MMM-Sonos - To show what your SONOS is playing.
29 Posts 17 Posters 23.5k Views 16 Watching
    Snille Module Developer
    Description:
    This is an modification of of @Vaggan MagicMirror-SonosModule and @CFenner MagicMirror-SonosModule. It was modified to get some enhancements in visualisation and configuration. Also the module hides itself when not playing now.
    Note from me: I’m new to the MagicMirror world and Node.js, this is my first attempt to modify a module. There are probably lot’s of things that could have been done better. :)
    Screenshots:
    When starting the Mirror:
    Module on the Left side of the Mirror:
    Module in the Center of the Mirror:
    Module in the Center of the Mirror playing in 3 different zones:
    Module on the Right side of the Mirror:
    And, this is my own look on my mirrors (@ top center) using some addition in the custom.css…
    If you want my look on it, use this CSS code in your custom.css.
    /* Sonos --------------------------------------------*/
    .sonos ul .type {
        font-size: 12px;
        padding: 0px 0px;
        line-height: 12px;
        width: 260px;
    .sonos ul .room {
        font-size: 16px;
        padding: 0px 0px;
        line-height: 16px;
        width: 260px;
    .sonos ul .song {
        padding: 0px 0px;
        position: relative;
    .sonos ul .art img {
        height: 60px;
        width: 60px;
        border-radius: 50%;
        margin: 0px 0px;
        border: 2px solid #FFF;
    .sonos ul .name {
        width: 200px;
        font-size: 16px;
        padding: 0px 4px;
        line-height: 16px;
    Download:
    [card:Snille/MMM-Sonos]
    Version 0.1
    • I’m guessing that’s Vaggans version…
    Version 0.2
    • Has to be CFenners version…
    Version 0.3
    • My version… :)
    If you cant find it, make it and share it!
    Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      Atreo
      Hi There.
      First i need to say that i am new to both Raspberry and Magic mirror.
      Sooo happy now when i know what it can do.
      I have i problem with the sonos module, Don´t know if you can help me.
      I can not make it work, i get on the mirror saying Loading music.
      And i can see that it is saying from the terminal.
      Sono_update
      Failure: Error: Connect ECONNREFUSED 192.168.0.100
      Kind regards
      Jonas
      L C 2 Replies Last reply Mar 22, 2017, 9:11 PM Reply Quote 0
      • L Offline
        Luttich @Atreo
        @Atreo same for me
          cederstrom Module Developer @Atreo
          @Atreo Have you tried the fix in the “Known issues” section of the README? https://github.com/Snille/MMM-Sonos#known-issues
            cohron
            Guess I’m total noob but I havent figured out exactly how to install MMM-Sonos.
            1. I’m confused on installing and running node-sonos-http-api part. Does it get installed on /usr/local/lib/node_modules (I dont have that folder) but I do have /home/pi/MagicMirror/node_modules.
            2. MM is on rPI3b using the default installation from the readme but the the documentation on the api says i should install the latest nodejs. do i need to update/install? I went to https://nodejs.org/download/release/latest/ and it looks like 7.9.0 is the latest. i assume i install this on the MM rPI also. I’ll have to figure out how to git that too if so.
            3. I have my mm.sh file that auto-starts MM using pm2. Do I add a line in the mm.sh file to auto run the api on boot?
              my mm.sh
              DISPLAY=:0 npm start
              @cohron First you need to “install” the node-sonos-http-api. You can put the node-sonos-http-api on the RPi I think. I have not tried that. I have mine installed on another server. But just try it, do the following (obs I have not tried this):
              cd ~
              git clone git@github.com:jishi/node-sonos-http-api.git
              cd node-sonos-http-api
              npm install --production
              npm start
              Now, see if you can get your zones via the link: http://yourmagicmirrorip:5005/zones
              If you do, you should be able to point your config to http://localhost
              And you should see something playing, if it is playing. :)
              Now you need to make sure the http-api is running all the time.
              Use the same procedure as for the MagicMirror.
              When you have the MagicMirror and http-api running type pm2 save (if you are using pm2).
              Otherwise you have to add it to your startup manually.
              I hope this helps a bit at least. :)
              C 1 Reply Last reply Apr 21, 2017, 9:32 PM Reply Quote 0
                cohron @Snille
                @Snille
                All right, love trial and error. Got it all up and running on my MM rPI!!!
                Through ssh pi@192.168.0.207 (my MM ip address)
                cd ~ //which puts me at /home/pi
                pi@magicpi:~ $ git clone https://github.com/jishi/node-sonos-http-api.git
                npm start
                verify, open a browser, point to your MM’s IP like so:
                http://192.168.0.207:5005/zones
                you should see a page full of sonos related text, if so the hard part is done…
                create another pm2 script named sonos.sh in ~ directory
                cd ~
                sonos.sh file contents:
                cd ~/node-sonos-http-api
                pm2 start sonos.sh
                pm2 start mm
                pm2 save
                now just do the normal git for the sonos module
                pi@magicpi:~/MagicMirror/modules $ git clone https://github.com/Snille/MMM-Sonos.git
                fill in your config, this is mine:
                module: ‘MMM-Sonos’,
                header: “Playing on SONOS”,
                position: “top_center”, // This can be any of the regions, best results in center regions
                classes: “default everyone”,
                // See ‘Configuration options’ for more information.
                showStoppedRoom: false,
                showAlbumArt: true
                I also copied your awsome custom css content!
                D B 2 Replies Last reply Apr 15, 2018, 6:20 PM Reply Quote 0
                  @cohron So it’s working now? Congrats! Great work! :)
                  J 1 Reply Last reply Apr 26, 2017, 2:07 AM Reply Quote 0
                    j.e.f.f Project Sponsor Module Developer @Snille
                    • brandongomezB Offline
                      brandongomez
                      Great module! I am new to all of this and have the module working as intended. I listen to SiriusXM, Google Play and Spotify through Sonos.
                      Google Play looks great and pulls the Artist and Track Title correctly. However, SiriusXM is sending everything together. Is there a way to format what SiriusXM sends me?
                      For example, if I go to http://IP_Address:5005/zones when using Google Play, I see… {“currentTrack”:{“artist”:“Aretha Franklin”,“title”:“Respect”,“album”:“I Never Loved A Man The Way I Love You”,“albumArtUri”
                      But if I put on a SiriusXM channel, it looks like this… {“currentTrack”:{“title”:“BR P|TYPE=SNG|TITLE Cold Little Heart|ARTIST Michael Kiwanuka|ALBUM”,“albumArtUri”
                      As a result, the SiriusXM channel shows nothing for the Artist and “BR P|TYPE=SNG|TITLE Cold Little Heart|ARTIST Michael Kiwanuka|ALBUM” for the Track. Would love to get it to show something like “Cold Little Heart, Michael Kiwanuka” instead.
                      Any help is appreciated. Thanks!
