    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 578.0k Views 43 Watching
    • lavolp3L
      lavolp3 Module Developer @strawberry 3.141
      @strawberry-3-141 Really great work man!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        matze86 @strawberry 3.141
        @strawberry-3-141
        Nice work 👍🏻
        Is ist possible to add a config value that it shows only the top scorer?
        Another idea is that the module shows the Player List from the focussed Team with some stats (played Games, goals, assists, cards,…),
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @matze86
          @matze86 I’m not exactly sure what you want. Do you want to show only one single player or only the top scorer view?
            pikasso
            Hello
            Successfully installed a Smart Mirror. All went with some struggles but I managed to make it go then improve step by step to my goal…
            With the initial MMM-soccer installed, an API key and all perfectly working, I tried to install the branch 42 following the commands you shared… git to extract-api-provider
            cd ~/MagicMirror/modules/MMM-soccer
            git fetch
            git checkout feature/extract-api-provider
            git pull
            npm i --production
            While all was good with inital version once updated to v3, I can see the caroussel but it’s empty either if I use the default configuration here
            Module loaded corretly but there seems to be no data when the caroussel switches. Bellow shows a message “No data available”.
            pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git pull
            Déjà à jour.
            pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git status
            Sur la branche feature/extract-api-provider
            Votre branche est à jour avec 'origin/feature/extract-api-provider'.
            Modifications qui ne seront pas validées :
              (utilisez "git add <fichier>..." pour mettre à jour ce qui sera validé)
              (utilisez "git checkout -- <fichier>..." pour annuler les modifications dans la copie de travail)
                    modifié :         package-lock.json
            aucune modification n'a été ajoutée à la validation (utilisez "git add" ou "git commit -a")
            In my global config, the locale is set to ‘fr-FR’ and … again, my configuration is the one here . I tried as well with [Babene’s config] removing any other module… (https://forum.magicmirror.builders/post/92126) :
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
                        module: 'MMM-soccer',
                        position: 'top_right',
                            colored: true,
                            logos: true,
                            rotationInterval: 20 * 1000, // 20 seconds instead of 15 (default)
                            provider: {
                                'football-data': {
                                    apiKey: 'xxxxx' // Replace with your API key
                            competitions: [
                                    code: 'EC', // European championship
                                    standings: {
                                        provider: 'football-data',
                                        focusOn: 'GER', // Germany
                                        maxEntries: 5
                                    schedules: {
                                        maxEntries: 7
            But nothing comes… looks like my API Key is maybe not working for v3 ? It was perfectly working with initial version though
            Would you have any suggestion in order to make it work ?
              @strawberry-3-141 said in MMM-Soccer - Standings, Schedules and Top Scorers:
              I want to Show the top 10 scorer of the league for example
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @pikasso
                @pikasso I just started the module with your config and got data.
                Do you have any errors in the logs?
                • strawberry 3.141S
                  @matze86 this is already possible, see example config:
                      provider: {
                        'football-data': {
                          apiKey: 'XXX'
                      competitions: [
                          code: 'BL1',
                          scorers: {
                            maxEntries: 5
                  • K
                    Kongledyret
                    Does this still work?
                    Getting “Loading…”
                    Config:
                      position: 'bottom_right',
                        show: 'ENGLAND',
                        max_teams: 5
                      Babene1 Project Sponsor
                      Ich hab die einfache Konfig verwendet:
                          provider: {
                            'football-data': {
                              apiKey: 'XXX'
                          competitions: [
                              code: 'BL1',
                              scorers: {
                                maxEntries: 5
                      I have this error:
                      [ERROR] [MMM-soccer]: SoccerError: FETCHING_SCORERS
                      at Object.fetchScorers (/home/pi/MagicMirror/modules/MMM-soccer/provider/football-data/provider.js:110:15)
                      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                      at async Class.createSingleRequest (/home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:86:30)
                      at async Promise.all (index 0)
                      at async Class.makeRequests (/home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:97:27) {
                      competition: ‘BL1’,
                      provider: ‘football-data’
                      • H
                        Henrik @Babene1
                        @Babene1 @Kongledyret
                        I am using this config, and it works fine. Make sure to do a git pull if you haven’t already.
                        			position: 'top_left',
                        				show: ['PL', 'PD'],
                        				showMatches: false,
                        				api_key: 'goes here',
                                        		logos: true,
                                       		 	colored: true,
                        				updateInterval: 40,
                        				liveMode: false,
                        Just to make sure we’re talking about the same thing, this is the one I’m using:
                        https://github.com/lavolp3/MMM-soccer
                        • 10
                        • 11
                        • 11 / 11
