    How to resize Icon and Change Day language in WunderGround
    18 Posts 4 Posters 11.5k Views 4 Watching
    • N Offline
      nobita @strawberry 3.141
      @strawberry-3.141 Thanks,I will Try later
      • W Offline
        wizz
        I wounder as i tried to set the lang tosv as it is for Sweden and still it display English? any solution for that?
          Mykle1 Project Sponsor Module Developer @wizz
          @wizz
          The language of the days. Goes in your config.js for WunderGround
          lang: ‘en’, Change this to your language, or change language: 'en', at the top of your config.js, unless you want everything else in English.
          • W Offline
            wizz
            @Mykle1 i got this in my config.js
            At the top language: ‘sv’, as i want it in Swedish.
            Also i have the WunderGround lang: ‘sv’,
            But it still shows in English and not in Swedish?
            Mykle1M strawberry 3.141S 3 Replies Last reply Reply Quote 0
              @wizz said in How to resize Icon and Change Day language in WunderGround:
              Yes, that’s odd. You could try removing lang: ‘sv’, from the WunderGround portion of your config.js.
              Also, are you sure you’re using the most recent version of WunderGround?
              In your terminal, go to ~/MagicMirror/modules/MMM-WunderGround $
              and type git pull, then restart your mirror
                I just checked my translations folder in the MMM-WunderGround folder. I only have de, en, fr, nl and pl. This may be where your problem is.
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @wizz
                  @wizz the module uses momentjs to create those day abbrevations. maybe you’re missing the moment locales for swedish.
                  also the config option lang has no effect at all as it is not used anywhere in the code, maybe it is from an old version. The language which is used for moment js is the global config language.
                  • W Offline
                    wizz
                    @strawberry-3-141 the moment locales how do i add that? if it is missing?
                      @wizz The module dependency moment.js gets mapped in the vendor directory to the file moment-with-locales.js and in there is the locale sv. Do the other modules work with swedish language? Is only a part working in swedish? Can you make a screenshot?
                      • W Offline
                        wizz
                        @strawberry-3-141 Later on tonight i will try to make a screenshot of that. and hope to get that right :)
