    Internet Monitor
    108 Posts 27 Posters 168.4k Views 30 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @ronny3050
      @ronny3050 said in Internet Monitor:
      @Mykle1 could you post pm2 logs?
      I could, if I knew how. I hope it doesn’t involve trying to run the module again. :-/ Please advise
      • cowboysdudeC
        cowboysdude Module Developer @ronny3050
        @ronny3050 I don’t think it’s your module … I honestly believe that everything I’m loading is coming from an outside source as well so again I don’t believe it’s strictly your module :) I just think my mirror is away from my router and it takes a minute to shoot the info back [Ie news module, horoscope, globe data, weather]… :)
        • cowboysdudeC
          @Mykle1 You could run it without he module to see what happens. I tell you what I’d do before I tried it again… backup my sd card :)
          The only thing I’m not loading that you are is the plantrise stuff didn’t need it… but other than that we are running almost identical.
          Mykle1M 2 Replies Last reply
          • Mykle1M
            @cowboysdude said in Internet Monitor:
            My mirror runs perfectly without the internet-monitor. It is only when I introduce that to my setup that things go south. Of course we’re running almost identical, you’re using my config. ;-) My project for today is backup my SD card so thanks for that suggestion.
            If someone would tell me how to find the pm2 logs I will post them
            cowboysdudeC M 2 Replies Last reply
            • cowboysdudeC
              @Mykle1 I think they are here if I’m not mistaken:
              /root/.pm2/logs/
              • Mykle1M
                /root/.pm2/logs/
                Thanks bro, I’ll look into that in a little while
                  Mar @Mykle1
                  @Mykle1 As I posted up above, seems like others are having the same issue. I noticed that in the logs the internet monitor is posting the speed every few seconds so I was thinking this was a probably cause?
                  Though the amount of slowdown just to show the wifi indicator was a little too much
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    /root/.pm2/logs/
                    when I try cd root it says permission denied. I tried sudo cd root and it said bad command.
                    So, how do I get to the logs so I can post them?
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @Mar
                      @Mar said in Internet Monitor:
                      My problem isn’t slowdown, it’s crashing my MM2 (see previous post) so I’m trying to get the the logs so I can post them and perhaps get a fix. Also, I’m on a Pi3
                        ronny3050 Module Developer
                        @Mykle1 run pm2 logs from the terminal.
                        • Mykle1M
                          • Mykle1M
                            @ronny3050 - this is what I got when I ran pm2 logs
                            [TAILING] Tailing last 10 lines for [all] processes (change the value with --lines option)
                            /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                            0|mm       | npm ERR!     npm bugs magicmirror
                            0|mm       | npm ERR! Or if that isn't available, you can get their info via:
                            0|mm       | npm ERR!     npm owner ls magicmirror
                            0|mm       | npm ERR! There is likely additional logging output above.
                            0|mm       |
                            0|mm       | npm ERR! Please include the following file with any support request:
                            0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                            0|mm       | ERROR! Could not find main module js file.
                            /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
                            0|mm       | Starting module: newsfeed
                            0|mm       | Sockets connected & modules started ...
                            0|mm       | Launching application.
                            0|mm       | Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                            0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/themykle%40themykle.com/private-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX/basic.ics - Interval: 300000
                            0|mm       | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                            0|mm       |
                            0|mm       | > magicmirror@2.1.0 start /home/pi/MagicMirror
                            0|mm       | > electron js/electron.js
                            0|mm       |
                            [STREAMING] Now streaming realtime logs for [all] processes
                            R 1 Reply Last reply
                              ronny3050 Module Developer @Mykle1
                              @Mykle1 Could you run the following?
                              pm2 flush
                              pm2 logs and wait for a couple of minutes of log?
                              Thanks!
                              • Mykle1M
                                @ronny3050 wait for it to complete doing something? Will it stop by itself or I have to do something?
                                If so, what do I have to do?
                                It’s running now
                                  @Mykle1 yes, after typing pm2 logs it will update logs realtime so then you can post it here. I am wondering what exactly crashes your mirror inside my module.
                                  • Mykle1M
                                    @ronny3050 ok, I’m waiting for it to complete
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Mykle1
                                      I’ve been waiting for 34 minutes and nothing has happened. My console still reads:
                                      [STREAMING] Now streaming realtime logs for [all] processes.
                                      Am I supposed to do something? run MM with your module perhaps? You didn’t say
                                      • Mykle1M
                                        Well, I waited over and hour, staring at the console, and nothing happened since I ran:
                                        pm2 flush
                                        pm2 logs
                                        Here is what I’ve been staring at:
                                        pi@Pi3:~ $ pm2 flush
                                        [PM2] Flushing /home/pi/.pm2/pm2.log
                                        [PM2] Flushing
                                        [PM2] /home/pi/.pm2/logs/mm-out-0.log
                                        [PM2] /home/pi/.pm2/logs/mm-error-0.log
                                        [PM2] Logs flushed
                                        pi@Pi3:~ $ pm2 logs
                                        /home/pi/.pm2/pm2.log last 10 lines:
                                        • Mykle1M
                                          Done. I made two backups of my SD card. One locally and one on my backup server. While that was going on I installed a fan on my Pi. I have spare parts lying around. Good little mini project while I waited for the backups. Now my Pi runs at 35 C, down from 60 C. Sweet.
                                          • cowboysdudeC
                                            @Mykle1 That’s a great idea that I should probably do as well… adding the fan!!!
                                            • 2 / 6
