    Internet Monitor
    108 Posts 27 Posters 168.4k Views 30 Watching
    • Mykle1M
      I played with this module the better part of this afternoon and it crashed my MM every time. I tried different positions, verbose and minimal, indicator enabled and not, maxTime I left at default (20000) with updateInterval ranging from 40000 -100000. displayStrength on and off and displaySpeed on and off. I gave up before changing anything in strengthIconSize and maxGaugeScale. Each time it would try to load and then freeze and lock up MM, forcing me to switch the power off because MM could unresponsive and could not be quit. Upon restarting, I would have to quickly run VNC, open the terminal and “pm2 stop mm” before it would launch again and crash again.
      I really love the idea of this module and I would like to have it on my mirror. Any ideas?
      Pi 3, Jessie
      • cowboysdudeC
        @Mykle1 I’ll try it on mine… I’ll let you know what happens… I mean mine is pretty much setup like yours [layout wise :)]…
        Ok put in my mirror [I was just using in my dev at first] …
        It makes things load slower but it does load…
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @cowboysdude said in Internet Monitor:
          Hmm, well, it’s not happening for me. I want it so bad that I invested a lot of time with it today, but to no avail.
          You’re just using the defaults? Because those didn’t work for me either, right from the get go.
          R 1 Reply Last reply
            ronny3050 Module Developer @Mykle1
            @Mykle1 It’s strange that it’s not loading at all and @cowboysdude thank you for your kind words, but I am upset that it is loading slow now. I could try and optimize a little and check with you, if that’s okay?
            @Mykle1 could you post pm2 logs?
            Mykle1M cowboysdudeC 2 Replies Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @ronny3050
              @ronny3050 said in Internet Monitor:
              I could, if I knew how. I hope it doesn’t involve trying to run the module again. :-/ Please advise
              • cowboysdudeC
                cowboysdude Module Developer @ronny3050
                @ronny3050 I don’t think it’s your module … I honestly believe that everything I’m loading is coming from an outside source as well so again I don’t believe it’s strictly your module :) I just think my mirror is away from my router and it takes a minute to shoot the info back [Ie news module, horoscope, globe data, weather]… :)
                • cowboysdudeC
                  @Mykle1 You could run it without he module to see what happens. I tell you what I’d do before I tried it again… backup my sd card :)
                  The only thing I’m not loading that you are is the plantrise stuff didn’t need it… but other than that we are running almost identical.
                  Mykle1M 2 Replies Last reply
                  • Mykle1M
                    My mirror runs perfectly without the internet-monitor. It is only when I introduce that to my setup that things go south. Of course we’re running almost identical, you’re using my config. ;-) My project for today is backup my SD card so thanks for that suggestion.
                    If someone would tell me how to find the pm2 logs I will post them
                    cowboysdudeC M 2 Replies Last reply
                    • cowboysdudeC
                      @Mykle1 I think they are here if I’m not mistaken:
                      /root/.pm2/logs/
                      • Mykle1M
                        /root/.pm2/logs/
                        Thanks bro, I’ll look into that in a little while
                          Mar @Mykle1
                          @Mykle1 As I posted up above, seems like others are having the same issue. I noticed that in the logs the internet monitor is posting the speed every few seconds so I was thinking this was a probably cause?
                          Though the amount of slowdown just to show the wifi indicator was a little too much
                          • Mykle1M
                            /root/.pm2/logs/
                            when I try cd root it says permission denied. I tried sudo cd root and it said bad command.
                            So, how do I get to the logs so I can post them?
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Mar
                              @Mar said in Internet Monitor:
                              My problem isn’t slowdown, it’s crashing my MM2 (see previous post) so I’m trying to get the the logs so I can post them and perhaps get a fix. Also, I’m on a Pi3
                                @Mykle1 run pm2 logs from the terminal.
                                • Mykle1M
                                  • Mykle1M
                                    @ronny3050 - this is what I got when I ran pm2 logs
                                    [TAILING] Tailing last 10 lines for [all] processes (change the value with --lines option)
                                    /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                                    0|mm       | npm ERR!     npm bugs magicmirror
                                    0|mm       | npm ERR! Or if that isn't available, you can get their info via:
                                    0|mm       | npm ERR!     npm owner ls magicmirror
                                    0|mm       | npm ERR! There is likely additional logging output above.
                                    0|mm       |
                                    0|mm       | npm ERR! Please include the following file with any support request:
                                    0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                    0|mm       | ERROR! Could not find main module js file.
                                    /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
                                    0|mm       | Starting module: newsfeed
                                    0|mm       | Sockets connected & modules started ...
                                    0|mm       | Launching application.
                                    0|mm       | Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                                    0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/themykle%40themykle.com/private-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX/basic.ics - Interval: 300000
                                    0|mm       | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                    0|mm       |
                                    0|mm       | > magicmirror@2.1.0 start /home/pi/MagicMirror
                                    0|mm       | > electron js/electron.js
                                    0|mm       |
                                    [STREAMING] Now streaming realtime logs for [all] processes
                                      @Mykle1 Could you run the following?
                                      pm2 flush
                                      pm2 logs and wait for a couple of minutes of log?
                                      Thanks!
                                      • Mykle1M
                                        @ronny3050 wait for it to complete doing something? Will it stop by itself or I have to do something?
                                        If so, what do I have to do?
                                        It’s running now
                                          @Mykle1 yes, after typing pm2 logs it will update logs realtime so then you can post it here. I am wondering what exactly crashes your mirror inside my module.
                                          • Mykle1M
                                            @ronny3050 ok, I’m waiting for it to complete
                                            • 2 / 6
