    Internet Monitor
    108 Posts 27 Posters 168.1k Views 30 Watching
      ronny3050 Module Developer @Mykle1
      @Mykle1 It’s strange that it’s not loading at all and @cowboysdude thank you for your kind words, but I am upset that it is loading slow now. I could try and optimize a little and check with you, if that’s okay?
      @Mykle1 could you post pm2 logs?
      Mykle1M cowboysdudeC 2 Replies Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @ronny3050
        @ronny3050 said in Internet Monitor:
        I could, if I knew how. I hope it doesn’t involve trying to run the module again. :-/ Please advise
        • cowboysdudeC
          cowboysdude Module Developer @ronny3050
          @ronny3050 I don’t think it’s your module … I honestly believe that everything I’m loading is coming from an outside source as well so again I don’t believe it’s strictly your module :) I just think my mirror is away from my router and it takes a minute to shoot the info back [Ie news module, horoscope, globe data, weather]… :)
          • cowboysdudeC
            @Mykle1 You could run it without he module to see what happens. I tell you what I’d do before I tried it again… backup my sd card :)
            The only thing I’m not loading that you are is the plantrise stuff didn’t need it… but other than that we are running almost identical.
            Mykle1M 2 Replies Last reply
            • Mykle1M
              @cowboysdude said in Internet Monitor:
              My mirror runs perfectly without the internet-monitor. It is only when I introduce that to my setup that things go south. Of course we’re running almost identical, you’re using my config. ;-) My project for today is backup my SD card so thanks for that suggestion.
              If someone would tell me how to find the pm2 logs I will post them
              cowboysdudeC M 2 Replies Last reply
              • cowboysdudeC
                @Mykle1 I think they are here if I’m not mistaken:
                /root/.pm2/logs/
                • Mykle1M
                  /root/.pm2/logs/
                  Thanks bro, I’ll look into that in a little while
                    Mar @Mykle1
                    @Mykle1 As I posted up above, seems like others are having the same issue. I noticed that in the logs the internet monitor is posting the speed every few seconds so I was thinking this was a probably cause?
                    Though the amount of slowdown just to show the wifi indicator was a little too much
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      /root/.pm2/logs/
                      when I try cd root it says permission denied. I tried sudo cd root and it said bad command.
                      So, how do I get to the logs so I can post them?
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Mar
                        @Mar said in Internet Monitor:
                        My problem isn’t slowdown, it’s crashing my MM2 (see previous post) so I’m trying to get the the logs so I can post them and perhaps get a fix. Also, I’m on a Pi3
                          @Mykle1 run pm2 logs from the terminal.
                          • Mykle1M
                            • Mykle1M
                              @ronny3050 - this is what I got when I ran pm2 logs
                              [TAILING] Tailing last 10 lines for [all] processes (change the value with --lines option)
                              /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                              0|mm       | npm ERR!     npm bugs magicmirror
                              0|mm       | npm ERR! Or if that isn't available, you can get their info via:
                              0|mm       | npm ERR!     npm owner ls magicmirror
                              0|mm       | npm ERR! There is likely additional logging output above.
                              0|mm       |
                              0|mm       | npm ERR! Please include the following file with any support request:
                              0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                              0|mm       | ERROR! Could not find main module js file.
                              /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
                              0|mm       | Starting module: newsfeed
                              0|mm       | Sockets connected & modules started ...
                              0|mm       | Launching application.
                              0|mm       | Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                              0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/themykle%40themykle.com/private-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX/basic.ics - Interval: 300000
                              0|mm       | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                              0|mm       |
                              0|mm       | > magicmirror@2.1.0 start /home/pi/MagicMirror
                              0|mm       | > electron js/electron.js
                              0|mm       |
                              [STREAMING] Now streaming realtime logs for [all] processes
                              R 1 Reply Last reply
                                @Mykle1 Could you run the following?
                                pm2 flush
                                pm2 logs and wait for a couple of minutes of log?
                                Thanks!
                                • Mykle1M
                                  @ronny3050 wait for it to complete doing something? Will it stop by itself or I have to do something?
                                  If so, what do I have to do?
                                  It’s running now
                                    @Mykle1 yes, after typing pm2 logs it will update logs realtime so then you can post it here. I am wondering what exactly crashes your mirror inside my module.
                                    • Mykle1M
                                      @ronny3050 ok, I’m waiting for it to complete
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @Mykle1
                                        I’ve been waiting for 34 minutes and nothing has happened. My console still reads:
                                        [STREAMING] Now streaming realtime logs for [all] processes.
                                        Am I supposed to do something? run MM with your module perhaps? You didn’t say
                                        • Mykle1M
                                          Well, I waited over and hour, staring at the console, and nothing happened since I ran:
                                          pm2 flush
                                          pm2 logs
                                          Here is what I’ve been staring at:
                                          pi@Pi3:~ $ pm2 flush
                                          [PM2] Flushing /home/pi/.pm2/pm2.log
                                          [PM2] Flushing
                                          [PM2] /home/pi/.pm2/logs/mm-out-0.log
                                          [PM2] /home/pi/.pm2/logs/mm-error-0.log
                                          [PM2] Logs flushed
                                          pi@Pi3:~ $ pm2 logs
                                          /home/pi/.pm2/pm2.log last 10 lines:
                                          • Mykle1M
                                            Done. I made two backups of my SD card. One locally and one on my backup server. While that was going on I installed a fan on my Pi. I have spare parts lying around. Good little mini project while I waited for the backups. Now my Pi runs at 35 C, down from 60 C. Sweet.
                                            • 2 / 6
