    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
      Babene1 Project Sponsor @strawberry 3.141
      my branch is up to date
      this is my modul-config:
                  module: 'MMM-soccer',
                  position: 'top_right',
                      colored: true,
                      logos: true,
                      rotationInterval: 20 * 1000, // 20 seconds instead of 15 (default)
                      provider: {
                          'football-data': {
                              apiKey: 'API Keay' // Replace with your API key
                      competitions: [
                              code: 'EC', // European championship
                              standings: {
                                  provider: 'football-data',
                                  focusOn: 'GER', // Germany
                                  maxEntries: 5
                              schedules: {
                                  maxEntries: 7
      should not only display the current matchday?
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Babene1
        @babene1 schedules wasn’t optimized yet for no focusOn team specified.
        Run git pull to get the latest commit.
        lavolp3L M 2 Replies Last reply
        • lavolp3L
          lavolp3 Module Developer @strawberry 3.141
          @strawberry-3-141 Really great work man!
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            matze86 @strawberry 3.141
            @strawberry-3-141
            Nice work 👍🏻
            Is ist possible to add a config value that it shows only the top scorer?
            Another idea is that the module shows the Player List from the focussed Team with some stats (played Games, goals, assists, cards,…),
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @matze86
              @matze86 I’m not exactly sure what you want. Do you want to show only one single player or only the top scorer view?
              M 1 Reply Last reply
                pikasso
                Hello
                Successfully installed a Smart Mirror. All went with some struggles but I managed to make it go then improve step by step to my goal…
                With the initial MMM-soccer installed, an API key and all perfectly working, I tried to install the branch 42 following the commands you shared… git to extract-api-provider
                cd ~/MagicMirror/modules/MMM-soccer
                git fetch
                git checkout feature/extract-api-provider
                git pull
                npm i --production
                While all was good with inital version once updated to v3, I can see the caroussel but it’s empty either if I use the default configuration here
                Module loaded corretly but there seems to be no data when the caroussel switches. Bellow shows a message “No data available”.
                pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git pull
                Déjà à jour.
                pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git status
                Sur la branche feature/extract-api-provider
                Votre branche est à jour avec 'origin/feature/extract-api-provider'.
                Modifications qui ne seront pas validées :
                  (utilisez "git add <fichier>..." pour mettre à jour ce qui sera validé)
                  (utilisez "git checkout -- <fichier>..." pour annuler les modifications dans la copie de travail)
                        modifié :         package-lock.json
                aucune modification n'a été ajoutée à la validation (utilisez "git add" ou "git commit -a")
                In my global config, the locale is set to ‘fr-FR’ and … again, my configuration is the one here . I tried as well with [Babene’s config] removing any other module… (https://forum.magicmirror.builders/post/92126) :
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                                colored: true,
                                logos: true,
                                provider: {
                                    'football-data': {
                                        apiKey: 'xxxxx' // Replace with your API key
                                competitions: [
                                        standings: {
                                            maxEntries: 5
                                        schedules: {
                                            maxEntries: 7
                But nothing comes… looks like my API Key is maybe not working for v3 ? It was perfectly working with initial version though
                Would you have any suggestion in order to make it work ?
                  @strawberry-3-141 said in MMM-Soccer - Standings, Schedules and Top Scorers:
                  I want to Show the top 10 scorer of the league for example
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @pikasso
                    @pikasso I just started the module with your config and got data.
                    Do you have any errors in the logs?
                    • strawberry 3.141S
                      @matze86 this is already possible, see example config:
                          provider: {
                            'football-data': {
                              apiKey: 'XXX'
                          competitions: [
                              code: 'BL1',
                              scorers: {
                                maxEntries: 5
                      • K
                        Kongledyret
                        Does this still work?
                        Getting “Loading…”
                        Config:
                          position: 'bottom_right',
                            show: 'ENGLAND',
                            max_teams: 5
                          Ich hab die einfache Konfig verwendet:
                              provider: {
                                'football-data': {
                                  apiKey: 'XXX'
                              competitions: [
                                  code: 'BL1',
                                  scorers: {
                                    maxEntries: 5
                          I have this error:
                          [ERROR] [MMM-soccer]: SoccerError: FETCHING_SCORERS
                          at Object.fetchScorers (/home/pi/MagicMirror/modules/MMM-soccer/provider/football-data/provider.js:110:15)
                          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                          at async Class.createSingleRequest (/home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:86:30)
                          at async Promise.all (index 0)
                          at async Class.makeRequests (/home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:97:27) {
                          competition: ‘BL1’,
                          provider: ‘football-data’
                          H 1 Reply Last reply
                          • H
                            Henrik @Babene1
                            @Babene1 @Kongledyret
                            I am using this config, and it works fine. Make sure to do a git pull if you haven’t already.
                            			position: 'top_left',
                            				show: ['PL', 'PD'],
                            				showMatches: false,
                            				api_key: 'goes here',
                                            		logos: true,
                                           		 	colored: true,
                            				updateInterval: 40,
                            				liveMode: false,
                            Just to make sure we’re talking about the same thing, this is the one I’m using:
                            https://github.com/lavolp3/MMM-soccer
                            • 10
                            • 11
                            • 11 / 11
