    How to resize Icon and Change Day language in WunderGround
    18 Posts 4 Posters 12.0k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @wizz
      @wizz the module uses momentjs to create those day abbrevations. maybe you’re missing the moment locales for swedish.
      also the config option lang has no effect at all as it is not used anywhere in the code, maybe it is from an old version. The language which is used for moment js is the global config language.
      • W Offline
        wizz
        @strawberry-3-141 the moment locales how do i add that? if it is missing?
          @wizz The module dependency moment.js gets mapped in the vendor directory to the file moment-with-locales.js and in there is the locale sv. Do the other modules work with swedish language? Is only a part working in swedish? Can you make a screenshot?
          • W Offline
            wizz
            @strawberry-3-141 Later on tonight i will try to make a screenshot of that. and hope to get that right :)
            • W Offline
              wizz
              @strawberry-3-141 All Modules work with Swedish but not WunderGround and also the Traffic Module is only in English but the rest works with Swedish?
              • W Offline
                wizz
                @strawberry-3-141 The default Weather module display in Swedish but not the Wunderground module ?
                This means that the moment locales works.
                strawberry 3.141S 2 Replies Last reply Reply Quote 0
                  @wizz I’ll have a look
                    @wizz Ok I digged a little bit deeper than last time. As it points out the config option in MMM-Wunderground has an usage in the node_helper I didn’t check before. The problem is that Wunderground uses for some languages some uncommon language codes
                      module: "MMM-WunderGround",
                        lang: "sw"
                    the full list can be found here https://www.wunderground.com/weather/api/d/docs?d=language-support
                    N 1 Reply Last reply Reply Quote 1
                    • N Offline
                      nobita @strawberry 3.141
                      @strawberry-3.141 's not work
                        strawberry 3.141 Project Sponsor Module Developer @nobita
