    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • L Offline
      lucallmon @strawberry 3.141
      @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
      • L Offline
        lucallmon
        @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
        [STEP 5/6] Installing npm dependencies
        dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
        npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
        npm WARN pocketsphinx No description
        npm WARN pocketsphinx No repository field.
        npm WARN pocketsphinx No README data
        npm WARN pocketsphinx No license field.
        [STEP 5/6] Installing npm dependencies | Done
        [STEP 6/6] Manipulating dependencies
        dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
        sed: can't read index.js: No such file or directory
        [STEP 6/6] Manipulating dependencies | Failed
        thoughts?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @lucallmon
          @lucallmon this will not work as it tries to look and do stuff in /root/... instead of /home/pi/...
            I’m curious if someone ever tried to find the easter egg in this module :thinking:
            Mykle1M A 2 Replies Last reply Reply Quote 1
              Mykle1 Project Sponsor Module Developer @strawberry 3.141
              @strawberry-3.141 said in MMM-voice:
              I tried the voice command, “Show me some boobs”, but I got nothing. :-)
              The same exact response I get from my wife.
                abcdennis @strawberry 3.141
                @strawberry-3.141 I found it, I just didn’t want to post any spoilers.
                  Mykle1 Project Sponsor Module Developer @abcdennis
                  @abcdennis said in MMM-voice:
                  How about a hint then? You can pm it if you don’t want to spoil it for others
                  strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
                    strawberry 3.141 Project Sponsor Module Developer @Mykle1
                    @Mykle1 A hint would be if you want to test it as a voice command you need to have mmm-tts installed as well or you try to reverse engineer it then you can start at the mmm-tts notification ;)
                      This is an impossibility. “shrug”
                        @Mykle1 then you need mmm-tts to hear the response when you found it :)
                        • cowboysdudeC Offline
                          I’m sworn to secrecy… will not tell :) Install MMM-TTS and you’ll love it when you find it! :)
                            My mirror does not have sound (yet) so I’ll have to install tts on my MM Sports Laptop
                              @strawberry-3.141
                              Do I run sudo apt-get festival in the MMM-TTS directory?
                              cowboysdudeC strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                  @Mykle1 it doesnt matter in which directory you run the command
                                    Ok @abcdennis got the correct answer, let’s see who else get the right answer. Next hint on Thursday.
                                      ok,thanks
                                        Today is Friday. Where’s my hint? :-)
                                          @Mykle1 There was once a fairytale, where a mirror took place
                                          Solution will follow on sunday.
                                          johnnyboyJ Mykle1M 2 Replies Last reply Reply Quote 2
                                          • johnnyboyJ Offline
                                            johnnyboy @strawberry 3.141
                                            • 16
                                            • 17
                                            • 7 / 17
