    How to resize Icon and Change Day language in WunderGround
    18 Posts 4 Posters 11.7k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @wizz
      @wizz
      The language of the days. Goes in your config.js for WunderGround
      lang: ‘en’, Change this to your language, or change language: 'en', at the top of your config.js, unless you want everything else in English.
      • W Offline
        wizz
        @Mykle1 i got this in my config.js
        At the top language: ‘sv’, as i want it in Swedish.
        Also i have the WunderGround lang: ‘sv’,
        But it still shows in English and not in Swedish?
        Mykle1M strawberry 3.141S 3 Replies Last reply Reply Quote 0
          @wizz said in How to resize Icon and Change Day language in WunderGround:
          Yes, that’s odd. You could try removing lang: ‘sv’, from the WunderGround portion of your config.js.
          Also, are you sure you’re using the most recent version of WunderGround?
          In your terminal, go to ~/MagicMirror/modules/MMM-WunderGround $
          and type git pull, then restart your mirror
            I just checked my translations folder in the MMM-WunderGround folder. I only have de, en, fr, nl and pl. This may be where your problem is.
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @wizz
              @wizz the module uses momentjs to create those day abbrevations. maybe you’re missing the moment locales for swedish.
              also the config option lang has no effect at all as it is not used anywhere in the code, maybe it is from an old version. The language which is used for moment js is the global config language.
              • W Offline
                wizz
                @strawberry-3-141 the moment locales how do i add that? if it is missing?
                  @wizz The module dependency moment.js gets mapped in the vendor directory to the file moment-with-locales.js and in there is the locale sv. Do the other modules work with swedish language? Is only a part working in swedish? Can you make a screenshot?
                  • W Offline
                    wizz
                    @strawberry-3-141 Later on tonight i will try to make a screenshot of that. and hope to get that right :)
                    • W Offline
                      wizz
                      @strawberry-3-141 All Modules work with Swedish but not WunderGround and also the Traffic Module is only in English but the rest works with Swedish?
                      • W Offline
                        wizz
                        @strawberry-3-141 The default Weather module display in Swedish but not the Wunderground module ?
                        This means that the moment locales works.
                        strawberry 3.141S 2 Replies Last reply Reply Quote 0
