    MMM-Globe
    118 Posts 32 Posters 199.1k Views 37 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Eunanibus
      @Eunanibus Welcome to the club LOL At times there’s just no way to know how something is going to react …everyone seems to have different setups… at times this causes issues :)
        BlackTalon
        So does that mean some people have this running on their Pi 3? If so I’ll try a fresh build and install this first.
        bheplerB 1 Reply Last reply
        • bheplerB
          bhepler Module Developer @BlackTalon
          @BlackTalon I don’t think so, no. I’m running this on either my development PC, my work desktop or a microPC. Win10 or Ubuntu 16, respectively.
          It looks like the electron browser thingy doesn’t support some of the commands used by the module. Possibly. We may need a workaround. Still investigating.
            BlackTalon
            Ok I managed to get this running on a Pi 3. I did sudo apt-get update and sudo apt-get upgrade after installing the driver from raspi-config. Its flickering pretty bad but its running it. I need to pair down some processes on here to see if I can get it to run cleaner.
              BlackTalon
              Its hammering the processor on the Pi 3 pretty bad The chip is getting hot. I am going to add a heat sink and a fan to it before I do more. Thanks for your help.
              • bheplerB
                @BlackTalon Interesting. Thanks for figuring out the issue.
                Question: I could load this on the Raspberry Pi 3 at the office and then take a video of the end result. Would that be interesting to the community? Or should we just call this a greater-than-raspberry module?
                • cowboysdudeC
                  cowboysdude Module Developer @bhepler
                  @bhepler I am using on my win10 dev machine and unbuntu mini-itx 32" inch mirror so it runs great but yes I’d be interested in the RPI-3 info! :)
                  • slametpsS
                    slametps
                    @Eunanibus : your module name has conflicted with this one MMM-Globe. I suggest you change your Globe module name.
                    regards,
                    Slamet PS
                    • bheplerB
                      Well, this sucks. I tried to enable the GL drivers on my Raspberry Pi 3 and it crashed the Pi. It installed the drivers, asked me to reboot and then the Pi won’t come back up. I’m going to have to reflash the card and start over.
                      It’s going to be a long night. If you’re going to try the GL drivers, back up your config.js at the very least. Better yet, image your SD card just in case.
                      D 1 Reply Last reply
                        d3r @bhepler
                        @bhepler said in MMM-Globe:
                        I had the same black screen issue on my pi3. I reflashed my card twice before realizing I could have disabled opengl by editing the boot config.txt file. This might save someone else some time. So if you enable opengl and get the black screen issue remember to edit you config file to fix the issue.
                        dtoverlay=vc4-kms-v3ddtoverlay=vc4-fkms-v3d
                        gpu_mem=256
                        #dtoverlay=vc4-fkms-v3d
                        #Adding these two lines stopped the black screen issue.
                        hdmi_force_edid_3d=1
                        avoid_warnings=2
                        https://www.raspberrypi.org/forums/viewtopic.php?p=999920#p999920
                        E 1 Reply Last reply
                        Reply Quote 2
                        • E
                          ecirpnaes @d3r
                          @d3r This.
                          I had the same issue on a Pi 2. Starting in safe mode (repeatedly mashing the Shift key on boot) got me up. Editing the boot config.txt file and commenting out the lines that get added when you enable the Open GL driver fixed things.
                          • tidus5T
                            tidus5
                            as anybody know why we have this issue ? I m reading that can be cause of the power supply ?
                              blafpap @BlackTalon
                              @BlackTalon got it running to on the rpi3, but it is flickering and sometimes blackscreen. Rpi3 is to weak i think.
                              • bheplerB
                                bhepler Module Developer @tidus5
                                @tidus5 The OpenGL drivers are experimental. I think we’re pushing the Pi - even the RPi3 - to its absolute limit with this type of rendering. A stable power supply isn’t the issue. It’s an issue of raw computing power.
                                • SvenSommerS
                                  SvenSommer
                                  This module is amazing! Some thoughts about this:
                                  1. I’m sure many overlook this topic because it is not classified into one of the subcategories, like all other modules, as one would expect. I believe this piece of art deserves the full attention!
                                    @administrators Is it possible to shift the module to Utilities?
                                  2. I really would like to use this module for showing real time data from other modules, by using Notifications. E. g. location data from website visitors with MMM-GoogleAnalytics.
                                    @Eunanibus Is it possible to add location data to the globe while it’s already animated?
                                  Looking for some building inspiration?
                                  Check out my large, thin and metal framed mirror on robstechlog.com.
                                  Modules released:
                                  MMM-GoogleAnalytics
                                  MMM-GrafanaChart
                                  MMM-GrafanaGauges
                                  • E
                                    Eunanibus Module Developer @SvenSommer
                                    @SvenSommer I’m glad you like it! There is a separate post for this in Utilities but it hasn’t garnered a huge amount of attention. I’m hesitant because if most users user Pi’s for their mirror, this plugin may provide a heavy burden to it in terms of computational ability.
                                    1. There is no reason you cannot. I think this would be entirely possible. The module allows you to pass custom locations for pins within the builder (see documentation), so there’s no reason that this information cannot be derived from a custom script.
                                    cowboysdudeC SvenSommerS 2 Replies Last reply
                                    Reply Quote 2
                                    • cowboysdudeC
                                      @Eunanibus I LOVE this module… I have installed it on my itx board MM and it has enough power to make it work awesome!!
                                      • SvenSommerS
                                        SvenSommer @Eunanibus
                                        @Eunanibus
                                        Thanks for you tips. I could easily adjust the module to react to Notifications. I made a pull Request with the latest changes.
                                        Would be so kind to merge them?!
                                        I also adjusted my module MMM-GoogleAnalytics to provide the coordinates of the website visitors location.
                                        The module is in a very early state but it’s quite impressive to see it’s working . See for yourself:
                                        https://youtu.be/xOU1pVOgcTY
                                        Bad side of the story?
                                        I have to get rid of the Raspberry Pi 3 in my MagicMirror. But hey, it was already to long in a “completed” state. :)
                                        @bhepler : You were running this module smoothly on your mirror. What hardware did you use?
                                        Modules released:
                                        MMM-GoogleAnalytics
                                        MMM-GrafanaChart
                                        MMM-GrafanaGauges
                                        E bheplerB 2 Replies Last reply
                                        • E
                                          Eunanibus Module Developer @cowboysdude
                                          @cowboysdude I’m really pleased. Because of yours and others feedback, I’ve revised the front page of this module recommending not to use this module with Pi’s. That said, I’m really glad it’s serving you well - I worked hard on it and that’s exactly what I wanted from it!
                                          Also if you want to submit a video of it in action (wherever that may be!) here, please feel free. I love seeing my module in people’s homes.
                                          • E
                                            @SvenSommer said in MMM-Globe:
                                            Hi Sven,
                                            Thanks for your contribution here. I’ll review the changes tomorrow (It’s pretty late here) - I believe @bhepler was using a more powerful linux driven system. I’ve had multiple reports from users that their Pi’s aren’t really up to the task, and I’ve updated the title page as such.
                                            I’m going to attempt to create a lite version of this module for Pi users when I get the opportunity. In actuality, I’d like to rebuild the module entirely as there’s a lot of code cleanup I’d like to do. Although Rob S was the original creator of the globe, he assisted me in making heavy changes to the code, and I had to make some additions to make it compatible with the MM framework. Unbelievably, this was actually heavier on processing prior to release. Performance improvements are at the top of my list, as are a few other things.
                                            Either way, I’m really glad your enjoying it, and your creativity in feeding new locations is really encouraging.
                                            B L 2 Replies Last reply
                                            • 3 / 6
