    MMM-QuotesFromReddit
    magic mirrorquotesrandom
    10 Posts 4 Posters 5.7k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @Spankythemusical
      @Spankythemusical said in MMM-QuotesFromReddit:
      Is there any way to add a css file to control the font size?
      The readme for the compliments module:
      https://github.com/MichMich/MagicMirror/tree/develop/modules/default/compliments
      Configuration options
      classes
      Override the CSS classes of the div showing the compliments
      Default value: thin xlarge bright
        Spankythemusical
        While it is entirely possible that I’m overlooking something simple, adding that config to the MMM-QuotesFromReddit section of config.js has no effect.
          @Spankythemusical
          My mistake entirely. I thought we were talking about the compliments module.
          in your custom.css file you could try adding this:
          .MMM-QuotesFromReddit thin.xlarge.bright {
            font-size: 21px;  /* Adjust accordingly */
            Spankythemusical
            No problem. I was sure it was something that I was doing wrong. So in my MMM-QuotesFromReddit.js file I added:
                    getStyles: function () {
                            return ["MMM-QuotesFromReddit.css"];
            Then I created a MMM-QuotesFromReddit.css file and put in the line that you wrote. Still no change. I’m going to continue messing with it, but any additional help would be unbelievably appreciated.
            EDIT: I figured it out. I changed the line:
            wrapper.className = "thin xlarge bright";
            to:
            wrapper.className = "small";
            Works like a charm!
            bthuilotB 1 Reply Last reply Reply Quote 0
            • bthuilotB Offline
              bthuilot @Spankythemusical
              @Spankythemusical Hey sorry for the late response, I will make it so that you can change that in the config file soon and not need to edit the js file.
                Spankythemusical
                @bthuilot It’s no big deal. I honestly don’t know if the issue I was having was the same for anyone else. Just glad I was able to find a workaround so that I could use your module. Thank you for the work!
                • 5 Offline
                  5M3D1N4 @bthuilot
                  @bthuilot I know this is years later but is this module not available anymore?
                  • bugsounetB bugsounet referenced this topic on
