    Internet Monitor
    108 Posts 27 Posters 166.3k Views 30 Watching
      benjee
      Hi Ronny3050,
      just installed your module and it works fine…
      Is their a way to change jauge scale from 100 to 10Mbits for example ?
      I leave in a small village and my connection is up to 8M :)
      Thank you
        ronny3050 Module Developer @benjee
        @benjee thank you so much for your suggestion! I pushed it and you should be able to adjust the scale using maxGaugeScale.
          benjee
          Great !! It works fine !
          Thank you
            plumcraft
            Great module :)
              ronny3050 Module Developer @plumcraft
              @plumcraft thank you! :)
              • MichMichM
                MichMich
                Love it! Especially the wifi connection indicator!
                  ronny3050 Module Developer @MichMich
                  @MichMich Thank you so much! It exists all because of what you started :)
                    shashank @ronny3050
                    @ronny3050 Module works great!, can the display speed graph resize
                      ronny3050 Module Developer @shashank
                      @shashank Thank you @shashank ! :D
                        Mar
                        Ive done quite a bit of testing and on the Zero this module really slows down my startup, and seems to cause a few other modules trying to connect to the internet to take forever to load, or timeout (i.e TubeStatus). Increases my startup from less than a minute to a few minutes. Im not really sure why, but as soon as i disable everything goes back to being smooth.
                        • cowboysdudeC
                          Really nice!! Now I can put just the indicator on my mirror and it’s a great way to make sure you’re connected!!! Thanks!!
                          • Mykle1M
                            I played with this module the better part of this afternoon and it crashed my MM every time. I tried different positions, verbose and minimal, indicator enabled and not, maxTime I left at default (20000) with updateInterval ranging from 40000 -100000. displayStrength on and off and displaySpeed on and off. I gave up before changing anything in strengthIconSize and maxGaugeScale. Each time it would try to load and then freeze and lock up MM, forcing me to switch the power off because MM could unresponsive and could not be quit. Upon restarting, I would have to quickly run VNC, open the terminal and “pm2 stop mm” before it would launch again and crash again.
                            I really love the idea of this module and I would like to have it on my mirror. Any ideas?
                            Pi 3, Jessie
                            • cowboysdudeC
                              @Mykle1 I’ll try it on mine… I’ll let you know what happens… I mean mine is pretty much setup like yours [layout wise :)]…
                              Ok put in my mirror [I was just using in my dev at first] …
                              It makes things load slower but it does load…
                              • Mykle1M
                                @cowboysdude said in Internet Monitor:
                                Hmm, well, it’s not happening for me. I want it so bad that I invested a lot of time with it today, but to no avail.
                                You’re just using the defaults? Because those didn’t work for me either, right from the get go.
                                  ronny3050 Module Developer @Mykle1
                                  @Mykle1 It’s strange that it’s not loading at all and @cowboysdude thank you for your kind words, but I am upset that it is loading slow now. I could try and optimize a little and check with you, if that’s okay?
                                  @Mykle1 could you post pm2 logs?
                                  Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @ronny3050
                                    @ronny3050 said in Internet Monitor:
                                    I could, if I knew how. I hope it doesn’t involve trying to run the module again. :-/ Please advise
                                    • cowboysdudeC
                                      cowboysdude Module Developer @ronny3050
                                      @ronny3050 I don’t think it’s your module … I honestly believe that everything I’m loading is coming from an outside source as well so again I don’t believe it’s strictly your module :) I just think my mirror is away from my router and it takes a minute to shoot the info back [Ie news module, horoscope, globe data, weather]… :)
                                      • cowboysdudeC
                                        @Mykle1 You could run it without he module to see what happens. I tell you what I’d do before I tried it again… backup my sd card :)
                                        The only thing I’m not loading that you are is the plantrise stuff didn’t need it… but other than that we are running almost identical.
                                        Mykle1M 2 Replies Last reply Reply Quote 1
                                        • Mykle1M
                                          My mirror runs perfectly without the internet-monitor. It is only when I introduce that to my setup that things go south. Of course we’re running almost identical, you’re using my config. ;-) My project for today is backup my SD card so thanks for that suggestion.
                                          If someone would tell me how to find the pm2 logs I will post them
                                          cowboysdudeC M 2 Replies Last reply Reply Quote 0
                                          • cowboysdudeC
                                            @Mykle1 I think they are here if I’m not mistaken:
                                            /root/.pm2/logs/
                                            • 1 / 6
