    1 old noob + 1 rPi = I can't believe I did it! (revisited)
    193 Posts 29 Posters 478.9k Views 28 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @johnnyboy
      @johnnyboy said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
      I have been lurking on here for a while now picking up hints and tips along the way
      You don’t have to lurk. Step into the light. No really, this place is just full of helpful, brilliant people. Any problems I encountered were immediately addressed when I posted my questions. I’m basically done with my (1st) mirror but I’m sticking around to try to repay those that helped, or continue to help me, by helping others, if I can.
      • cowboysdudeC
        @Mykle1 Yes they were because they like doing this and because you asked nicely ;)
        We’ve had a few that ‘demanded’… they didn’t last long here… LOL
        This is a labor of love for many… There are so many other really great people here. So yes step into the light and ask questions… it’s how we learn!
        johnnyboyJ 1 Reply Last reply
        • johnnyboyJ
          johnnyboy @cowboysdude
          • cowboysdudeC
            cowboysdude Module Developer @johnnyboy
            @johnnyboy I had to format my brain to use Linux and learn JS… LOL BUT I’m doing it!
            I’m used to Windows and PHP… While the both offer great things learning something new can be fun and frustrating… But hang in there if you have questions someone is usually there to answer!
            Mykle1M 1 Reply Last reply
            • Mykle1M
              @Everyone
              1.1k views! That just made my day. Yeah, baby! :eyes:
              johnnyboyJ 2 Replies Last reply
              • johnnyboyJ
                johnnyboy @Mykle1
                Y 1 Reply Last reply
                • Y
                  yawns Moderator @johnnyboy
                  @johnnyboy
                  The pictures are there, the forum is just not showing them currently.
                  I fixed the image links in the opening post manually
                  Reply Quote 3
                  • johnnyboyJ
                    johnnyboy @Mykle1
                    • Mykle1M
                      Hey bud… what post had your updated MM pictures that showed your finished WunderGround module… the one where you added colours? iirc there was a tip there too to change the colors?
                      I don’t know where that post is so here’s what I think you are looking for. This goes in your custom.css file to change the colors for max-temp, min-temp and day. The colors you choose are up to you.
                      .MMM-WunderGround .max-temp {
                        color: #f66;
                      .MMM-WunderGround .min-temp {
                        color: #0ff;
                      .MMM-WunderGround .day {
                        color: #6f6;
                      That gives you this.
                      Reply Quote 2
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @yawns
                        @yawns said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                        They seem to be working now. Thanks yawns. :thumbsup:
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Guest
                          so maybe furum still buggy?
                          My Weather icons look nothing like yours… so do I need to update WunderGround?
                          Yes, I think there is an issue with pictures displaying but the moderators/administrators are aware of that and are looking into it. Make sure you have coloricon: true, set in your config.js file in the WunderGround array. If that doesn’t do it then maybe you do need to update WunderGround. In that case, in your terminal
                          ~/MagicMirror/modules/MMM-WunderGround $ git pull
                          That will update your WunderGround, if it needs it
                          • Mykle1M
                            Also… whats with the time being wrong? Its been stuck on 17.20 ?
                            That’s your sunset/sunrise time, from the Wunderground module. is your clock module installed.enable?
                            • Mykle1M
                              Is this not in your config.js file?
                              		module: 'clock',
                              		position: 'top_center'
                              • Mykle1M
                                Your a mind reader from across the pond lol… I was thinking about changing the clock over to centre 5 mins ago…
                                I wasn’t suggesting that you move the clock. I was only inquiring if you had the clock installed because you thought that the sunset time was the clock, stuck at 17:20
                                  sitobcn82
                                  Hi! I’m not able to find inside amazon, this king of acrylic plastic. Can you put the link please ?
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @sitobcn82
                                    @sitobcn82
                                    https://www.amazon.com/12-Acrylic-See-Through-Mirror-3mm/dp/B01G4MQ5OW/ref=sr_1_4?ie=UTF8&qid=1487615457&sr=8-4&keywords=12"x24"+3mm+acrylic
                                    • johnnyboyJ
                                      johnnyboy @Mykle1
                                      • Mykle1M
                                        change out the calendar for something else or see if calender is editable?
                                        Well, that’s the beauty of having modules. You can always change them to something more to your liking. I like the calendar because it allows me to link my Google calendar into it, so I see my events (birthdays, weddings, party dates, etc) as well as the US Holidays. You can also change the dates from relative (in 22 days) to absolute (Mar 14th) in the config’js file, which is nice. And there’s always the custom.css file for coloring, positioning, sizing, etc.
                                        Initially, my biggest problem was wanting to put as many modules as I could fit on the screen, but I soon realized that it looked too busy, too cluttered. So, I decided less is more. I decided what modules were really important to me and where I wanted them. I’m happy with my design
                                        • johnnyboyJ
                                          johnnyboy @Mykle1
                                          johnnyboyJ Mykle1M 2 Replies Last reply
                                          • johnnyboyJ
                                            johnnyboy @johnnyboy
                                            • 10
                                            • 2 / 10
