    MMM-voice
    voice control
    329 Posts 55 Posters 1.0m Views 50 Watching
    • G Offline
      gismo2006
      Some time ago @tyho help me a lot to to use voice commands in the module “Simple music Player” So I can use Start Stop Forward and back. I know in my case snoword hotword Detection was use but maybe it can help. If it was ok for @tyho I can post the code.
      Maybe it will be an option for the first time, till @strawberry-3-141 have more time. :-)
      Greets gismo
        DirkS
        Hi, in my case it does not stop blinking and only shows “initialisiere…”
        I tried
                 microphone: 1,
        and
                 microphone: '1',
        but no effect.
        iMAGiCI 1 Reply Last reply Reply Quote 0
        • iMAGiCI Offline
          iMAGiC @DirkS
          @DirkS please say " magic mirror" at the first. when it flashing say “voice”, when it changes to Voice mode, you can say command.
          Choice * Judgment * Values
            DirkS @iMAGiC
            @iMAGiC i tried that many times. But i changed the word to Jarvis.
            Now the status is just ERROR :(
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @DirkS
              @DirkS hey dirk, try to add debug: true in the config section, this will create a more detailed log. we also can get in touch via pm, then i can help you more and quicker via teamviewer
                A Former User
                Been busy the last two weeks, so not had chance to look at MM in a while, still having issues installing the dependencies, truth be told, not my area of expertise, playing with terminal .
                Thus installing them is where i am coming unstuck.
                Mentioned previously failing at Level 1
                "Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes.
                Would highly appreciate if anyone can pipe up the actual commands for installation on Mac (Terminal) for these commands…
                e[0m
                \e[96m[STEP 1/6] Installing Packages\e[90m
                sudo: apt-get: command not found
                \e[31m[STEP 1/6] Installing Packages | Failed\e[0m
                NA-3:installers #####$ sudo chmod 777 /Users/billijaywest/MagicMirror/modules/MMM-voice/installers
                NA-3:installers ####$ bash dependencies.sh
                \e[0m
                As i have managed to manually install only Install, but the rest (and always fails at n1) i am stuck on lack of knowledge of the installation.
                  Porkiddo
                  Any luck with the ERROR message near the microphone? I have the same and no idea what to do next.
                    bhepler Module Developer
                    @wjdw87 - Looking at the dependencies.sh file, the line it’s failing on is if sudo apt-get install bison libasound2-dev autoconf automake libtool python-dev swig python-pip -y ;
                    If “command not found” is your error message, it looks like apt-get is not installed on your Mac.
                      Porkiddo @Porkiddo
                      @Porkiddo said in MMM-voice:
                      Done, I just restart npm and the error is gone
                        DirkS
                        thanks to @strawberry-3-141 the module works now very good! Hopefully the other module developer will add the voice function!
                          MagicMirrorPi
                          I had a problem with this module too. My first problem was to solve the issue with the usb soundcard. Then i insert the debug line in the config and get some more informations. Now, i say magic mirror and the microphone is blinking and i can say some keywords like HIDE ALL MODULES, and i can see, the module understand me correctly, but do nothing… Anybody know why?
                          • E Offline
                            ealfaror
                            The module works very good! I’m Spanish and I have had to modify some words to improve the results.
                            But, I’ve a question:
                            I want use only the VOICE module. It’s possible to predefine that module when MagicMirror starts?
                            Thanks!
                              strawberry 3.141 Project Sponsor Module Developer @ealfaror
                              @ealfaror Currently it’s not supported. If you want to change it https://github.com/fewieden/MMM-voice/blob/f9eb4cd4bde5c64ef894e8625250c4092aa0d4a7/node_helper.js#L18 this is were you need to change it mode: "VOICE". But keep in mind that manual changes can make trouble by a module update
                              • E Offline
                                ealfaror @strawberry 3.141
                                @strawberry-3.141 Thanks! I’ve changed it and it works!
                                I hope I’ll remember it when the module updates. :)
                                  Allred
                                  I am not sure what I am missing/doing wrong. I have gotten everything installed and working after several attempts. I enabled debugging so I could see what it was capturing. Magic mirror activated microphone just fine. I could see the text below it that it was recognising, but if I said hide, or hide modules. It won’t hide any modules.
                                    strawberry 3.141 Project Sponsor Module Developer @Allred
                                    @Allred sounds like you didn’t enter the voice mode first
                                    MAGIC MIRROR VOICE HIDE MODULES will activate the microphone, switch to voice mode and performs the task hide modules.
                                    For every following command in the voice mode you have to say
                                    MAGIC MIRROR SHOW MODULES or when the microphone is already active just SHOW MODULES until you switch into another mode, then you would have to say voice again
                                    Mykle1M 1 Reply Last reply Reply Quote -1
                                      Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                      @strawberry-3.141
                                      What do I need?
                                      Do I need a specific microphone?
                                      If I get a webcam with a built in microphone, will that work?
                                      If the webcam microphone will work, which webcam do you recommend?
                                      I just want to have everything I need before I try anything, thanks.
                                        strawberry 3.141 Project Sponsor Module Developer @Mykle1
                                        @Mykle1 i’m just using a usb microphone, never tried a buil in mic of a webcam because i don’t have one
                                          @strawberry-3.141 said in MMM-voice:
                                          i’m just using a usb microphone, never tried a buil in mic of a webcam because i don’t have one.
                                          I actually got it working on a laptop with Ubuntu so I am now trying it on the Pi 3 with MMM-voice and a Logitech USB microphone. It loads with “Initializing” next to the microphone and for a second it shows “Ready, choose a mode.” but then it changes to Error. I tried to make it the default in Audio Device Settings on the Pi3 but it keeps going back to "bcm2835 (ALSA mixer) (Default). It won’t keep the “AK5370 (Alsa mixer)” as default.
                                           0 [ALSA           ]: bcm2835 - bcm2835 ALSA
        bcm2835 ALSA
                                           1 [AK5370         ]: USB-Audio - AK5370
        AKM AK5370 at usb-3f980000.usb-1.2, full speed
                                          I’m going to bed!
                                            @Mykle1 just set the config to microphone: 1
                                            • 16
                                            • 17
                                            • 4 / 17
