MMM-QuotesFromReddit
magic mirrorquotesrandom
10 Posts 4 Posters 4.8k Views 4 Watching
    bthuilot
    Description
    Picks a random post from /r/quotes and displays the title meaning a random supply of quotes! Ideally meant to replace the compliments module.
    Download
    [card:bthuilot/MMM-QuotesFromReddit]
    M 5 2 Replies Last reply Jul 12, 2017, 11:48 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @bthuilot
      @bthuilot said in MMM-QuotesFromReddit:
      Blasphemy! ;-)
        Spankythemusical
        Is there any way to add a css file to control the font size? While this is an unbelievably wonderful module, the quotes come in so large that it sometimes takes up half the screen.
        M 1 Reply Last reply Jul 18, 2017, 10:30 AM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @Spankythemusical
          @Spankythemusical said in MMM-QuotesFromReddit:
          The readme for the compliments module:
          https://github.com/MichMich/MagicMirror/tree/develop/modules/default/compliments
          Configuration options
          classes
          Override the CSS classes of the div showing the compliments
          Default value: thin xlarge bright
            Spankythemusical
            While it is entirely possible that I’m overlooking something simple, adding that config to the MMM-QuotesFromReddit section of config.js has no effect.
            M 1 Reply Last reply Jul 18, 2017, 11:59 AM Reply Quote 0
              @Spankythemusical
              My mistake entirely. I thought we were talking about the compliments module.
              in your custom.css file you could try adding this:
              .MMM-QuotesFromReddit thin.xlarge.bright {
                font-size: 21px;  /* Adjust accordingly */
                Spankythemusical
                No problem. I was sure it was something that I was doing wrong. So in my MMM-QuotesFromReddit.js file I added:
                        getStyles: function () {
                                return ["MMM-QuotesFromReddit.css"];
                Then I created a MMM-QuotesFromReddit.css file and put in the line that you wrote. Still no change. I’m going to continue messing with it, but any additional help would be unbelievably appreciated.
                EDIT: I figured it out. I changed the line:
                wrapper.className = "thin xlarge bright";
                to:
                wrapper.className = "small";
                Works like a charm!
                B 1 Reply Last reply Jul 18, 2017, 1:57 PM Reply Quote 0
                  bthuilot @Spankythemusical
                  @Spankythemusical Hey sorry for the late response, I will make it so that you can change that in the config file soon and not need to edit the js file.
                    Spankythemusical
                    @bthuilot It’s no big deal. I honestly don’t know if the issue I was having was the same for anyone else. Just glad I was able to find a workaround so that I could use your module. Thank you for the work!
                    • 5 Offline
                      5M3D1N4 @bthuilot
                      @bthuilot I know this is years later but is this module not available anymore?
                      • B bugsounet referenced this topic on Mar 31, 2024, 10:24 AM
