    Calender only Loading!
    21 Posts 4 Posters 14.1k Views 4 Watching
    • F Offline
      Force_United
      Hi!
      I NEED HELP!
      what should I do?
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @Force_United
        @force_united could u give us a little more info.
        New system, old, what level of MM, what kind of calendar, do u see errors,
        Etc
        • F Offline
          Force_United @sdetweil
          Hi! Do you have discord so i can show you! I am not good in Linux so i need so much help!
          Please help
          • F Offline
            Force_United
            @sdetweil can you help me??
              Mykle1 Project Sponsor Module Developer @Force_United
              @force_united
              @sdetweil asked you a few questions in order to help you. That’s how it works. You post your problem. Others posts their answers. People that read this in the future have the benefit of this information.
              • F Offline
                Force_United
                @Mykle1 Yo! I am not good in linux so can you get me the commands to check everything i need to check?
                what is the command here? New system, old, what level of MM, what kind of calendar, do u see errors,
                linux is unknown to me
                Please help me!
                  @force_united said in Calender only Loading!:
                  Hmm, let’s just start here. I assume you’ve changed the default NY TIMES CALENDAR url. Otherwise, it should be working. SO, post(copy and paste, using a code block) your calendar entry from your config.js file here.
                  • F Offline
                    Force_United
                    Yo! @Mykle1
                    i fix my problem (-:
                    But somthing is wrong ): date in calender is not correct is not 4 days to the event is 5 days. I not understand that )-;
                    Please help! (-:
                    Thank you
                    with best regards
                    ★¯_(Force_United)_/¯★
                    • F Offline
                      Force_United
                      Yo! @Mykle1 @MichMich
                      How can I set up the calendar for Norwegian time?
                      with best regards
                      ★Force_United ★
                        @force_united
                        another post said
                        had the same issue, it shows you the end of the event, usually because its an all day event.
                        here is my config:
                        just added the option showEnd: false <-----
                        and date and time formats according to moment
                        • F Offline
                          Force_United
                          Yo! @sdetweil
                          Not working )-:
                          with best regards
                          ★Force_United ★
                          • F Offline
                            Force_United
                            Yo! @sdetweil
                            I think the calendar is set up as American time and not Norwegian time. how do I change the calendar to Norwegian time? The clock is set correctly but the calendar is not correct.
                            with best regards
                            ★Force_United ★
                              @force_united what calendar? my google calendar is set to my local time
                              • F Offline
                                Force_United
                                Yo!
                                When the clock is 06:00 in norway it is 00:00 in the usa. so it changes when the clock is 06:00 in norway.
                                with best regards
                                ★Force_United ★
                                  @force_united not the question…
                                  there is local system time (pi clock) - YOU set the system time (MM uses system time)
                                  and there is calendar time (where is the calendar stored?)… mine is on google.com (wherever that is)…
                                  • F Offline
                                    Force_United
                                    Yo! @sdetweil i use google calender (-:
                                    • F Offline
                                      Force_United
                                      Yo! @Mykle1 @MichMich @sdetweil
                                      Same problems with calander. Calander not sync with my norwegian time.
                                      Where can I get this to work?
                                      When the clock in norway is 00:00 it is still on the same date. But when the time is 06:00 in norway, the calendar changes to the next date. I want the calendar to sync with Norwegian time.
                                      I need help!
                                      ★Force_United ★
                                      • F Offline
                                        Force_United
                                        Yo!
                                        I want the calendar to change date 00:00 in Norwegian time.
                                        ★Force_United ★
                                        • F Offline
                                          Force_United
                                          HELLO???
                                            @force_united is the mm system timezone the same as the calendar timezone?
