    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      beck0r
      Hi there,
      could you have a look with us on this ?
      MMM-Voice libpocketsphinx.so.3: cannot open shared object file: No such file or directory[update]
      Thank you
      Kind Regards
      • cowboysdudeC
        cowboysdude Module Developer @beck0r
        @beck0r Same thing I would delete pocketsphinx and reinstall it…
        B 2 Replies Last reply
          beck0r @cowboysdude
          @cowboysdude
          I have removed the folder pocketsphinx with rm -r. This did not feel right ;)
          Since I’m quite new to linux… could you please describe me the proper way to remove the needed components?
          Sorry if I may have overlooked something around here. A lot of posts for a newcomer.
          Thank you very much
            beck0r @cowboysdude
            @cowboysdude
            Update:
            Ran bash dependencies.sh again and reinstalled sphinx but still the same output in the debug log.
            • cowboysdudeC
              You’re doing it correctly just not sure why you’re getting those results.
              I would, if I were you, delete the entire thing… start over. Something is getting corrupt.
              B 1 Reply Last reply
                beck0r @cowboysdude
                @cowboysdude
                I did that, still the same… here’s what “npm start dev” is showing me right now
                TypeError: this.sendSocketNotification is not a function
                    at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
                    at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
                    at FSReqWrap.oncomplete (fs.js:112:15)
                TypeError: Cannot read property 'debug' of undefined
                    at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
                    at emitOne (events.js:96:13)
                    at PocketSphinxContinuous.emit (events.js:188:7)
                    at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
                    at Socket.emit (events.js:188:7)
                    at readableAddChunk (_stream_readable.js:176:18)
                    at Socket.Readable.push (_stream_readable.js:134:10)
                    at Pipe.onread (net.js:551:20)
                So if anybody has an idea let met know :)
                E 1 Reply Last reply
                • E
                  ezarlive @beck0r
                  @beck0r Same error here:
                  1|mm | MMM-voice: Checking files.
                  1|mm | MMM-voice: Starting pocketsphinx.
                  1|mm | Whoops! There was an uncaught exception...
                  1|mm | TypeError: this.sendSocketNotification is not a function
                  1|mm | at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
                  1|mm | at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
                  1|mm | at FSReqWrap.oncomplete (fs.js:112:15)
                  • E
                    ezarlive
                    Nothing to do with this module.
                    It doesnt works :(
                    Fails everytime.
                    0|mm       | TypeError: Cannot read property 'debug' of undefined
                    0|mm       |     at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
                    0|mm       |     at emitOne (events.js:96:13)
                    0|mm       |     at PocketSphinxContinuous.emit (events.js:191:7)
                    0|mm       |     at Socket. (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
                    0|mm       |     at Socket.emit (events.js:191:7)
                    0|mm       |     at readableAddChunk (_stream_readable.js:178:18)
                    0|mm       |     at Socket.Readable.push (_stream_readable.js:136:10)
                    0|mm       |     at Pipe.onread (net.js:560:20)
                    And …
                      beck0r
                      still the same ;-(
                      • E
                        ezarlive
                        Updated to last github version seems to work!
                          beck0r
                          not for me… still the same error message in debug.log
                          pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                          • cowboysdudeC
                            @beck0r said in MMM-voice:
                            Try getting rid of pocketsphinx and reinstalling it…
                            • tbbearT
                              tbbear Module Developer
                              im cant understand the problem i have:
                              First i can arecord and aplay without any problems with my usb audio device.
                              But when i try to use MMM-voice i always get:
                              (snipet from the debug file)
                              INFO: lm_trie.c(482): Building LM trie
                              INFO: ngram_search_fwdtree.c(74): Initializing search tree
                              INFO: ngram_search_fwdtree.c(101): 32 unique initial diphones
                              INFO: ngram_search_fwdtree.c(186): Creating search channels
                              INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 168
                              INFO: ngram_search_fwdtree.c(333): Created 32 root, 40 non-root channels, 5 single-phone words
                              INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                              INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Jan 6 2018, AT: 13:45:05
                              Error opening audio device plughw:0 for capture: Connection refused
                              FATAL: “continuous.c”, line 245: Failed to open audio device
                              Please help me !!!
                              Robert the Bear
                              tbbearT 1 Reply Last reply
                              • tbbearT
                                tbbear Module Developer @tbbear
                                @tbbear Its always the same, better look twice before asking. I found one old pulseaudio.h file and this was the problem. Everything works fine now and i can start to work on supporting my MMM-Openhab with MMM-voice.
                                Robert the Bear
                                Mykle1M 1 Reply Last reply
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @tbbear
                                  @tbbear said in MMM-voice:
                                  Haha Robert. It ALWAYS happens that way, doesn’t it? :-)
                                  Glad you found it now get to work. ;-)
                                  • A
                                    AxLed Module Developer
                                    Hi Strawberry,
                                    do you know, if i can change the language of MMM-voice with Pocketsphinx / Sphinxbase to german?
                                    I found a webseite where i can create .dic and .lm files and they work somehow (i also changed the new words in different .js files of folder MMM-voice).
                                    I am looking forward hearing from you.
                                    Regards
                                    AxLED
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @AxLed
                                      @AxLed https://cmusphinx.github.io/wiki/faq/#q-which-languages-are-supported
                                      A 1 Reply Last reply
                                        Peter
                                        I would like to have this module working, but up till now no succes.
                                        It is a bit confusing.
                                        It says MagicMirror/modules/MMM-voice/ installers as a directory, but after cloning it says: MMM-voice-master.
                                        So I tried both directories; MMM-voice and MMM-voice-master.
                                        Both did not work.
                                        Do I have to see a voice symbol on the screen?
                                        I tried the commands: Magic Mirror, Voice, go to sleep.
                                        Nothing happens.
                                        I have a USB microfone connected as microphone 1.
                                        Installing the module seemed to be ok.
                                        Only in the end: step 6/6; No such file or directory.
                                        Any help would be appreciated.
                                        Peter
                                        Mykle1M strawberry 3.141S 2 Replies Last reply
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @Peter
                                          @Peter
                                          I was in hospital for a few days. :-(
                                          When you clone MMM-voice into your modules folder, the “installers” folder is inside of that. The readme in the repo gives directions for installation
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @Peter
                                            @Peter if you clone the repository the directory is called MMM-voice, only when you manually download it it will be name MMM-voice-master and that isnt cloning.
                                            it looks like youre trying to use an old version, as the current one (since august last year) had just 5 steps in the installer not 6
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
