    Internet Monitor
    108 Posts 27 Posters 144.6k Views 30 Watching
      plumcraft
      Great module :)
        ronny3050 Module Developer @plumcraft
        @plumcraft thank you! :)
        • MichMichM Offline
          MichMich
          Love it! Especially the wifi connection indicator!
            ronny3050 Module Developer @MichMich
            @MichMich Thank you so much! It exists all because of what you started :)
              shashank @ronny3050
              @ronny3050 Module works great!, can the display speed graph resize
                ronny3050 Module Developer @shashank
                @shashank Thank you @shashank ! :D
                  Mar
                  Ive done quite a bit of testing and on the Zero this module really slows down my startup, and seems to cause a few other modules trying to connect to the internet to take forever to load, or timeout (i.e TubeStatus). Increases my startup from less than a minute to a few minutes. Im not really sure why, but as soon as i disable everything goes back to being smooth.
                  • cowboysdudeC Offline
                    Really nice!! Now I can put just the indicator on my mirror and it’s a great way to make sure you’re connected!!! Thanks!!
                      I played with this module the better part of this afternoon and it crashed my MM every time. I tried different positions, verbose and minimal, indicator enabled and not, maxTime I left at default (20000) with updateInterval ranging from 40000 -100000. displayStrength on and off and displaySpeed on and off. I gave up before changing anything in strengthIconSize and maxGaugeScale. Each time it would try to load and then freeze and lock up MM, forcing me to switch the power off because MM could unresponsive and could not be quit. Upon restarting, I would have to quickly run VNC, open the terminal and “pm2 stop mm” before it would launch again and crash again.
                      I really love the idea of this module and I would like to have it on my mirror. Any ideas?
                      Pi 3, Jessie
                        @Mykle1 I’ll try it on mine… I’ll let you know what happens… I mean mine is pretty much setup like yours [layout wise :)]…
                        Ok put in my mirror [I was just using in my dev at first] …
                        It makes things load slower but it does load…
                        • 10
                        • 11
                        • 1 / 11
