    Installing on a Pi Zero
    175 Posts 33 Posters 258.6k Views 33 Watching
      Big11
      @andyc7687 said in Installing on a Pi Zero:
      pm2 start ~/MagicMirror/installers/pm2_MagicMirrorPi0.json
      Need help…
      I have installed MM on my PiZero’s many times with no succes to start it just localy and automatically …
      i followed your script and all seems running well and i did what you decided to autostart with PM2…
      but it didn’t
      after rebooting i can see the process “PM2 v3.4.2 GOD” running, but Nothing happens on my screen
      I tried to start the three startscripts manually and i got an Gtk-Error starting chromium-browser which i can’t work
      That it basicly works is shown when i start first the xserver manually (startx) and then whitin starting chromium-browser and Point it to http://localhost:8080…
      What is going wrong?
      where i can see some Errors ?
      Thanks a lot…
        andyc7687 @Big11
        @big11 From what I am reading of your reply, are you booting into command line mode? You should be booting into Desktop AutoLogin from sudo raspi-config | Choose option: Boot Options | Choose option: Desktop / CLI | then Desktop Autologin.
        Can you confirm which install script you ran? Did you run the one from ac2799/MagicMirror or ac2799/MagicMirrorPi0Installer?
        • 1 Offline
          12wsx
          This post is deleted!
          • 1 Offline
            12wsx
            same problem to me.
            using raspberry pi Zero (not W)
            installed latest Raspbian Stretch with desktop. update from first run creator.
            Full instalation LOG
            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/     MagicMirror/master/installers/raspberry.sh)"
            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                             $$  __$$\
            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$     $\   $$$$$$\   $$$$$$\  \__/  $$ |
            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __     $$\ $$  __$$\ $$  __$$\  $$$$$$  |
            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |       \__|$$ /  $$ |$$ |  \__|$$  ____/
            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |           $$ |  $$ |$$ |      $$ |
            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |           \$$$$$$  |$$ |      $$$$$$$$\
            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|            \______/ \__|      \________|
                                    \______/
            If you are running a Pi Zero, installation will continue, but you will have to r     un in server only mode.
            Updating packages ...
            Stary:1 http://archive.raspberrypi.org/debian stretch InRelease
            Stary:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
            Czytanie list pakietów... Gotowe
            Budowanie drzewa zależności
            Odczyt informacji o stanie... Gotowe
            Obliczanie aktualizacji... Gotowe
            0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
            E: Nie udało się otworzyć pliku blokady /var/lib/dpkg/lock - open (13: Brak dost     ępu)
            E: Nie udało się zablokować katalogu administracyjnego (/var/lib/dpkg/), czy uży     to uprawnień administratora?
            Update failed, carrying on installation ...
            Installing helper tools ...
            build-essential is already the newest version (12.3).
            curl is already the newest version (7.52.1-5+deb9u8).
            git is already the newest version (1:2.11.0-3+deb9u4).
            unzip is already the newest version (6.0-21).
            wget is already the newest version (1.18-5+deb9u2).
            Check current Node installation ...
            Node.js is not installed.
            Installing Node.js ...
            Downloading node v11.6.0
              % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                             Dload  Upload   Total   Spent    Left  Speed
            100 17.0M  100 17.0M    0     0   861k      0  0:00:20  0:00:20 --:--:--  968k
            Extracting node v11.6.0
            Extracting node and npm
            Zostaną zainstalowane następujące NOWE pakiety:
              unclutter
            0 aktualizowanych, 1 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
            Konieczne pobranie 16,6 kB archiwów.
            Po tej operacji zostanie dodatkowo użyte 47,1 kB miejsca na dysku.
            Pobieranie:1 http://ftp.icm.edu.pl/pub/Linux/distributions/raspbian/raspbian str     etch/main armhf unclutter armhf 8-20 [16,6 kB]
            Pobrano 16,6 kB w 1s (14,1 kB/s)
            Prekonfiguracja pakietów ...
            Wybieranie wcześniej niewybranego pakietu unclutter.
            (Odczytywanie bazy danych ... 80763 pliki i katalogi obecnie zainstalowane.)
            Przygotowywanie do rozpakowania pakietu .../unclutter_8-20_armhf.deb ...
            Rozpakowywanie pakietu unclutter (8-20) ...
            Konfigurowanie pakietu unclutter (8-20) ...
            Przetwarzanie wyzwalaczy pakietu man-db (2.7.6.1-2)...
            Cloning MagicMirror ...
            Cloning into 'MagicMirror'...
            remote: Enumerating objects: 305, done.
            remote: Counting objects: 100% (305/305), done.
            remote: Compressing objects: 100% (273/273), done.
            remote: Total 305 (delta 37), reused 169 (delta 22), pack-reused 0
            Receiving objects: 100% (305/305), 614.71 KiB | 747.00 KiB/s, done.
            Resolving deltas: 100% (37/37), done.
            Cloning MagicMirror Done!
            Installing dependencies ...
            npx: zainstalowano 405 w 218.392s
            npm notice CANARY npmc is experimental software. If you find an issue, please fi     le it in the main npm repository, and call out that you were using npmc.
            npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically un     maintained. Move on to something better. This package will continue to work with      Grunt v1, but it will not receive any updates.
            npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@n     pmjs.com for more info.
            > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron     -chromedriver
            > node ./download-chromedriver.js
            successfully dowloaded and extracted!
            > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            Downloading SHASUMS256.txt
            [============================================>] 100.0% of 5.39 kB (5.39 kB/s)
            > magicmirror@2.6.0 install /home/pi/MagicMirror
            > cd vendor && npm install
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fse     vents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@     1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}     )
            added 82 packages from 57 contributors and audited 220 packages in 118.631s
            found 3 low severity vulnerabilities
              run `npm audit fix` to fix them, or `npm audit` for details
            > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
            > sh installers/postinstall/postinstall.sh && npm run install-fonts
            MagicMirror installation successful!
            > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
            > cd fonts && npm install
            added 1 package from 1 contributor and audited 1 package in 42.42s
            found 0 vulnerabilities
            npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is      installed. You must install peer dependencies yourself.
            npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed.      You must install peer dependencies yourself.
            added 921 packages from 1366 contributors in 1049.638s
            Errors while installing dependencies! (source command: npmc@latest install)
            + acorn@6.0.5
            added 2 packages from 78 contributors, updated 1 package and audited 2467 packag     es in 175.814s
            found 8 vulnerabilities (7 low, 1 high)
            Errors while installing dependencies! (source command: npm install acorn@latest)
            + stylelint@9.9.0
            added 155 packages from 107 contributors, removed 32 packages, updated 99 packages, moved 6 packages and audited 4452 packages in 458.975s
            found 4 vulnerabilities (3 low, 1 high)
            Errors while installing dependencies! (source command: pm install stylelint@latest)
            + jshint@2.9.7
            added 2 packages from 1 contributor, removed 6 packages and updated 5 packages in 226.509s
            fixed 3 of 4 vulnerabilities in 4452 scanned packages
              1 vulnerability required manual review and could not be updated
            Vulnerabilities may remain!
            Check plymouth installation ...
            Splashscreen: Checking themes directory.
            Splashscreen: Create theme directory if not exists.
            Splashscreen: Theme copied successfully.
            Splashscreen: Changed theme to MagicMirror successfully.
            Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
            /usr/local/bin/pm2 -> /usr/local/lib/node_modules/pm2/bin/pm2
            /usr/local/bin/pm2-dev -> /usr/local/lib/node_modules/pm2/bin/pm2-dev
            /usr/local/bin/pm2-docker -> /usr/local/lib/node_modules/pm2/bin/pm2-docker
            /usr/local/bin/pm2-runtime -> /usr/local/lib/node_modules/pm2/bin/pm2-runtime
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/pm2/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            + pm2@3.2.4
            added 313 packages from 246 contributors in 320.301s
            __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
             _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
              _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
               _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                 _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                  _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                   _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                    _\///______________\///______________\///__\///////////////__
                                      Runtime Edition
                    PM2 is a Production Process Manager for Node.js applications
                                 with a built-in Load Balancer.
                            Start and Daemonize any application:
                            $ pm2 start app.js
                            Load Balance 4 instances of api.js:
                            $ pm2 start api.js -i 4
                            Monitor in production:
                            $ pm2 monitor
                            Make pm2 auto-boot at server restart:
                            $ pm2 startup
                            To go further checkout:
                            http://pm2.io/
            [PM2] Init System found: systemd
            Platform systemd
            Template
            [Unit]
            Description=PM2 process manager
            Documentation=https://pm2.keymetrics.io/
            After=network.target
            [Service]
            Type=forking
            User=pi
            LimitNOFILE=infinity
            LimitNPROC=infinity
            LimitCORE=infinity
            Environment=PATH=/usr/local/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
            Environment=PM2_HOME=/home/pi/.pm2
            PIDFile=/home/pi/.pm2/pm2.pid
            ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
            ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
            ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
            [Install]
            WantedBy=multi-user.target
            Target path
            /etc/systemd/system/pm2-pi.service
            Command list
            [ 'systemctl enable pm2-pi' ]
            [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
            [PM2] Making script booting at startup...
            [PM2] [-] Executing: systemctl enable pm2-pi...
            Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
            [PM2] [v] Command successfully executed.
            [PM2] Freeze a process list on reboot via:
            $ pm2 save
            [PM2] Remove init script via:
            $ pm2 unstartup systemd
                                      Runtime Edition
                            $ pm2 start app.js
                            $ pm2 monitor
                            $ pm2 startup
                            http://pm2.io/
            [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
            [PM2] PM2 Successfully daemonized
            [PM2][WARN] Applications MagicMirror not running, starting...
            [PM2] App [MagicMirror] launched (1 instances)
            │ Name        │ id │ mode  │ status │ ↺      │ cpu │ memory │
            │ MagicMirror │ 0  │ 2.6.0 │ fork   │ online │ 0   │ 0%     │ 2.5 MB   │
             Use `pm2 show ` to get more details about an app
            [PM2] Saving current process list...
            [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
            We're ready! Restart your Pi Zero to start your MagicMirror.
            pi@raspberrypi:~ $ sudo login as: pi
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Mon Jan  7 20:33:42 2019
                                    \______/
              unclutter
            > node install.js
            + acorn@6.0.5
            + stylelint@9.9.0
            + jshint@2.9.7
            Do you want usHasło:
            Nieprawidłowe logowanie
            raspberrypi login: rror (y/N)?y
            + pm2@3.2.4
                                      Runtime Edition
                            $ pm2 start app.js
                            $ pm2 monitor
                            $ pm2 startup
                            http://pm2.io/
            Platform systemd
            Template
            [Unit]
            [Service]
            Type=forking
            User=pi
            LimitNPROC=infinity
            LimitCORE=infinity
            [Install]
            Target path
            Command list
            $ pm2 save
                                      Runtime Edition
                            $ pm2 start app.js
                         Hasło:
            after reboot server work properly. If I connect from my computer webbrowser everythings is fine.
            On local LCD raspberry load to desktop and do not run chromium (default browser)
            sorry for 2 post one by one.
              Big11 @andyc7687
              @andyc7687
              i run just
              bash -c “$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)”
              don’t know if this leads to bare or Pi0 …
              This is your “modified” installer script also for the Pi0…
                andyc7687 @Big11
                @big11 this goes to my forked repo. Are you booting through to the desktop or to the console?
                  Big11 @andyc7687
                  @andyc7687
                  so since yesterday i installed many times from Scratch but without success……
                  With your script i ran into Troubles with a lot of Errors…
                  missing dependencies….
                  so i suggest to do more steps after “sudo apt INSTALL --fix-missing” -> “apt UPGRADE --fix-missing” does not work…
                  sudo dpkg –configure -a. and.
                  sudo apt install -f.
                  at npm install a lot of Warnings e.g.
                  added 921 packages from 1366 contributors and audited 2466 packages in 859.404s
                  + stylelint@9.9.0
                  added 156 packages from 107 contributors, removed 32 packages, updated 99 packages, moved 6 packages and audited 4452 packages in 370.707s
                  pi@magicpi:~ $   run `npm audit fix` to fix them, or `npm audit` for details
                  npm ERR! code EAUDITNOPJSON
                  npm ERR! audit No package.json found: Cannot audit a project without a package.json
                  npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_26_138Z-debug.log
                  npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_35_497Z-debug.log
                  -bash: run: Kommando nicht gefunden.
                  pi@magicpi:~ $ Errors while installing dependencies! (source command: pm install stylelint@latest)
                  -bash: Syntaxfehler beim unerwarteten Wort `('
                  i could fix this with
                  "npm audit fix" or "npm audit fix --force" in directory MagicMirror
                  and then i figured out autostart with PM2 as described in MM-Wiki but…
                  it won’t start …
                  as done in the guide i created a mm.sh script und configured this for autostart with pm2
                  at next start Nothing happens to start MagicMirror localy
                  a “pm2 logs mm”
                  Shows a loop of “sh run-start.sh”
                  |mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
                  0|mm       | > sh run-start.sh
                  0|mm       |
                  0|mm       |
                  0|mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
                  0|mm       |
                  0|mm       |
                  0|mm       |
                  0|mm       |
                  a cat to run-start.sh Shows
                  pi@magicpi:~/MagicMirror $ cat run-start.sh
                  if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                          export DISPLAY=:0 # Set by default display
                  fi
                  electron js/electron.js $1
                  but electron.js isn’t installed
                  trying manually install this with
                  sudo npm install electron -g
                  ended again in Error-Messages
                  Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/electron/.electron'
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! electron@4.0.1 postinstall: `node install.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the electron@4.0.1 postinstall script.
                  npm ERR!     /root/.npm/_logs/2019-01-09T09_13_51_893Z-debug.log
                  so… now i’m giving up for These days….
                  does anybody know where my Failure is ??
                  Thank you
                    andyc7687 @Big11
                    @big11 I did a test install today, so I’m really not sure what you are doing.
                    You will notice that the missing dependencies are installed in subsequent steps (e.g. there’s a problem with style lint and acorn. This is then fixed (see where it says + stylelint@9.9.0 and + acorn lower down in your warnings).
                    This installation is completely different from the MM-Wiki. It does not use sh run-start.sh at all. Therefore there may well be problems.
                    Can I ask, are you doing your installation over SSH/Telnet? or on the Pi itself? because you keep mentioning ‘locally’ and I just want to make sure I know what you mean by that.
                    Edit: Also, don’t use npm install in sudo; it should be run as the normal user
                      Big11 @andyc7687
                      @andyc7687
                      as for your Question
                      i’m installing over SSH but start it then directly on the Pi0…
                      i will i try a new Installation by now…
                      normally i don’t run “npm install” as root…
                      don’t know if i wrote so…
                        Big11 @Big11
                        @big11
                        thats my “achievment” from last night…
                        pi@raspberrypi:~ $ cd MagicMirror/
                        > sh run-start.sh
                        run-start.sh: 4: run-start.sh: electron: not found
                        npm ERR! file sh
                        npm ERR! errno ENOENT
                        npm ERR! syscall spawn
                        npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
                        npm ERR! spawn ENOENT
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.6.0 start script.
                        npm ERR!     /home/pi/.npm/_logs/2019-01-10T07_11_11_053Z-debug.log
                        • 1 Offline
                          12wsx
                          finally full success!!:)
                          @big11 install directly from raspberry terminal not via ssh.
                          After few fresh installation and hundreds errors last time tried install using
                          bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)"
                          from raspberrypi terminal.There were some errors but finally worked.
                          if you want, I can make a image of my card and share it.
                            Big11 @12wsx
                            @12wsx
                            you made my day…
                            it works…
                            the first differences i encountered was the Installation of electron …
                            this i didn’t found at all the others…
                            and i thought before, that this will be the quest…
                            regarding to the warnings installing npm
                            you could fix that with “npm Audit fix” or “npm Audit fix --force”
                            as suggested…
                            i did this also, so maybe this could be an error too…
                            and if it works but this warnings, who cares…. :-)
                            have a great day…
                            thank you
                            • W Offline
                              Wordonroad
                              Awesome write up. Super helpful!
                              • qu1queQ Offline
                                qu1que Project Sponsor
                                Thank you very much for this work! The tutorial works perfectly. I just installed it in a rpi zero W. Highly recommended for anyone who wants to install it on this SBC.
                                • C Offline
                                  cdh1001
                                  Many thanks Andrew - worked well for me (other than first step: connecting to wifi with WPA2 needed some minor tweaks.)
                                    andyc7687 @cdh1001
                                    @cdh1001 please specify tweaks as they might help others.
                                    • C Offline
                                      cdh1001 @andyc7687
                                      @andyc7687 - I needed to delete the line: key_mgmt=WPA-PSK Based on discussions elsewhere I originally tried renaming Key_mgmt to WPA2 and/or changing group=CCMP, but neither of those were necessary for me; simply deleting the line was sufficient.
                                        andyc7687 @cdh1001
                                        @cdh1001 thanks, I will amend my guide over the weekend then.
                                          Smolo
                                          Thanks for the script and the hints so far :-)
                                          Unfortunately I am really frustrated after x installations. :-( Currently everything is installed the autostart works but chrome says “err_connection_refused”!
                                          Does anyone have an idea?
                                          Zero W V1.1 / Raspian Desktop / no sudo
                                          • bheplerB Offline
                                            bhepler Module Developer @Smolo
                                            @smolo Some suggestions: First, make sure that some form of IP address is present in the address key. Usually 127.0.0.1, but the IP address of your pi will probably work too. Without that value, the web server has a tendency to freak out.
                                            Second, make sure you are specifying the port in your web call. That one has bitten me a couple times.
                                            Third, I would double-check your IP whitelist in the config.js. Possibly open it up to all connections and attempt to view the magic mirror from another computer. See if the problem is local to the PI Zero or if it is on a deeper level.
                                            • 8
                                            • 9
                                            • 2 / 9
