    Internet Monitor
    108 Posts 27 Posters 159.9k Views 30 Watching
      plumcraft
      Great module :)
        ronny3050 Module Developer @plumcraft
        @plumcraft thank you! :)
        • MichMichM Offline
          MichMich
          Love it! Especially the wifi connection indicator!
            ronny3050 Module Developer @MichMich
            @MichMich Thank you so much! It exists all because of what you started :)
              shashank @ronny3050
              @ronny3050 Module works great!, can the display speed graph resize
                ronny3050 Module Developer @shashank
                @shashank Thank you @shashank ! :D
                  Mar
                  Ive done quite a bit of testing and on the Zero this module really slows down my startup, and seems to cause a few other modules trying to connect to the internet to take forever to load, or timeout (i.e TubeStatus). Increases my startup from less than a minute to a few minutes. Im not really sure why, but as soon as i disable everything goes back to being smooth.
                  • cowboysdudeC Offline
                    Really nice!! Now I can put just the indicator on my mirror and it’s a great way to make sure you’re connected!!! Thanks!!
                      I played with this module the better part of this afternoon and it crashed my MM every time. I tried different positions, verbose and minimal, indicator enabled and not, maxTime I left at default (20000) with updateInterval ranging from 40000 -100000. displayStrength on and off and displaySpeed on and off. I gave up before changing anything in strengthIconSize and maxGaugeScale. Each time it would try to load and then freeze and lock up MM, forcing me to switch the power off because MM could unresponsive and could not be quit. Upon restarting, I would have to quickly run VNC, open the terminal and “pm2 stop mm” before it would launch again and crash again.
                      I really love the idea of this module and I would like to have it on my mirror. Any ideas?
                      Pi 3, Jessie
                        @Mykle1 I’ll try it on mine… I’ll let you know what happens… I mean mine is pretty much setup like yours [layout wise :)]…
                        Ok put in my mirror [I was just using in my dev at first] …
                        It makes things load slower but it does load…
                          @cowboysdude said in Internet Monitor:
                          Hmm, well, it’s not happening for me. I want it so bad that I invested a lot of time with it today, but to no avail.
                          You’re just using the defaults? Because those didn’t work for me either, right from the get go.
                            ronny3050 Module Developer @Mykle1
                            @Mykle1 It’s strange that it’s not loading at all and @cowboysdude thank you for your kind words, but I am upset that it is loading slow now. I could try and optimize a little and check with you, if that’s okay?
                            @Mykle1 could you post pm2 logs?
                            Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                              Mykle1 Project Sponsor Module Developer @ronny3050
                              @ronny3050 said in Internet Monitor:
                              I could, if I knew how. I hope it doesn’t involve trying to run the module again. :-/ Please advise
                                cowboysdude Module Developer @ronny3050
                                @ronny3050 I don’t think it’s your module … I honestly believe that everything I’m loading is coming from an outside source as well so again I don’t believe it’s strictly your module :) I just think my mirror is away from my router and it takes a minute to shoot the info back [Ie news module, horoscope, globe data, weather]… :)
                                  @Mykle1 You could run it without he module to see what happens. I tell you what I’d do before I tried it again… backup my sd card :)
                                  The only thing I’m not loading that you are is the plantrise stuff didn’t need it… but other than that we are running almost identical.
                                  Mykle1M 2 Replies Last reply Reply Quote 1
                                    My mirror runs perfectly without the internet-monitor. It is only when I introduce that to my setup that things go south. Of course we’re running almost identical, you’re using my config. ;-) My project for today is backup my SD card so thanks for that suggestion.
                                    If someone would tell me how to find the pm2 logs I will post them
                                    cowboysdudeC M 2 Replies Last reply Reply Quote 0
                                      @Mykle1 I think they are here if I’m not mistaken:
                                      /root/.pm2/logs/
                                        /root/.pm2/logs/
                                        Thanks bro, I’ll look into that in a little while
                                          Mar @Mykle1
                                          @Mykle1 As I posted up above, seems like others are having the same issue. I noticed that in the logs the internet monitor is posting the speed every few seconds so I was thinking this was a probably cause?
                                          Though the amount of slowdown just to show the wifi indicator was a little too much
                                            /root/.pm2/logs/
                                            when I try cd root it says permission denied. I tried sudo cd root and it said bad command.
                                            So, how do I get to the logs so I can post them?
                                            • 1 / 6
