    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 578.0k Views 43 Watching
      matze86 @strawberry 3.141
      @strawberry-3-141
      Nice work 👍🏻
      Is ist possible to add a config value that it shows only the top scorer?
      Another idea is that the module shows the Player List from the focussed Team with some stats (played Games, goals, assists, cards,…),
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @matze86
        @matze86 I’m not exactly sure what you want. Do you want to show only one single player or only the top scorer view?
          pikasso
          Hello
          Successfully installed a Smart Mirror. All went with some struggles but I managed to make it go then improve step by step to my goal…
          With the initial MMM-soccer installed, an API key and all perfectly working, I tried to install the branch 42 following the commands you shared… git to extract-api-provider
          cd ~/MagicMirror/modules/MMM-soccer
          git fetch
          git checkout feature/extract-api-provider
          git pull
          npm i --production
          While all was good with inital version once updated to v3, I can see the caroussel but it’s empty either if I use the default configuration here
          Module loaded corretly but there seems to be no data when the caroussel switches. Bellow shows a message “No data available”.
          pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git pull
          Déjà à jour.
          pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git status
          Sur la branche feature/extract-api-provider
          Votre branche est à jour avec 'origin/feature/extract-api-provider'.
          Modifications qui ne seront pas validées :
            (utilisez "git add <fichier>..." pour mettre à jour ce qui sera validé)
            (utilisez "git checkout -- <fichier>..." pour annuler les modifications dans la copie de travail)
                  modifié :         package-lock.json
          aucune modification n'a été ajoutée à la validation (utilisez "git add" ou "git commit -a")
          In my global config, the locale is set to ‘fr-FR’ and … again, my configuration is the one here . I tried as well with [Babene’s config] removing any other module… (https://forum.magicmirror.builders/post/92126) :
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
                      module: 'MMM-soccer',
                      position: 'top_right',
                          colored: true,
                          logos: true,
                          rotationInterval: 20 * 1000, // 20 seconds instead of 15 (default)
                          provider: {
                              'football-data': {
                                  apiKey: 'xxxxx' // Replace with your API key
                          competitions: [
                                  code: 'EC', // European championship
                                  standings: {
                                      provider: 'football-data',
                                      focusOn: 'GER', // Germany
                                      maxEntries: 5
                                  schedules: {
                                      maxEntries: 7
          But nothing comes… looks like my API Key is maybe not working for v3 ? It was perfectly working with initial version though
          Would you have any suggestion in order to make it work ?
            @strawberry-3-141 said in MMM-Soccer - Standings, Schedules and Top Scorers:
            I want to Show the top 10 scorer of the league for example
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @pikasso
              @pikasso I just started the module with your config and got data.
              Do you have any errors in the logs?
              • strawberry 3.141S
                @matze86 this is already possible, see example config:
                    provider: {
                      'football-data': {
                        apiKey: 'XXX'
                    competitions: [
                        code: 'BL1',
                        scorers: {
                          maxEntries: 5
                • K
                  Kongledyret
                  Does this still work?
                  Getting “Loading…”
                  Config:
                    position: 'bottom_right',
                      show: 'ENGLAND',
                      max_teams: 5
                    Babene1 Project Sponsor
                    Ich hab die einfache Konfig verwendet:
                        provider: {
                          'football-data': {
                            apiKey: 'XXX'
                        competitions: [
                            code: 'BL1',
                            scorers: {
                              maxEntries: 5
                    I have this error:
                    [ERROR] [MMM-soccer]: SoccerError: FETCHING_SCORERS
                    at Object.fetchScorers (/home/pi/MagicMirror/modules/MMM-soccer/provider/football-data/provider.js:110:15)
                    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                    at async Class.createSingleRequest (/home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:86:30)
                    at async Promise.all (index 0)
                    at async Class.makeRequests (/home/pi/MagicMirror/modules/MMM-soccer/node_helper.js:97:27) {
                    competition: ‘BL1’,
                    provider: ‘football-data’
                    • H
                      Henrik @Babene1
                      @Babene1 @Kongledyret
                      I am using this config, and it works fine. Make sure to do a git pull if you haven’t already.
                      			position: 'top_left',
                      				show: ['PL', 'PD'],
                      				showMatches: false,
                      				api_key: 'goes here',
                                      		logos: true,
                                     		 	colored: true,
                      				updateInterval: 40,
                      				liveMode: false,
                      Just to make sure we’re talking about the same thing, this is the one I’m using:
                      https://github.com/lavolp3/MMM-soccer
                      • 10
                      • 11
                      • 11 / 11
