. Not sure about Mac has a Package Manager as apt-get, the installer was Designed for raspbian
          A Former User
          ah… yes using mac… (will move over to windows based later, but just getting all the customisation out of the way on here and learning how it all works before doing additional functions etc)… anyway… i take it there is no ‘easy/guided way to install on here?’
          Thanks @strawberry-3-141
            @wjdw87 you can read your way through the installer and install the dependencies manually, only the first step is based on apt-get, maybe the rest is working on a Mac as well, then you can comment out step one and rerun the installer
              plumcraft
              I’m trying the MMM-voice but no luck for now.
              I got “Error” on the Magic mirror and i have the following error in the debug.log :
              INFO: continuous.c(295): Specify ‘-infile <file.wav>’ to recognize from file or ‘-inmic yes’ to recognize from microphone.
              ERROR: “cmd_ln.c”, line 641: Duplicate argument name in arguments: -adcdev
              ERROR: “cmd_ln.c”, line 704: Failed to parse arguments list
              And got “12712712712712712712712711111111111111111111” in error.log
              I already tried couple of things :
              • reinstall the module by deleting the node_modules folder and rerun the dependencies.sh script.
              • upgrade everything with apt-get upgrade
              • Configure the usb microphone by creating .asound.rc file
              I’m using a standart usb microphone (http://www.banggood.com/fr/USB-Microphone-For-Raspberry-Pi-p-993726.html)
              I’ve found couple of differents versions how to setup an usb microphone on a RPI3 but no luck either to have a clear sound when i’m recording wav file to test it with following command :
              • arecord -D plughw:1,0 test_mic.wav
              Is there a excellent microphone for RPI3 ?
              Really looking forward to use this module.
              Thanks for your help
                plumcraft
                With @strawberry-3-141 help, thanks again by the way, it’s working now :)
                If you got the same issue, here the solution :
                • delete the node_modules folder and then rerun the installer.
                • remove the words.json file on root module folder and restart the magic mirror.
                  (It’s going to be regenerated when the module starts)
                That should be it.
                • W Offline
                  witschi87
                  Hey guys,
                  i’ve installed the plugin but getting this error:
                  pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                  Any suggestions?
                    bhepler Module Developer @witschi87
                    @witschi87 Did you follow the installation instructions in the module’s readme.md file? Because it sure looks like you do not have PocketSphinx installed.
                    • iMAGiCI Offline
                      iMAGiC
                      finally got it work… due to command behavior, all set, but don’t know how it works.
                      @strawberry-3-141 is it possible that you could spend time to build a simple music player for MMM-voice module?
                      all I need is random play mp3 in a folder, no need to select, just play and stop is OK via voice command.
                      thanks in advance.
                      Choice * Judgment * Values
                        strawberry 3.141 Project Sponsor Module Developer @iMAGiC
                        We could get Around the issue of @witschi87 but we dont know yet what the problem actually is. When he starts his mirror with DISPLAY=:0 nohup npm start & it works, with pm2 start mm not, but i have seen a couple using it with pm2 already
                        @iMAGiC sry I my Time is pretty Limited due to my Bachelor thesis, but i will have a look if i can adjust the Existent Music player to Voice commands easily
                        • G Offline
                          gismo2006
                          Some time ago @tyho help me a lot to to use voice commands in the module “Simple music Player” So I can use Start Stop Forward and back. I know in my case snoword hotword Detection was use but maybe it can help. If it was ok for @tyho I can post the code.
                          Maybe it will be an option for the first time, till @strawberry-3-141 have more time. :-)
                          Greets gismo
                            DirkS
                            Hi, in my case it does not stop blinking and only shows “initialisiere…”
                            I tried
                                     microphone: 1,
                            and
                                     microphone: '1',
                            but no effect.
                            iMAGiCI 1 Reply Last reply Reply Quote 0
                            • iMAGiCI Offline
                              iMAGiC @DirkS
                              @DirkS please say " magic mirror" at the first. when it flashing say “voice”, when it changes to Voice mode, you can say command.
                                DirkS @iMAGiC
                                @iMAGiC i tried that many times. But i changed the word to Jarvis.
                                Now the status is just ERROR :(
                                  strawberry 3.141 Project Sponsor Module Developer @DirkS
                                  @DirkS hey dirk, try to add debug: true in the config section, this will create a more detailed log. we also can get in touch via pm, then i can help you more and quicker via teamviewer
                                    A Former User
                                    Been busy the last two weeks, so not had chance to look at MM in a while, still having issues installing the dependencies, truth be told, not my area of expertise, playing with terminal .
                                    Thus installing them is where i am coming unstuck.
                                    Mentioned previously failing at Level 1
                                    "Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes.
                                    Would highly appreciate if anyone can pipe up the actual commands for installation on Mac (Terminal) for these commands…
                                    e[0m
                                    \e[96m[STEP 1/6] Installing Packages\e[90m
                                    sudo: apt-get: command not found
                                    \e[31m[STEP 1/6] Installing Packages | Failed\e[0m
                                    NA-3:installers #####$ sudo chmod 777 /Users/billijaywest/MagicMirror/modules/MMM-voice/installers
                                    NA-3:installers ####$ bash dependencies.sh
                                    \e[0m
                                    As i have managed to manually install only Install, but the rest (and always fails at n1) i am stuck on lack of knowledge of the installation.
                                      Porkiddo
                                      Any luck with the ERROR message near the microphone? I have the same and no idea what to do next.
                                        @wjdw87 - Looking at the dependencies.sh file, the line it’s failing on is if sudo apt-get install bison libasound2-dev autoconf automake libtool python-dev swig python-pip -y ;
                                        If “command not found” is your error message, it looks like apt-get is not installed on your Mac.
                                          Porkiddo @Porkiddo
                                          @Porkiddo said in MMM-voice:
                                          Done, I just restart npm and the error is gone
                                            DirkS
                                            thanks to @strawberry-3-141 the module works now very good! Hopefully the other module developer will add the voice function!
                                            • 16
                                            • 17
                                            • 3 / 17
