    24 Hour clock problem
    25 Posts 5 Posters 13.8k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Rasmus rytter
      @rasmus-rytter
      You don’t have your config.js.sample file?
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "YOUR_OPENWEATHER_API_KEY"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      Reply Quote 1
      • B
        bhepler Module Developer
        Everyone! Please, use the Markdown features of the forum when posting code.
        @rasmus-rytter said in 24 Hour clock problem:
        Everything has gone except of the clock?
        Looking at your config.js file, you are missing the code to include the clock module entirely. @Mykle1 has it correct: It’s best at this point to copy the config.js.sample file to config.js and just start from a known working baseline.
        Reply Quote 1
        • Mykle1M
          @rasmus-rytter
          Also, for future reference, a value of true should not be in quotes as you have in colored: "true", above.
          • R
            Rasmus rytter
            Thanks, i learn some new everyday :)
            Mykle1M 1 Reply Last reply
            • Mykle1M
              As do I, my friend. As do I. :thumbsup:
