    Internet Monitor
    108 Posts 27 Posters 166.4k Views 30 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Mykle1
      I’ve been waiting for 34 minutes and nothing has happened. My console still reads:
      [STREAMING] Now streaming realtime logs for [all] processes.
      Am I supposed to do something? run MM with your module perhaps? You didn’t say
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Well, I waited over and hour, staring at the console, and nothing happened since I ran:
        pm2 flush
        pm2 logs
        Here is what I’ve been staring at:
        pi@Pi3:~ $ pm2 flush
        [PM2] Flushing /home/pi/.pm2/pm2.log
        [PM2] Flushing
        [PM2] /home/pi/.pm2/logs/mm-out-0.log
        [PM2] /home/pi/.pm2/logs/mm-error-0.log
        [PM2] Logs flushed
        pi@Pi3:~ $ pm2 logs
        [TAILING] Tailing last 10 lines for [all] processes (change the value with --lines option)
        /home/pi/.pm2/pm2.log last 10 lines:
        /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
        /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
        • Mykle1M
          @cowboysdude said in Internet Monitor:
          I tell you what I’d do before I tried it again… backup my sd card
          Done. I made two backups of my SD card. One locally and one on my backup server. While that was going on I installed a fan on my Pi. I have spare parts lying around. Good little mini project while I waited for the backups. Now my Pi runs at 35 C, down from 60 C. Sweet.
          • cowboysdudeC
            @Mykle1 That’s a great idea that I should probably do as well… adding the fan!!!
              pjkoeleman
              @Mykle1 said in Internet Monitor:
              @ronny3050 thanks for a nice Monitor, i love the wifi indicator.
              You asked for wishes for the Internet Monitor.
              I have been looking in the code if it is possible to give te wifi indicators some color.
              Making strength_full.png green, strength_almost yellow, strength_half orange and strength_non.png red. Would love to see this as an config option of in the my custom.css.
              Is there a way to do this?
              A 1 Reply Last reply
              • A
                Advokaten @pjkoeleman
                @pjkoeleman is this module working for you? I can’t get it to work :(
                P 1 Reply Last reply
                  pjkoeleman @Advokaten
                  @Advokaten Yes it’s just working as discribed. Here is my part off config.js for the Internet Monitor.
                    Module: 'internet-monitor',
                    position: 'bottom_right',
                      type: 'minimal',
                      maxTime: 10000,
                      updateInterval: 120000,
                      verbose: false,
                      displayStrength: true,
                      displaySpeed: false,
                      strengthIconSize: 40,
                      maxGaugeScale: 25
                  Now I want to bring a little color to the wifi indicator.
                  • A
                    @pjkoeleman Thank you! Using your config lines made it work somehow! I am too interested in changing color of the wi-fi strength png’s. I tried changing all the white levelColors without success. Don’t know what is turning the strength bars into a white color :( Anybody who could help us out? Thanks.
                    R P 2 Replies Last reply
                      ronny3050 Module Developer @Advokaten
                      @pjkoeleman @Advokaten try changing type in config to type: '' from type: 'minimal'.
                      Also, thank you for the kind words! :)
                      • A
                        Advokaten @ronny3050
                        @ronny3050 I’m sorry. I don’t understand if this made any difference other than it took some extra time to load the indicator. Is there a way to change colors in the css file now or what…? Sorry once more for being such a nublet and thank you for taking your time to do stuff like this!
                        R 1 Reply Last reply
                          @Advokaten @pjkoeleman Silly me, I am sorry, I thought you requested colors for the speed gauges, which are already there. As for colors for the wifi strength indicator, there are two ways:
                          1. CSS coloring (you have complete control over the colors)
                          2. Pre-made images with different colors (colors chosen by me).
                          I am sure 1 would be preferred. I will get back to you in a little bit with my progress on this. Thank you very much for suggesting this.
                          A P 2 Replies Last reply
                          Reply Quote 2
                          • cowboysdudeC
                            Yes #1 preferred ;)
                              ronny3050 Module Developer @cowboysdude
                              @cowboysdude Usually preferred = harder ;)
                              cowboysdudeC strawberry 3.141S 2 Replies Last reply
                              • cowboysdudeC
                                cowboysdude Module Developer @ronny3050
                                @ronny3050 said in Internet Monitor:
                                LOL yeah me too but for once thought I’d go the easier route…
                                • A
                                  @ronny3050 Option 1 would be quite amazing, yes! Another question, would it be possible to remove everything in the module except for the wi-fi indicator part, to make it smaller and quicker (maybe easier to configure for nubs like me)? Like remove all unnecessary files and coding. I’m afraid I’ll break it if I tinker with it lol.
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @ronny3050
                                    @ronny3050 you could achieve this with css3 filters
                                    R cowboysdudeC 2 Replies Last reply
                                    Reply Quote 3
                                      @Advokaten sure, I’ll clean it up :)
                                        ronny3050 Module Developer @strawberry 3.141
                                        @strawberry-3.141 Hey bro, thanks for the heads up! I was going to go that route except not sure whether everyone’s raspberry browser supports css3.
                                        Reply Quote 2
                                        • cowboysdudeC
                                          cowboysdude Module Developer @strawberry 3.141
                                          @strawberry-3.141 said in Internet Monitor:
                                          I swear to God I’m calling you “Magic Man”… :)
                                            pjkoeleman @ronny3050
                                            @ronny3050 Thanks for taking up the challenge.
                                            I would prefer option #1 as well. So the user can choose its own colors.
                                            Reply Quote 2
                                            • 3 / 6
