    How to resize Icon and Change Day language in WunderGround
    18 Posts 4 Posters 12.4k Views 4 Watching
    • N Offline
      nobita
      Re: WunderGround Icon name?
      as photo above ,How can I resize Icon symbol (as thermometer and Umbrella) and Change Day language
      Thanks for helps
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @nobita
        @nobita
        .MMM-WunderGround table.small .wi {
            font-size: 10px;
        .MMM-WunderGround table.small .forecastWeatherIcon {
            height: 10px;
            width: 10px;
        • N Offline
          nobita @strawberry 3.141
          @strawberry-3.141 Thanks,I will Try later
          • W Offline
            wizz
            I wounder as i tried to set the lang tosv as it is for Sweden and still it display English? any solution for that?
              Mykle1 Project Sponsor Module Developer @wizz
              @wizz
              The language of the days. Goes in your config.js for WunderGround
              lang: ‘en’, Change this to your language, or change language: 'en', at the top of your config.js, unless you want everything else in English.
              • W Offline
                wizz
                @Mykle1 i got this in my config.js
                At the top language: ‘sv’, as i want it in Swedish.
                Also i have the WunderGround lang: ‘sv’,
                But it still shows in English and not in Swedish?
                Mykle1M strawberry 3.141S 3 Replies Last reply Reply Quote 0
                  @wizz said in How to resize Icon and Change Day language in WunderGround:
                  Yes, that’s odd. You could try removing lang: ‘sv’, from the WunderGround portion of your config.js.
                  Also, are you sure you’re using the most recent version of WunderGround?
                  In your terminal, go to ~/MagicMirror/modules/MMM-WunderGround $
                  and type git pull, then restart your mirror
                    I just checked my translations folder in the MMM-WunderGround folder. I only have de, en, fr, nl and pl. This may be where your problem is.
                      strawberry 3.141 Project Sponsor Module Developer @wizz
                      @wizz the module uses momentjs to create those day abbrevations. maybe you’re missing the moment locales for swedish.
                      also the config option lang has no effect at all as it is not used anywhere in the code, maybe it is from an old version. The language which is used for moment js is the global config language.
                      • W Offline
                        wizz
                        @strawberry-3-141 the moment locales how do i add that? if it is missing?
                          @wizz The module dependency moment.js gets mapped in the vendor directory to the file moment-with-locales.js and in there is the locale sv. Do the other modules work with swedish language? Is only a part working in swedish? Can you make a screenshot?
                          • W Offline
                            wizz
                            @strawberry-3-141 Later on tonight i will try to make a screenshot of that. and hope to get that right :)
                            • W Offline
                              wizz
                              @strawberry-3-141 All Modules work with Swedish but not WunderGround and also the Traffic Module is only in English but the rest works with Swedish?
                              • W Offline
                                wizz
                                @strawberry-3-141 The default Weather module display in Swedish but not the Wunderground module ?
                                This means that the moment locales works.
                                strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                  @wizz I’ll have a look
                                    @wizz Ok I digged a little bit deeper than last time. As it points out the config option in MMM-Wunderground has an usage in the node_helper I didn’t check before. The problem is that Wunderground uses for some languages some uncommon language codes
                                      module: "MMM-WunderGround",
                                        lang: "sw"
                                    the full list can be found here https://www.wunderground.com/weather/api/d/docs?d=language-support
                                    N 1 Reply Last reply Reply Quote 1
                                    • N Offline
                                      @strawberry-3.141 's not work
