    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      Advokaten @pawpawsoswag
      @pawpawsoswag MAGIC MIRROR VOICE OPEN HELP? Maybe pause a bit before saying “VOICE”?
        Rattenjunge8080
        maybe someone can help me…I installed this module and when I starting the Magic Mirror, everything seems to be fine.
        But since I installed this Module, my microfone and the audio output is not working anymore (I tested the microfone and the speaker before I installed this module).
        Iḿ using a USB-Dongle and like I sayed, everything was fine until I installed this module.
        When I choose the “Audio Device Setting”, I can choose between “bcm2385 ALSA” and “USB PnP Sound Device”. Both are not working anymore.
        Someone have some advise?
        Thank you very much.
        • cowboysdudeC Offline
          cowboysdude Module Developer @Rattenjunge8080
          @Rattenjunge8080 Did you get any install errors?
            Rattenjunge8080 @cowboysdude
            @cowboysdude no, there were no errors and the module is appearing in the UI of the Mirror.
            I think it has something to do with the pocketsphinx Software-> cause this problem seems to happend often for people using USB-Sound devices on Raspian Jesse. It changes the priority of the Sound devices for some reason…
              That’s odd because I had no issues myself. Delete the pocketsphinx and run npm install again
                @cowboysdude Didn’t worked. I think this module let my RPI crash (more like: changes in my system were made, which I cannot set back).
                I will bet a backup and try again.
                Thanks for your help!
                  @Rattenjunge8080 Yeah I’m not seeing that… it wouldn’t crash your system or RPI. It would have to change the Raspbian operating system to do that and it doesn’t touch that… so it’s very possible you could have an SD card going South…
                    beck0r
                    Hi there,
                    could you have a look with us on this ?
                    MMM-Voice libpocketsphinx.so.3: cannot open shared object file: No such file or directory[update]
                    Thank you
                    Kind Regards
                      cowboysdude Module Developer @beck0r
                      @beck0r Same thing I would delete pocketsphinx and reinstall it…
                        beck0r @cowboysdude
                        @cowboysdude
                        I have removed the folder pocketsphinx with rm -r. This did not feel right ;)
                        Since I’m quite new to linux… could you please describe me the proper way to remove the needed components?
                        Sorry if I may have overlooked something around here. A lot of posts for a newcomer.
                        Thank you very much
                          beck0r @cowboysdude
                          @cowboysdude
                          Update:
                          Ran bash dependencies.sh again and reinstalled sphinx but still the same output in the debug log.
                            You’re doing it correctly just not sure why you’re getting those results.
                            I would, if I were you, delete the entire thing… start over. Something is getting corrupt.
                              beck0r @cowboysdude
                              @cowboysdude
                              I did that, still the same… here’s what “npm start dev” is showing me right now
                              TypeError: this.sendSocketNotification is not a function
                                  at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
                                  at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
                                  at FSReqWrap.oncomplete (fs.js:112:15)
                              TypeError: Cannot read property 'debug' of undefined
                                  at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
                                  at emitOne (events.js:96:13)
                                  at PocketSphinxContinuous.emit (events.js:188:7)
                                  at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
                                  at Socket.emit (events.js:188:7)
                                  at readableAddChunk (_stream_readable.js:176:18)
                                  at Socket.Readable.push (_stream_readable.js:134:10)
                                  at Pipe.onread (net.js:551:20)
                              So if anybody has an idea let met know :)
                              • E Offline
                                ezarlive @beck0r
                                @beck0r Same error here:
                                1|mm | MMM-voice: Checking files.
                                1|mm | MMM-voice: Starting pocketsphinx.
                                1|mm | Whoops! There was an uncaught exception...
                                1|mm | TypeError: this.sendSocketNotification is not a function
                                1|mm | at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
                                1|mm | at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
                                1|mm | at FSReqWrap.oncomplete (fs.js:112:15)
                                • E Offline
                                  ezarlive
                                  Nothing to do with this module.
                                  It doesnt works :(
                                  Fails everytime.
                                  0|mm       | TypeError: Cannot read property 'debug' of undefined
                                  0|mm       |     at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
                                  0|mm       |     at emitOne (events.js:96:13)
                                  0|mm       |     at PocketSphinxContinuous.emit (events.js:191:7)
                                  0|mm       |     at Socket. (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
                                  0|mm       |     at Socket.emit (events.js:191:7)
                                  0|mm       |     at readableAddChunk (_stream_readable.js:178:18)
                                  0|mm       |     at Socket.Readable.push (_stream_readable.js:136:10)
                                  0|mm       |     at Pipe.onread (net.js:560:20)
                                  And …
                                    beck0r
                                    still the same ;-(
                                    • E Offline
                                      ezarlive
                                      Updated to last github version seems to work!
                                        beck0r
                                        not for me… still the same error message in debug.log
                                        pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                                          @beck0r said in MMM-voice:
                                          Try getting rid of pocketsphinx and reinstalling it…
                                          • tbbearT Offline
                                            tbbear Module Developer
                                            im cant understand the problem i have:
                                            First i can arecord and aplay without any problems with my usb audio device.
                                            But when i try to use MMM-voice i always get:
                                            (snipet from the debug file)
                                            INFO: lm_trie.c(482): Building LM trie
                                            INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                            INFO: ngram_search_fwdtree.c(101): 32 unique initial diphones
                                            INFO: ngram_search_fwdtree.c(186): Creating search channels
                                            INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 168
                                            INFO: ngram_search_fwdtree.c(333): Created 32 root, 40 non-root channels, 5 single-phone words
                                            INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                            INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Jan 6 2018, AT: 13:45:05
                                            Error opening audio device plughw:0 for capture: Connection refused
                                            FATAL: “continuous.c”, line 245: Failed to open audio device
                                            Please help me !!!
                                            Robert the Bear
                                            tbbearT 1 Reply Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
