    Internet Monitor
    108 Posts 27 Posters 168.4k Views 30 Watching
    • cowboysdudeC
      @Mykle1 I think they are here if I’m not mistaken:
      /root/.pm2/logs/
      Mykle1M 2 Replies Last reply
      • Mykle1M
        @cowboysdude said in Internet Monitor:
        /root/.pm2/logs/
        Thanks bro, I’ll look into that in a little while
          Mar @Mykle1
          @Mykle1 As I posted up above, seems like others are having the same issue. I noticed that in the logs the internet monitor is posting the speed every few seconds so I was thinking this was a probably cause?
          Though the amount of slowdown just to show the wifi indicator was a little too much
          Mykle1M 1 Reply Last reply
          • Mykle1M
            /root/.pm2/logs/
            when I try cd root it says permission denied. I tried sudo cd root and it said bad command.
            So, how do I get to the logs so I can post them?
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Mar
              @Mar said in Internet Monitor:
              My problem isn’t slowdown, it’s crashing my MM2 (see previous post) so I’m trying to get the the logs so I can post them and perhaps get a fix. Also, I’m on a Pi3
                ronny3050 Module Developer
                @Mykle1 run pm2 logs from the terminal.
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @ronny3050
                  • Mykle1M
                    @ronny3050 - this is what I got when I ran pm2 logs
                    [TAILING] Tailing last 10 lines for [all] processes (change the value with --lines option)
                    /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                    0|mm       | npm ERR!     npm bugs magicmirror
                    0|mm       | npm ERR! Or if that isn't available, you can get their info via:
                    0|mm       | npm ERR!     npm owner ls magicmirror
                    0|mm       | npm ERR! There is likely additional logging output above.
                    0|mm       |
                    0|mm       | npm ERR! Please include the following file with any support request:
                    0|mm       | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                    0|mm       | ERROR! Could not find main module js file.
                    /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
                    0|mm       | Starting module: newsfeed
                    0|mm       | Sockets connected & modules started ...
                    0|mm       | Launching application.
                    0|mm       | Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                    0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/themykle%40themykle.com/private-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX/basic.ics - Interval: 300000
                    0|mm       | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    0|mm       |
                    0|mm       | > magicmirror@2.1.0 start /home/pi/MagicMirror
                    0|mm       | > electron js/electron.js
                    0|mm       |
                    [STREAMING] Now streaming realtime logs for [all] processes
                    R 1 Reply Last reply
                      ronny3050 Module Developer @Mykle1
                      @Mykle1 Could you run the following?
                      pm2 flush
                      pm2 logs and wait for a couple of minutes of log?
                      Thanks!
                      • Mykle1M
                        @ronny3050 wait for it to complete doing something? Will it stop by itself or I have to do something?
                        If so, what do I have to do?
                        It’s running now
                          @Mykle1 yes, after typing pm2 logs it will update logs realtime so then you can post it here. I am wondering what exactly crashes your mirror inside my module.
                          • Mykle1M
                            @ronny3050 ok, I’m waiting for it to complete
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Mykle1
                              I’ve been waiting for 34 minutes and nothing has happened. My console still reads:
                              [STREAMING] Now streaming realtime logs for [all] processes.
                              Am I supposed to do something? run MM with your module perhaps? You didn’t say
                              • Mykle1M
                                Well, I waited over and hour, staring at the console, and nothing happened since I ran:
                                pm2 flush
                                pm2 logs
                                Here is what I’ve been staring at:
                                pi@Pi3:~ $ pm2 flush
                                [PM2] Flushing /home/pi/.pm2/pm2.log
                                [PM2] Flushing
                                [PM2] /home/pi/.pm2/logs/mm-out-0.log
                                [PM2] /home/pi/.pm2/logs/mm-error-0.log
                                [PM2] Logs flushed
                                pi@Pi3:~ $ pm2 logs
                                /home/pi/.pm2/pm2.log last 10 lines:
                                • Mykle1M
                                  I tell you what I’d do before I tried it again… backup my sd card
                                  Done. I made two backups of my SD card. One locally and one on my backup server. While that was going on I installed a fan on my Pi. I have spare parts lying around. Good little mini project while I waited for the backups. Now my Pi runs at 35 C, down from 60 C. Sweet.
                                  • cowboysdudeC
                                    @Mykle1 That’s a great idea that I should probably do as well… adding the fan!!!
                                    • pjkoelemanP
                                      pjkoeleman
                                      @Mykle1 said in Internet Monitor:
                                      @ronny3050 thanks for a nice Monitor, i love the wifi indicator.
                                      You asked for wishes for the Internet Monitor.
                                      I have been looking in the code if it is possible to give te wifi indicators some color.
                                      Making strength_full.png green, strength_almost yellow, strength_half orange and strength_non.png red. Would love to see this as an config option of in the my custom.css.
                                      Is there a way to do this?
                                      A 1 Reply Last reply
                                      • A
                                        Advokaten @pjkoeleman
                                        @pjkoeleman is this module working for you? I can’t get it to work :(
                                        pjkoelemanP 1 Reply Last reply
                                        • pjkoelemanP
                                          pjkoeleman @Advokaten
                                          @Advokaten Yes it’s just working as discribed. Here is my part off config.js for the Internet Monitor.
                                            Module: 'internet-monitor',
                                            position: 'bottom_right',
                                              type: 'minimal',
                                              maxTime: 10000,
                                              updateInterval: 120000,
                                              verbose: false,
                                              displayStrength: true,
                                              displaySpeed: false,
                                              strengthIconSize: 40,
                                              maxGaugeScale: 25
                                          Now I want to bring a little color to the wifi indicator.
                                          • A
                                            @pjkoeleman Thank you! Using your config lines made it work somehow! I am too interested in changing color of the wi-fi strength png’s. I tried changing all the white levelColors without success. Don’t know what is turning the strength bars into a white color :( Anybody who could help us out? Thanks.
                                            R pjkoelemanP 2 Replies Last reply
                                            • 2 / 6
