    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 891.9k Views 74 Watching
      dan-o
      @j-e-f-f came home to see the icon working, which was strange. anyway, grabbed your recent update and it works great. thank you SO MUCH for your time on this :)
        dan-o @dan-o
        @dan-o said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
        Looks like I spoke too soon :(. Was working after a restart. Walked by the mirror just now and no icon present.
        J 2 Replies Last reply Reply Quote 0
          j.e.f.f Project Sponsor Module Developer @Smotx
          @smotx you can control the width of the module in CSS. It defaults to 300px, but if you need it wider or narrower you can use this:
          .MMM-DarkSkyForecast .module-content {
            width: 250px; /* adjust this to taste */
            j.e.f.f Project Sponsor Module Developer @dan-o
            @dan-o hmmm… will look into this some more. For now, if you disable the animated icons you will at least get the static one reliably.
              I left this running on my mirror overnight and my main icon disappeared at some point as well, but it was back this morning. I have a few theories as to why.
              The way the animated icons work is that they get drawn real-time by JavaScript, which means I need to wait until the DOM update is finished before executing the draw command. I thought I had licked that with my last update but the combination of the Nunjucks templating system seems to be adding a latency I’m not accounting for.
              Will continue working on this over the next couple of days. Turn off animated icons for now as a work around.
                Arjan Project Sponsor
                Is it possible to disable the main icon via the config?
                I’m running two configs of MMM-DarkSlyForecast next to each other. One with 9 hour forecast and the other one with 6 day forecast.
                Because of this I have 2 main icons that are the same. See picture below.
                Is it possible to disable one of them via the config?
                  j.e.f.f Project Sponsor Module Developer @Arjan
                  @arjan yes. Here are a few config options for you:
                  showCurrentConditions: false will turn off the main icon and the current temparature display (the two big items).
                  showExtraCurrentConditions: false will turn off the the additional current conditions immediately below the big icon and temperature.
                  This module is programmed it with this type of usage in mind, so it supports multiple instances to work independently. I do something similar on my kitchen display centre.
                    Arjan Project Sponsor @j.e.f.f
                    @j-e-f-f Thanks. I overlooked that one.
                      @dan-o @Smotx I think I’ve licked the disappearing icon issue for good now. I tested a fix on my mirror for 24 hours, and the icon was visible every time I checked up on it. Please do a git pull in the MMM-DarkSkyForecast directory and restart MM. Let me know if it’s fixed.
                        dan-o
                        @j-e-f-f Pulled just now. Will let you know if I run into the issue again!
                        Appreciate ya!
                          Johans @j.e.f.f
                          @j-e-f-f installed latest version of your nicely build weather forecast module, but now I see that my personal web player is not working anymore.
                          All content is displayed on the mirror, but there is no reaction when I press a play button (seems play buttons are disabled)
                          To show the player on my mirror I’ve abused the widget module.
                          It shows me 6 radio stations and a selection button for MP3’s on the SD card of the raspberry. (All simple stuff – so far no rocket science)
                          I’m sure problem is related towards the installation of your weather module, as I did a rebuild on another SD card to try -out.
                          Removing and re-installing your module or the widget module was no solution so far.
                          Started mirror in dev mode, but here also I don’t see any problem.
                          As I read here that you updated this module to use the Nunjucks html templating system, I suspect it has a relation with my html code I’m using in the widget module.
                          See below code in the config. Perhaps somebody can port this code according the Nunjucks html. (sound lick chinees for me  )
                             		disabled: false,
                             		module: "MMM-Widget",
                                	        position: "middle_center",
                              		pages: {"Page1": "lower_third"},
                             		widgets: [
                             	        { //insert your script or html codes here.
                             	        html:`
                                                 <!-- TradingView Widget BEGIN -->
                             		<html lang="en">
                             		<head>
                             		<title>JSTAL MIRROR PLAYER</title>
                             		<meta charset="UTF-8">
                             		<meta name="viewport" content="width=device-width, initial-scale=1">
                             		<link rel="stylesheet" type="text/css" href="http://localhost:8080/modules/MyPlayer/css/styles.css">   <!-- page design -->
                             	        <link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css">
                             		<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script>  <!-- For audio play -->
                             		<style>
                             		</style>
                             		</head>
                             		<body>
                             		<div class="header">
                             		  <h1>Mirror Webradio / MP3 Player</h1>
                             		</div>
                             		<div class="row">
                             		  <div class="main">
                             		     <p>My Radio Stations</p>
                             			 <img src="http://localhost:8080/modules/MyPlayer/images/JoeFM.jpg" style="width:5%;">
                             			 <audio id="myAudio0" src="http://icecast-qmusic.cdp.triple-it.nl:80/JOEfm_be_live_128.mp3" preload="false" controls="true" volume="1.0"></audio>
                             		     <script>   <!-- Script play pause toggle -->
                             			 var myAudio0 = document.getElementById("myAudio0");
                             				function togglePlay() {
                             				return myAudio0.paused ? myAudio0.play() : myAudio0.pause();
                             			 </script> <br>
                             			 <img src="https://upload.wikimedia.org/wikipedia/commons/0/09/Qmusiclogo2015red.jpg" style="width:5%;">
                             			 <audio id="myAudio1" src="http://icecast-qmusic.cdp.triple-it.nl:80/Qmusic_be_live_96.mp3" preload="false" controls="true" volume="1.0"></audio>
                             			 var myAudio1 = document.getElementById("myAudio1");
                             				return myAudio1.paused ? myAudio1.play() : myAudio1.stoppause();
                             			 </script> <br>
                             			 <img src="https://pbs.twimg.com/profile_images/1612540320/FAMILYRADIO_LOGO_WEB_400x400.jpg" style="width:5%;">
                             			 <audio id="myAudio2" src="http://www.clubfmserver.be:8000/family.mp3" preload="false" controls="true" volume="1.0"></audio>
                             			 var myAudio2 = document.getElementById("myAudio2");
                             				return myAudio2.paused ? myAudio2.play() : myAudio2.pause();
                             			 </script> <br>
                             		    <img src="https://upload.wikimedia.org/wikipedia/commons/3/36/MNM_logo.png" style="width:5%;">
                             			 <audio id="myAudio3" src="http://icecast.vrtcdn.be/mnm_hits-high.mp3" preload="false" controls="true" volume="1.0"></audio>
                             			 var myAudio3 = document.getElementById("myAudio3");
                             				return myAudio3.paused ? myAudio3.play() : myAudio3.pause();
                             			 </script> <br>
                             		     <img src="https://upload.wikimedia.org/wikipedia/commons/thumb/1/19/Radio_2_Logo.svg/1000px-Radio_2_Logo.svg.png" style="width:5%;">
                             			 <audio id="myAudio4" src="http://icecast.vrtcdn.be/ra2ovl-high.mp3" preload="false" controls="true" volume="1.0"></audio>
                             			 var myAudio4 = document.getElementById("myAudio4");
                             				return myAudio4.paused ? myAudio4.play() : myAudio4.pause();
                             			 </script> <br>
                             		     <img src="https://pbs.twimg.com/profile_images/1476072724/Logo-alta-resolucao-MusicCityGame.jpg" style="width:5%;">
                             			 <audio id="myAudio5" src="http://stream2.intronic.nl:80/citymusic" preload="false" controls="true" volume="1.0"></audio>
                             			 var myAudio5 = document.getElementById("myAudio5");
                             				return myAudio5.paused ? myAudio5.play() : myAudio5.pause();
                             			 </script> <br>
                             		        <hr><p>Select and Play MP3 from Local database folder </p>
                             		        <input type="file" id="songs" multiple> <br> <br>
                             			<i class="fa fa-music"></i>
                             		        <audio controls id="myAudio" autoplay></audio>
                             					var songs = document.getElementById("songs"),
                             						myAudio = document.getElementById("myAudio");
                             						function next(n){
                             						  var url = URL.createObjectURL(files[n]);
                             						  myAudio.setAttribute('src', url);
                             						  myAudio.play();
                             						var _next = 0,
                             						files,
                             						len;
                             						songs.addEventListener('change', function() {
                             						  files = songs.files;
                             						  len = files.length;
                             						  if(len){
                             						next(_next);
                             						myAudio.addEventListener("ended", function(){
                             						   _next += 1;
                             						   next(_next);
                             						   console.log(len, _next);
                             						   if((len-1)==_next){
                             						 _next=-1;
                             				 </script>
                             		</body>
                             		<!-- TradingView Widget END -->
                                                 `,    // Ends of Widget - important to set!
                             	        width: "460px",
                             	        height: "525px",
                             	        backgroundColor: "#256d7b"   //"#FFF"
                          For people interested here the CSS details as well.
                          /* add here some separate css data */
                          /* Style the body margin: 0  */
                          body {
                              font-family: Arial;
                              margin: auto;
                              width: 450px;
                              height: 500px;
                              border: 3px solid #256d7b;
                          /* Header/logo Title  - color = #1abc9c/#008080  of #256d7b */
                          .header {
                              padding: 5px;
                              text-align: center;
                              background: #256d7b;
                              color: white;
                          /* Increase the font size of the heading */
                          .header h1 {
                              font-size: 20px;
                          /* Main column   color = #fcfcfc or white */
                          .main {
                              -ms-flex: 60%; /* IE10 */
                              flex: 60%;
                              background-color: #fcfcfc;
                              padding: 20px;
                              text-align: center;
                          /* Draw up a vertical line */
                          hr.vertical
                             width: 5px;
                             height: 100%; /* or height in PX */
                          .slider {
                            position: absolute;
                            cursor: pointer;
                            top: 0;
                            left: 0;
                            right: 0;
                            bottom: 0;
                            background-color: #ca2222;
                            -webkit-transition: .4s;
                            transition: .4s;
                             border-radius: 34px;
                          .slider:before {
                            position: absolute;
                            content: "";
                            height: 26px;
                            width: 26px;
                            left: 4px;
                            bottom: 4px;
                            background-color: white;
                            transition: .4s;
                            border-radius: 50%;
                          input:checked + .slider {
                            background-color: #2ab934;
                          input:focus + .slider {
                            box-shadow: 0 0 1px #2196F3;
                          input:checked + .slider:before {
                            -webkit-transform: translateX(26px);
                            -ms-transform: translateX(26px);
                            transform: translateX(55px);
                          /*------ ADDED CSS ---------*/
                          .slider:after
                           content:'OFF';
                           color: white;
                           display: block;
                           position: absolute;
                           transform: translate(-50%,-50%);
                           top: 50%;
                           left: 50%;
                           font-size: 10px;
                           font-family: Verdana, sans-serif;
                          input:checked + .slider:after
                            content:'ON';
                          Maybe there are other ways to embed my player on the mirror, but for now MMM-Widget was the only thing I found to do.
                          Hope somebody can help me out.
                          Thx.
                          J J 2 Replies Last reply Reply Quote 0
                            j.e.f.f Project Sponsor Module Developer @Johans
                            @johans If you disable the MMM-DarkSkyForecast module do you get your web player functionality back?
                              Johans @Johans
                              @johans
                              I’ll guess something went wrong when I paste the code
                              			disabled: false,
                              			widgets: [
                              		        html:`
                              			<html lang="en">
                              			<head>
                              			<style>
                              			</style>
                              			</head>
                              			<body>
                              			</div>
                              			<div class="row">
                              			  <div class="main">
                              				 </script> <br>
                              				 </script> <br>
                              				 </script> <br>
                              				 </script> <br>
                              				 </script> <br>
                              				 </script> <br>
                              							function next(n){
                              							  myAudio.play();
                              							var _next = 0,
                              							files,
                              							len;
                              							  len = files.length;
                              							  if(len){
                              							next(_next);
                              							   _next += 1;
                              							   next(_next);
                              							   if((len-1)==_next){
                              							 _next=-1;
                              					 </script>
                              			</body>
                              		        width: "460px",
                              		        height: "525px",
                                Johans @j.e.f.f
                                @j-e-f-f
                                No, It doesn’t come back.
                                I made a new installation on fresh SD card.
                                All works fine without installing your module, after that it’s not working anymore.
                                  Johans @Johans
                                  When I run directly in the browser, it’s OK, but thats not the main goal, should run via the MagicMirror.
                                  • H Offline
                                    hco125
                                    I posted an issue on your module link in GitHub, but no response yet. Please see this link for details. Both the config in the link as well as the one below do the same thing…loading infinitely.
                                    			module: 'MMM-DarkSkyForecast',
                                    			header: "Weather",
                                    			position: 'top_center',
                                    			disabled: false,
                                    				updateInterval: 10,
                                    				units: 'us',
                                    				forecastHeaderText: "O'Neill, NE",
                                    				iconset: '5c',
                                    				apiKey: 'blocked for privacy',
                                    				latitude: '42.457649',
                                    				longitude: '-98.647789',
                                    				forecastLayout: 'tiled',```
                                    • lavolp3L Offline
                                      lavolp3 Module Developer @hco125
                                      @hco125
                                      Time to go do some debugging. Ican imagine noone will be able to help you with the information given.
                                      Please do the following:
                                      Start the mirror in dev mode
                                      npm start dev
                                      OR
                                      Open the mirror webpage on another browser (MIRRORIP:8080), press F12 for dev mode
                                      In both cases, try to find error messages referring to this module and post them here.
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                      • H Offline
                                        hco125
                                        I stripped down my MagicMirror configuration as well, so that we know that another module is not interfering. The modules that ARE on this config include: alert, updatenotification, MMM-ModuleScheduler, clock, MMM-AlarmClock, MMM-DarkSkyForecast, and MMM-Screencast. Here are the errors in the console running MagicMirror and accessing on Chrome with those modules running.
                                        moment-timezone-with-data.js:472 Moment Timezone has no data for none. See http://momentjs.com/timezone/docs/#/data-loading/.
                                        logError	@	moment-timezone-with-data.js:472
                                        57
                                        fn.tz	@	moment-timezone-with-data.js:554
                                        getDom	@	clock.js:79
                                        (anonymous)	@	main.js:110
                                        updateDom	@	main.js:109
                                        updateDom	@	main.js:514
                                        updateDom	@	module.js:358
                                        (anonymous)	@	clock.js:45
                                        However, I then stripped ALL modules EXCEPT MMM-DarkSkyForecast and rechecked the console. I get NO errors, and the log is as follows, but the modules still loads infinitely, with no display of weather (see screenshot, below):
                                        Initializing MagicMirror.
                                        translator.js:201 Loading core translation file: translations/en.json
                                        translator.js:224 Loading core translation fallback file: translations/en.json
                                        loader.js:182 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
                                        module.js:469 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: 2.6.0
                                        module.js:471 Version is ok!
                                        module.js:477 Module registered: MMM-DarkSkyForecast
                                        loader.js:152 Bootstrapping module: MMM-DarkSkyForecast
                                        loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                                        loader.js:182 Load script: modules/MMM-DarkSkyForecast/skycons.js
                                        loader.js:157 Scripts loaded for: MMM-DarkSkyForecast
                                        loader.js:197 Load stylesheet: modules/MMM-DarkSkyForecast/MMM-DarkSkyForecast.css
                                        loader.js:159 Styles loaded for: MMM-DarkSkyForecast
                                        loader.js:161 Translations loaded for: MMM-DarkSkyForecast
                                        loader.js:197 Load stylesheet: css/custom.css
                                        MMM-DarkSkyForecast.js:138 Starting module: MMM-DarkSkyForecast
                                        main.js:468 All modules started!
                                        module.js:156 MMM-DarkSkyForecast received a system notification: ALL_MODULES_STARTED
                                        module.js:156 MMM-DarkSkyForecast received a system notification: MODULE_DOM_CREATED
                                        module.js:156 MMM-DarkSkyForecast received a system notification: DOM_OBJECTS_CREATED
                                        So after adding in one module at a time to determine which one was throwing the errors I posted above, it is the default MagicMirror “clock” module, and I do not believe it is the cause of the MMM-DarkSkyForecast problems.
                                          @johans @hco125 i believe your issues are related. If the module runs in the web browser, but not on the mirror, then we’re seeing an issue with the difference in JavaScript syntax supported by Chrome versus Electron. I’ll need to debug your configs in Electron running on the Pi, as the errors will only be seen in the browser console.
                                          Sorry I’ve been slow to respond. I just got back from visiting family for the holidays so I haven’t been checking this forum at all nor the issue list in my git repo. Will take a look and let you know if I find any problems.
                                            djsunrise19
                                            Looks very nice. Is there a way to get the “feels like” temperature, too? I can’t find anything about it.
                                            • 6
                                            • 16
                                            • 17
                                            • 4 / 17
