    1 old noob + 1 rPi = I can't believe I did it! (revisited)
    193 Posts 29 Posters 474.1k Views 28 Watching
      @Everyone
      1.1k views! That just made my day. Yeah, baby! :eyes:
      johnnyboyJ 2 Replies Last reply Reply Quote 1
      • johnnyboyJ Offline
        johnnyboy @Mykle1
        • Y Offline
          yawns Moderator @johnnyboy
          @johnnyboy
          The pictures are there, the forum is just not showing them currently.
          I fixed the image links in the opening post manually
          Mykle1M 1 Reply Last reply Reply Quote 3
            johnnyboy @Mykle1
              Mykle1 Project Sponsor Module Developer @johnnyboy
              @johnnyboy said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
              Hey bud… what post had your updated MM pictures that showed your finished WunderGround module… the one where you added colours? iirc there was a tip there too to change the colors?
              I don’t know where that post is so here’s what I think you are looking for. This goes in your custom.css file to change the colors for max-temp, min-temp and day. The colors you choose are up to you.
              .MMM-WunderGround .max-temp {
                color: #f66;
              .MMM-WunderGround .min-temp {
                color: #0ff;
              .MMM-WunderGround .day {
                color: #6f6;
              That gives you this.
                Mykle1 Project Sponsor Module Developer @yawns
                @yawns said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                They seem to be working now. Thanks yawns. :thumbsup:
                  Mykle1 Project Sponsor Module Developer @Guest
                  so maybe furum still buggy?
                  My Weather icons look nothing like yours… so do I need to update WunderGround?
                  Yes, I think there is an issue with pictures displaying but the moderators/administrators are aware of that and are looking into it. Make sure you have coloricon: true, set in your config.js file in the WunderGround array. If that doesn’t do it then maybe you do need to update WunderGround. In that case, in your terminal
                  ~/MagicMirror/modules/MMM-WunderGround $ git pull
                  That will update your WunderGround, if it needs it
                    Also… whats with the time being wrong? Its been stuck on 17.20 ?
                    That’s your sunset/sunrise time, from the Wunderground module. is your clock module installed.enable?
                      Is this not in your config.js file?
                      		module: 'clock',
                      		position: 'top_center'
                        Your a mind reader from across the pond lol… I was thinking about changing the clock over to centre 5 mins ago…
                        I wasn’t suggesting that you move the clock. I was only inquiring if you had the clock installed because you thought that the sunset time was the clock, stuck at 17:20
                        johnnyboyJ 1 Reply Last reply Reply Quote 0
                          sitobcn82
                          Hi! I’m not able to find inside amazon, this king of acrylic plastic. Can you put the link please ?
                            Mykle1 Project Sponsor Module Developer @sitobcn82
                            @sitobcn82
                            https://www.amazon.com/12-Acrylic-See-Through-Mirror-3mm/dp/B01G4MQ5OW/ref=sr_1_4?ie=UTF8&qid=1487615457&sr=8-4&keywords=12"x24"+3mm+acrylic
                              johnnyboy @Mykle1
                                change out the calendar for something else or see if calender is editable?
                                Well, that’s the beauty of having modules. You can always change them to something more to your liking. I like the calendar because it allows me to link my Google calendar into it, so I see my events (birthdays, weddings, party dates, etc) as well as the US Holidays. You can also change the dates from relative (in 22 days) to absolute (Mar 14th) in the config’js file, which is nice. And there’s always the custom.css file for coloring, positioning, sizing, etc.
                                Initially, my biggest problem was wanting to put as many modules as I could fit on the screen, but I soon realized that it looked too busy, too cluttered. So, I decided less is more. I decided what modules were really important to me and where I wanted them. I’m happy with my design
                                  johnnyboy @Mykle1
                                  johnnyboyJ Mykle1M 2 Replies Last reply Reply Quote 0
                                    johnnyboy @johnnyboy
                                      @johnnyboy
                                      body {
                                        color: #f66;
                                        color: #0ff;
                                        color: #6f6;
                                      That’s my custom.css entry for coloring
                                        johnnyboy @Mykle1
                                          @johnnyboy
                                          			module: 'calendar',
                                          			position: 'top_left',
                                          			urgency: 0,
                                          			getRelative: 1,
                                          			fadePoint: 0.25, // Start on 1/4th of the list.
                                          						symbol: 'calendar-check-o ',
                                          						url: 'https://calendar.google.com/calendar/ical/THIS COMES FROM GOOGLE CALENDAR/private-YOUR GOOGLE CALENDAR API GOES HERE/basic.ics'
                                          Change your getRelative: 1 as above in your config.js file
                                          Add your google calendar as above in your config.js file
                                            And please let us know the reactions of your son. I can imagine I would be kind of irritated but proud of my dad building such a thing on his own, working his way through all these difficulties.
                                            My son came home yesterday and stayed through this evening. It turns out my efforts were not in vain. He was utterly amazed that I took on, and completed, the MagicMirror project. He was excited and enthusiastic, wanting to see the code of the modules and css files. He already has ideas for what he would want to do with MM.
                                            So, he went back to school with a camera full of pictures of my mirror to show his frat buddies, and he promised that he and I would do something like this together, when time allowed. I’m hoping he will want to create a MM module with me, although he would be doing all the work and I would just be along for the ride.
                                            cowboysdudeC johnnyboyJ Mykle1M 3 Replies Last reply Reply Quote 6
                                            • 10
                                            • 2 / 10
