    MMM-QuotesFromReddit
    magic mirrorquotesrandom
    10 Posts 4 Posters 6.3k Views 4 Watching
      bthuilot
      Description
      Picks a random post from /r/quotes and displays the title meaning a random supply of quotes! Ideally meant to replace the compliments module.
      Download
      [card:bthuilot/MMM-QuotesFromReddit]
      Mykle1M 5 2 Replies Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @bthuilot
        @bthuilot said in MMM-QuotesFromReddit:
        Blasphemy! ;-)
          Spankythemusical
          Is there any way to add a css file to control the font size? While this is an unbelievably wonderful module, the quotes come in so large that it sometimes takes up half the screen.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Spankythemusical
            @Spankythemusical said in MMM-QuotesFromReddit:
            The readme for the compliments module:
            https://github.com/MichMich/MagicMirror/tree/develop/modules/default/compliments
            Configuration options
            classes
            Override the CSS classes of the div showing the compliments
            Default value: thin xlarge bright
              Spankythemusical
              While it is entirely possible that I’m overlooking something simple, adding that config to the MMM-QuotesFromReddit section of config.js has no effect.
              • Mykle1M
                @Spankythemusical
                My mistake entirely. I thought we were talking about the compliments module.
                in your custom.css file you could try adding this:
                .MMM-QuotesFromReddit thin.xlarge.bright {
                  font-size: 21px;  /* Adjust accordingly */
                  Spankythemusical
                  No problem. I was sure it was something that I was doing wrong. So in my MMM-QuotesFromReddit.js file I added:
                          getStyles: function () {
                                  return ["MMM-QuotesFromReddit.css"];
                  Then I created a MMM-QuotesFromReddit.css file and put in the line that you wrote. Still no change. I’m going to continue messing with it, but any additional help would be unbelievably appreciated.
                  EDIT: I figured it out. I changed the line:
                  wrapper.className = "thin xlarge bright";
                  to:
                  wrapper.className = "small";
                  Works like a charm!
                  B 1 Reply Last reply
                    bthuilot @Spankythemusical
                    @Spankythemusical Hey sorry for the late response, I will make it so that you can change that in the config file soon and not need to edit the js file.
                      Spankythemusical
                      @bthuilot It’s no big deal. I honestly don’t know if the issue I was having was the same for anyone else. Just glad I was able to find a workaround so that I could use your module. Thank you for the work!
                        5M3D1N4 @bthuilot
                        @bthuilot I know this is years later but is this module not available anymore?
                        • bugsounetB bugsounet referenced this topic on
