    MMM-QuotesFromReddit
    magic mirrorquotesrandom
    10 Posts 4 Posters 5.5k Views 4 Watching
      Spankythemusical
      While it is entirely possible that I’m overlooking something simple, adding that config to the MMM-QuotesFromReddit section of config.js has no effect.
        Mykle1 Project Sponsor Module Developer @Spankythemusical
        @Spankythemusical
        My mistake entirely. I thought we were talking about the compliments module.
        in your custom.css file you could try adding this:
        .MMM-QuotesFromReddit thin.xlarge.bright {
          font-size: 21px;  /* Adjust accordingly */
          Spankythemusical
          No problem. I was sure it was something that I was doing wrong. So in my MMM-QuotesFromReddit.js file I added:
                  getStyles: function () {
                          return ["MMM-QuotesFromReddit.css"];
          Then I created a MMM-QuotesFromReddit.css file and put in the line that you wrote. Still no change. I’m going to continue messing with it, but any additional help would be unbelievably appreciated.
          EDIT: I figured it out. I changed the line:
          wrapper.className = "thin xlarge bright";
          to:
          wrapper.className = "small";
          Works like a charm!
          bthuilotB 1 Reply Last reply Reply Quote 0
          • bthuilotB Offline
            bthuilot @Spankythemusical
            @Spankythemusical Hey sorry for the late response, I will make it so that you can change that in the config file soon and not need to edit the js file.
              Spankythemusical
              @bthuilot It’s no big deal. I honestly don’t know if the issue I was having was the same for anyone else. Just glad I was able to find a workaround so that I could use your module. Thank you for the work!
              • 5 Offline
                5M3D1N4 @bthuilot
                @bthuilot I know this is years later but is this module not available anymore?
                • bugsounetB bugsounet referenced this topic on
