    Monitor size recommendations
    how tomonitor
    13 Posts 6 Posters 10.0k Views 5 Watching
      dcarls91
      Begining my mirror build here soon, and was wondering what size monitor you all recommend for the build. Thanks
      cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer @dcarls91
        @dcarls91 Whatever your comfortable with. It can also depend on what you want to do with it. I have a 24" and a 32" …
          Mykle1 Project Sponsor Module Developer @dcarls91
          @dcarls91
          I agree with @cowboysdude. Whatever fits for the circumstance. I also have made a few, from the very small up to 24". They each suit their condition and purpose. Alarm clocks, Vanity mirrors, conventional, etc
          • ? Offline
            [[global:former-user]]
            Anyway, I think higher resolution(1920*1080) would be better for some modules. Sometimes I feel lower resolution is a bit small.
              j.e.f.f Project Sponsor Module Developer @Guest
              @sean said in Monitor size recommendations:
              I second this. You’ll find that most of the modules won’t scale well to 720p. Can all be corrected of you have a good handle on CSS, but if you just start with a 1080p display, you’ll save yourself time and headache.
                dcarls91
                Would a tv work? Thinking of using a tv so the speakers are already built in so that i can add alexa.
                J cowboysdudeC 2 Replies Last reply Reply Quote 1
                  j.e.f.f Project Sponsor Module Developer @dcarls91
                  @dcarls91 Yep TV will work fine. I built two out of TVs.
                    @dcarls91 I’m using a Vizio 32" HD tv and it is awesome! OF course I’m also using a ITX motherboard and not a pi ;)
                      bhepler Module Developer
                      I just started work on my 4th mirror and this one is 27" diagonal. I did one mirror that was 83" x 14" so it’s pretty much “whatever works for the space”.
                      Caution - Wide Load
                        j.e.f.f Project Sponsor Module Developer @cowboysdude
                        @cowboysdude said in Monitor size recommendations:
                        @dcarls91 Raspberry Pi will work fine with a TV as well. ITX board comes in handy for other processing tasks, but the Pi has no problems outputting 1080p over HDMI.
                          dcarls91
                          Awesome, thanks for all of your input. Ended up with a 22" monitor to start with.
                            @dcarls91 said in Monitor size recommendations:
                            Have fun! My first MM was a 22".
                            https://forum.magicmirror.builders/topic/1678/1-old-noob-1-rpi-i-can-t-believe-i-did-it-revisited
                              cowboysdude Module Developer @j.e.f.f
                              @j-e-f-f That is true…In my case I need more than the pi could handle.
