    Internet Monitor
    108 Posts 27 Posters 168.4k Views 30 Watching
      ronny3050 Module Developer @Mykle1
      @Mykle1 yes, after typing pm2 logs it will update logs realtime so then you can post it here. I am wondering what exactly crashes your mirror inside my module.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @ronny3050
        @ronny3050 ok, I’m waiting for it to complete
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Mykle1
          I’ve been waiting for 34 minutes and nothing has happened. My console still reads:
          [STREAMING] Now streaming realtime logs for [all] processes.
          Am I supposed to do something? run MM with your module perhaps? You didn’t say
          • Mykle1M
            Well, I waited over and hour, staring at the console, and nothing happened since I ran:
            pm2 flush
            pm2 logs
            Here is what I’ve been staring at:
            pi@Pi3:~ $ pm2 flush
            [PM2] Flushing /home/pi/.pm2/pm2.log
            [PM2] Flushing
            [PM2] /home/pi/.pm2/logs/mm-out-0.log
            [PM2] /home/pi/.pm2/logs/mm-error-0.log
            [PM2] Logs flushed
            pi@Pi3:~ $ pm2 logs
            [TAILING] Tailing last 10 lines for [all] processes (change the value with --lines option)
            /home/pi/.pm2/pm2.log last 10 lines:
            /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
            /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
            • Mykle1M
              @cowboysdude said in Internet Monitor:
              I tell you what I’d do before I tried it again… backup my sd card
              Done. I made two backups of my SD card. One locally and one on my backup server. While that was going on I installed a fan on my Pi. I have spare parts lying around. Good little mini project while I waited for the backups. Now my Pi runs at 35 C, down from 60 C. Sweet.
              • cowboysdudeC
                @Mykle1 That’s a great idea that I should probably do as well… adding the fan!!!
                • pjkoelemanP
                  pjkoeleman
                  @Mykle1 said in Internet Monitor:
                  @ronny3050 thanks for a nice Monitor, i love the wifi indicator.
                  You asked for wishes for the Internet Monitor.
                  I have been looking in the code if it is possible to give te wifi indicators some color.
                  Making strength_full.png green, strength_almost yellow, strength_half orange and strength_non.png red. Would love to see this as an config option of in the my custom.css.
                  Is there a way to do this?
                  A 1 Reply Last reply
                  • A
                    Advokaten @pjkoeleman
                    @pjkoeleman is this module working for you? I can’t get it to work :(
                    pjkoelemanP 1 Reply Last reply
                    • pjkoelemanP
                      pjkoeleman @Advokaten
                      @Advokaten Yes it’s just working as discribed. Here is my part off config.js for the Internet Monitor.
                        Module: 'internet-monitor',
                        position: 'bottom_right',
                          type: 'minimal',
                          maxTime: 10000,
                          updateInterval: 120000,
                          verbose: false,
                          displayStrength: true,
                          displaySpeed: false,
                          strengthIconSize: 40,
                          maxGaugeScale: 25
                      Now I want to bring a little color to the wifi indicator.
                      • A
                        @pjkoeleman Thank you! Using your config lines made it work somehow! I am too interested in changing color of the wi-fi strength png’s. I tried changing all the white levelColors without success. Don’t know what is turning the strength bars into a white color :( Anybody who could help us out? Thanks.
                        R pjkoelemanP 2 Replies Last reply
                          ronny3050 Module Developer @Advokaten
                          @pjkoeleman @Advokaten try changing type in config to type: '' from type: 'minimal'.
                          Also, thank you for the kind words! :)
                          • A
                            Advokaten @ronny3050
                            @ronny3050 I’m sorry. I don’t understand if this made any difference other than it took some extra time to load the indicator. Is there a way to change colors in the css file now or what…? Sorry once more for being such a nublet and thank you for taking your time to do stuff like this!
                            R 1 Reply Last reply
                              @Advokaten @pjkoeleman Silly me, I am sorry, I thought you requested colors for the speed gauges, which are already there. As for colors for the wifi strength indicator, there are two ways:
                              1. CSS coloring (you have complete control over the colors)
                              2. Pre-made images with different colors (colors chosen by me).
                              I am sure 1 would be preferred. I will get back to you in a little bit with my progress on this. Thank you very much for suggesting this.
                              A pjkoelemanP 2 Replies Last reply
                              Reply Quote 2
                              • cowboysdudeC
                                Yes #1 preferred ;)
                                  ronny3050 Module Developer @cowboysdude
                                  @cowboysdude Usually preferred = harder ;)
                                  cowboysdudeC strawberry 3.141S 2 Replies Last reply
                                  • cowboysdudeC
                                    cowboysdude Module Developer @ronny3050
                                    @ronny3050 said in Internet Monitor:
                                    LOL yeah me too but for once thought I’d go the easier route…
                                    • A
                                      @ronny3050 Option 1 would be quite amazing, yes! Another question, would it be possible to remove everything in the module except for the wi-fi indicator part, to make it smaller and quicker (maybe easier to configure for nubs like me)? Like remove all unnecessary files and coding. I’m afraid I’ll break it if I tinker with it lol.
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @ronny3050
                                        @ronny3050 you could achieve this with css3 filters
                                        R cowboysdudeC 2 Replies Last reply
                                        Reply Quote 3
                                          @Advokaten sure, I’ll clean it up :)
                                            ronny3050 Module Developer @strawberry 3.141
                                            @strawberry-3.141 Hey bro, thanks for the heads up! I was going to go that route except not sure whether everyone’s raspberry browser supports css3.
                                            Reply Quote 2
                                            • 2 / 6
