    MMM-Multimonth
    calendarmagicmirror2module
    78 Posts 19 Posters 62.7k Views 17 Watching
      sdetweil @BKeyport
      @BKeyport issued? u mean notification ?
      each event looks like this
      title: recurrenceTitle,
      startDate: startDate.format("x"),
      endDate: endDate.format("x"),
      fullDayEvent: true/false,
      recurringEvent: true/false,
      class: event.class,
      firstYear: event.start.getFullYear(),
      geo: geo,
      description: description
      code
      for(let event of payload){
          event.title
      • BKeyportB
        BKeyport Module Developer
        I’ve now added the ability to highlight weekends, per request of a user.
        • W
          welby
          Thanks very much for this it works great. One thing i can’t work out though is how to change the start of the week to Monday? Any tips on how the moment.js works.
          BKeyportB 1 Reply Last reply
          • BKeyportB
            BKeyport Module Developer @welby
            @welby Sorry for the long wait for a response.
            The start of week is tied to your default language and defaults for your locale. If you have it set to German, for instance, it’ll switch to Monday start.
            I haven’t thought about a manual start of week adjustment, I might add it when I have time.
              retroflex Project Sponsor Module Developer
              Great module @BKeyport , thanks a lot! I changed my custom.css a bit to match my other modules and ended up with a rather minimalist look:
              Here’s the css if anyone’s interested:
              .MMM-Multimonth .month {
                padding-left: 0px;
                padding-right: 0px;
              .MMM-Multimonth .month-header {
                background-color: #000000;
                text-transform: uppercase;
                font-size: 15px;
                font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                font-weight: 400;
                border-bottom: 1px solid #666;
                line-height: 15px;
                padding-bottom: 5px;
                margin-bottom: 10px;
                color: #999;
                border-radius: 0px;
              .MMM-Multimonth .days-header {
                color: #808080;
                text-align: center;
              .MMM-Multimonth .weeknumber:before {
                content: "v. ";
              .MMM-Multimonth .weeknumber {
                color: #808080;
                padding-right: 9px;
              .MMM-Multimonth .day {
                text-align: center;
              .MMM-Multimonth .current_day {
                background-color: #FFD11C;
                text-align: center;
                border-radius: 4px;
                padding-left: 0px;
                padding-right: 0px;
                margin-left: 4px;
                margin-right: 4px;
              Reply Quote 3
              • BKeyportB
                BKeyport Module Developer @retroflex
                @retroflex Nice!
                • BKeyportB
                  new product released!
                  Added:
                  Language and calendar modification unlinked. The module now has startWeek variable to set the start of the week
                  You now can shorten the day names to the shortest available for your language. (for english, instead of “Sun Mon Tue Wed Thu Fri Sat” it will be “S M T W T F S”
                  Removed:
                  All references and use of Moment. It’s now native code completely.
                  Other:
                  There’s a bug - Week numbers are in the system, but it will generate an additional line. I am going to re-do the module more (enough to create a MultiMonth2), so in that process I’ll sure I’ll find the cause.
                  As a reminder, internationalization is based on the mirror as a whole, so if you have your mirror set to French, it will have French month and day names.
                  Read the Readme for instructions.
                  Thanks to MMRize for the inspiration to do this!
                  E 1 Reply Last reply
                  Reply Quote 2
                  • pugslyP
                    pugsly
                    I only want to display a single month, how do I remove the beginning and ending dates from the current month calendar? Also seems like the alignment is off.
                    • BKeyportB
                      BKeyport Module Developer @pugsly
                      @pugsly
                      add this to your custom.css file. It will clear it out. As for the malformed space, I’ll have to look into that, it appears something’s minorly wrong with the CSS, which I didn’t touch from previous version.
                      .MMM-Multimonth .daydim {
                      color: var(–color-background);
                      • E
                        Egnos @BKeyport
                        @BKeyport great work!
                        Thanks.
                          p1lspeda
                          Great Module, but I think I found a small issue/bug.
                          The October I live in has 31 days, any idea what’s wrong ?
                          S BKeyportB 2 Replies Last reply
                            sdetweil @p1lspeda
                            @p1lspeda I had a similar problem in code I am porting.
                            month takes 4 or 5 weeks to show all the days… oops or 6 occasionally!
                            • BKeyportB
                              BKeyport Module Developer @p1lspeda
                              @p1lspeda Yep. Bug confirmed. Something to do with the start of week being specifically on monday (I suspect start of week and end of month being the same day). I’ll look into it when I’m able. We’re busy at work at the moment. Short term fix: set start of week to any day but Monday. 😉
                              • BKeyportB
                                @p1lspeda Bug Squashed (99% sure). Thanks for reporting.
                                  p1lspeda
                                  Confirmed,
                                  Bug fixed.
                                  Thanks for (very) quick fix.
                                  • BKeyportB
                                    @p1lspeda No worries, was using a routine wrong and didn’t catch that it was reporting the last day of the week as the first day of the week. Surprised it got through most of the month without an issue. 🤣
                                      marchvet
                                      Just installed this module and have it positioned as
                                      bottom_bar
                                      but it actually is about a half inch above the bottom.
                                      Anyway to get it to sit flush with the bottom of the screen?
                                      (I am a noob with coding)
                                      • BKeyportB
                                        BKeyport Module Developer @marchvet
                                        @marchvet Yes, it’s actually not the module that’s the error though it’s the overall system.
                                        in css/custom.css:
                                        :root {
                                        	--gap-body-top: ??px;
                                        	--gap-body-right: ??px;
                                        	--gap-body-bottom: ??px;
                                        	--gap-body-left: ??px;
                                        	--gap-modules: ??px;
                                        replace ?? with whatever value you find useful. the defaults are 60 for body and 30 for modules. I use 15 and 1 respectively.
                                        – Brendan
                                        M 2 Replies Last reply
                                          marchvet @BKeyport
                                          @BKeyport Thank you but I am not even sure how to get to the css/custom.css file?
                                            marchvet @BKeyport
                                            • 2 / 4
