    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
    • JalibuJ
      Jalibu Module Developer @hogedir
      @hogedir your configuration is buggy. Please read the module’s Readme.
      You don’t have to (and should not) change the mapUrl at all.
      Use mapPositions to justify it. The module should work world-wide.
      I’d recommend to use the default values whenever possible and just to set values you need to override.
      Does that work for you?
       module: "MMM-RAIN-MAP",
       position: "top_center",
        mapPositions: [
         { lat: 48.472, lng: -2.725 }
      H 1 Reply Last reply
      • H
        hogedir @Jalibu
        @Jalibu Thanks. I copied your code, and nothing again. No map.
        S JalibuJ 2 Replies Last reply
          sdetweil @hogedir
          @hogedir can you show the messages at mm startup?
          either npm start or if you use pm2, then
          pm2 logs --lines=50
          • JalibuJ
            @hogedir I noticed there were wrong double quote characters in the code of my last post.
            Please try again with the code below. Otherwise, please open an issue on GitHub and provide all the information asked in the form (entire config & logs)
              mapPositions: [
            • H
              hogedir
              @hogedir @Jalibu it’s working now Thanks ! : the map is showing well now BUT the rain is not showed very well !
              I compared what i see outside of my home and we had 5minutes before some rain and your data flow is not precise at all, i did not saw a rain in my region on your map but i saw it in weatherplaza.
              I give you the page which is more precise and realistic than the rain data you have in the module : https://www.weerplaza.nl/regenradar/europa/frankrijk/
              Map of rains with weather plaza : :
              Map of rains with your module : :
              Lots of difference, weather plaza is realistic (i checked outside 2 times yesterday, your module did not show well the rain.)
              • Second thing, I noticed something too : i want the “pause” time before the red zone to be more fast (some mms more fast). is it possible to change the “pause timer” ? Thanks
              • H
                hogedir @Jalibu
                @Jalibu Look Here is the map of Weatherplaza (meteoplaza) in the same time than yours, if it can help.
                and then the data flow on the module (less rain and less precise) :
                thanks
                  sdetweil @hogedir
                  @hogedir it’s not ‘his’ data. he is requesting a graphic from a service, and displaying what they give.
                  H 2 Replies Last reply
                  • H
                    hogedir @sdetweil
                    • H
                      hogedir @sdetweil
                      @sdetweil @Jalibu Obiviously !
                      I mean it’s Rainviewer data but rainviewer is not 100% legit.
                      weerplaza is the best radar information worldwide. They use sevral radar information worldwide and unite all these data for free. I think the only one very precise to offer this type of information.
                      They have a widget API too ! you could integrate in addition to Openweather+rainviewer.
                      The weerplaza api is here : https://www.weerplaza.nl/weerwidgets/
                      And @Jalibu Thanks for your work, I like the zoom option and the ultimate option you added and it’s very useful.
                        MajorC Project Sponsor
                        I have also often had the feeling that Rainviewer’s data is not particularly accurate.
                        If the option to switch to another provider were to be built in, I could only welcome that.
                        JalibuJ 1 Reply Last reply
                        • JalibuJ
                          Jalibu Module Developer @MajorC
                          @MajorC @hogedir
                          Unfortunately, Weerplaza.nl does not offer an API. I can’t just take their weather data and use it in MMM-RAIN-MAP.
                          They only allow to embed their service as an iFrame. You can easily do this on your own with https://github.com/alberttwong/MMM-iFrame
                          • H
                            hogedir @Jalibu
                            @Jalibu Is it possible to add a second source possible to be selected in the module ? the goal could be to show CLOUDS via SATELLITE RADAR too. Using IFRAME is not a solution. I prefer to use a unique MAP with rain + clouds included.
                            because lots of people needs to know if some clouds will be showed
                            Could be very very a master class module with that option.
                            here an example of sat clouds : http://en.sat24.com/en
                            Here the code you could use to integrate that data in the module : http://en.sat24.com/en/freeimages
                            RAINVIEWER DATA is not accurate at all like said MajorC(Project Sponsor). It doesn’t represent the reality.
                            Check
                            • JalibuJ
                              @hogedir I understand the need and desire. However, neither the weather data/layers from Weerplaza.nl, nor those from sat24.com are in any way compatible with the previous module. It is technically not so easy to put their layers just “over” the map ;-)
                              If someone finds a solution and takes care of the programming, then I would be happy to put this extension into the module.
                              However, I don’t have the time to take care of it myself.
                              • W
                                whimsicality
                                Is there a basic resource on how to generate maps? I am struggling with this basic concept. I’ve been to open street maps but I don’t see any way to generate a file like you did in the example.
                                  sdetweil @whimsicality
                                  @whimsicality the api provides the drawing of the maps
                                  W 1 Reply Last reply
                                  • W
                                    whimsicality @sdetweil
                                    @sdetweil according tot he config it looks like I’m supposed to input all kinds of GPS coordinates for the edges of the map as well as the link to the picture of the map… I think I’m just confused.
                                      @whimsicality he’s telling the api the size and shape of the map to draw… because thats what they do…
                                      I do the same thing with chartjs… I tell it the size and shape and all the points in the data, and what kind of chart to draw, and it generates the graphics.
                                      • W
                                        @sdetweil I think I was making it unnecessarily complicated, I understand it now. thanks!
                                        • W
                                          whimsicality
                                          hi! love this app but am struggling. I’ve tried the CSS mentioned here to change the opacity as well as just changing it under “config” but I can’t get teh opacity of the map to change. is there any other option to attempt?
                                          • W
                                            whimsicality
                                            Hi am definitely loving this module but honestly struggling to get the rain map to go away when rain is not predicted. I see the instructions for how to make it work with the weather module, but what piece of code do I need to have present in MMM-OpenWeatherForecast in order to trigger MMM-RAIN-MAP to hide itself? Sorry if it’s obvious…
                                            • 10
                                            • 9 / 10
