    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Rattenjunge8080
      @Rattenjunge8080 Yeah I’m not seeing that… it wouldn’t crash your system or RPI. It would have to change the Raspbian operating system to do that and it doesn’t touch that… so it’s very possible you could have an SD card going South…
        beck0r
        Hi there,
        could you have a look with us on this ?
        MMM-Voice libpocketsphinx.so.3: cannot open shared object file: No such file or directory[update]
        Thank you
        Kind Regards
        • cowboysdudeC
          cowboysdude Module Developer @beck0r
          @beck0r Same thing I would delete pocketsphinx and reinstall it…
          B 2 Replies Last reply
            beck0r @cowboysdude
            @cowboysdude
            I have removed the folder pocketsphinx with rm -r. This did not feel right ;)
            Since I’m quite new to linux… could you please describe me the proper way to remove the needed components?
            Sorry if I may have overlooked something around here. A lot of posts for a newcomer.
            Thank you very much
              beck0r @cowboysdude
              @cowboysdude
              Update:
              Ran bash dependencies.sh again and reinstalled sphinx but still the same output in the debug log.
              • cowboysdudeC
                You’re doing it correctly just not sure why you’re getting those results.
                I would, if I were you, delete the entire thing… start over. Something is getting corrupt.
                B 1 Reply Last reply
                  beck0r @cowboysdude
                  @cowboysdude
                  I did that, still the same… here’s what “npm start dev” is showing me right now
                  TypeError: this.sendSocketNotification is not a function
                      at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
                      at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
                      at FSReqWrap.oncomplete (fs.js:112:15)
                  TypeError: Cannot read property 'debug' of undefined
                      at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
                      at emitOne (events.js:96:13)
                      at PocketSphinxContinuous.emit (events.js:188:7)
                      at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
                      at Socket.emit (events.js:188:7)
                      at readableAddChunk (_stream_readable.js:176:18)
                      at Socket.Readable.push (_stream_readable.js:134:10)
                      at Pipe.onread (net.js:551:20)
                  So if anybody has an idea let met know :)
                  E 1 Reply Last reply
                  • E
                    ezarlive @beck0r
                    @beck0r Same error here:
                    1|mm | MMM-voice: Checking files.
                    1|mm | MMM-voice: Starting pocketsphinx.
                    1|mm | Whoops! There was an uncaught exception...
                    1|mm | TypeError: this.sendSocketNotification is not a function
                    1|mm | at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
                    1|mm | at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
                    1|mm | at FSReqWrap.oncomplete (fs.js:112:15)
                    • E
                      ezarlive
                      Nothing to do with this module.
                      It doesnt works :(
                      Fails everytime.
                      0|mm       | TypeError: Cannot read property 'debug' of undefined
                      0|mm       |     at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
                      0|mm       |     at emitOne (events.js:96:13)
                      0|mm       |     at PocketSphinxContinuous.emit (events.js:191:7)
                      0|mm       |     at Socket. (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
                      0|mm       |     at Socket.emit (events.js:191:7)
                      0|mm       |     at readableAddChunk (_stream_readable.js:178:18)
                      0|mm       |     at Socket.Readable.push (_stream_readable.js:136:10)
                      0|mm       |     at Pipe.onread (net.js:560:20)
                      And …
                        beck0r
                        still the same ;-(
                        • E
                          ezarlive
                          Updated to last github version seems to work!
                            beck0r
                            not for me… still the same error message in debug.log
                            pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                            • cowboysdudeC
                              @beck0r said in MMM-voice:
                              Try getting rid of pocketsphinx and reinstalling it…
                              • tbbearT
                                tbbear Module Developer
                                im cant understand the problem i have:
                                First i can arecord and aplay without any problems with my usb audio device.
                                But when i try to use MMM-voice i always get:
                                (snipet from the debug file)
                                INFO: lm_trie.c(482): Building LM trie
                                INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                INFO: ngram_search_fwdtree.c(101): 32 unique initial diphones
                                INFO: ngram_search_fwdtree.c(186): Creating search channels
                                INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 168
                                INFO: ngram_search_fwdtree.c(333): Created 32 root, 40 non-root channels, 5 single-phone words
                                INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Jan 6 2018, AT: 13:45:05
                                Error opening audio device plughw:0 for capture: Connection refused
                                FATAL: “continuous.c”, line 245: Failed to open audio device
                                Please help me !!!
                                Robert the Bear
                                tbbearT 1 Reply Last reply
                                • tbbearT
                                  tbbear Module Developer @tbbear
                                  @tbbear Its always the same, better look twice before asking. I found one old pulseaudio.h file and this was the problem. Everything works fine now and i can start to work on supporting my MMM-Openhab with MMM-voice.
                                  Robert the Bear
                                  Mykle1M 1 Reply Last reply
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @tbbear
                                    @tbbear said in MMM-voice:
                                    Haha Robert. It ALWAYS happens that way, doesn’t it? :-)
                                    Glad you found it now get to work. ;-)
                                    • A
                                      AxLed Module Developer
                                      Hi Strawberry,
                                      do you know, if i can change the language of MMM-voice with Pocketsphinx / Sphinxbase to german?
                                      I found a webseite where i can create .dic and .lm files and they work somehow (i also changed the new words in different .js files of folder MMM-voice).
                                      I am looking forward hearing from you.
                                      Regards
                                      AxLED
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @AxLed
                                        @AxLed https://cmusphinx.github.io/wiki/faq/#q-which-languages-are-supported
                                        A 1 Reply Last reply
                                          Peter
                                          I would like to have this module working, but up till now no succes.
                                          It is a bit confusing.
                                          It says MagicMirror/modules/MMM-voice/ installers as a directory, but after cloning it says: MMM-voice-master.
                                          So I tried both directories; MMM-voice and MMM-voice-master.
                                          Both did not work.
                                          Do I have to see a voice symbol on the screen?
                                          I tried the commands: Magic Mirror, Voice, go to sleep.
                                          Nothing happens.
                                          I have a USB microfone connected as microphone 1.
                                          Installing the module seemed to be ok.
                                          Only in the end: step 6/6; No such file or directory.
                                          Any help would be appreciated.
                                          Peter
                                          Mykle1M strawberry 3.141S 2 Replies Last reply
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Peter
                                            @Peter
                                            I was in hospital for a few days. :-(
                                            When you clone MMM-voice into your modules folder, the “installers” folder is inside of that. The readme in the repo gives directions for installation
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
