    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      AxLed Module Developer
      Hi Strawberry,
      do you know, if i can change the language of MMM-voice with Pocketsphinx / Sphinxbase to german?
      I found a webseite where i can create .dic and .lm files and they work somehow (i also changed the new words in different .js files of folder MMM-voice).
      I am looking forward hearing from you.
      Regards
      AxLED
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @AxLed
        @AxLed https://cmusphinx.github.io/wiki/faq/#q-which-languages-are-supported
          Peter
          I would like to have this module working, but up till now no succes.
          It is a bit confusing.
          It says MagicMirror/modules/MMM-voice/ installers as a directory, but after cloning it says: MMM-voice-master.
          So I tried both directories; MMM-voice and MMM-voice-master.
          Both did not work.
          Do I have to see a voice symbol on the screen?
          I tried the commands: Magic Mirror, Voice, go to sleep.
          Nothing happens.
          I have a USB microfone connected as microphone 1.
          Installing the module seemed to be ok.
          Only in the end: step 6/6; No such file or directory.
          Any help would be appreciated.
          Peter
          Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @Peter
            @Peter
            I was in hospital for a few days. :-(
            When you clone MMM-voice into your modules folder, the “installers” folder is inside of that. The readme in the repo gives directions for installation
              strawberry 3.141 Project Sponsor Module Developer @Peter
              @Peter if you clone the repository the directory is called MMM-voice, only when you manually download it it will be name MMM-voice-master and that isnt cloning.
              it looks like youre trying to use an old version, as the current one (since august last year) had just 5 steps in the installer not 6
                Peter
                Mykle1: hope you are doing allright! You are a good help to me from the beginning of my project.
                Strawberry: you are right; I did not clone but downloaded!
                Maybe that is the problem.
                A working day is waiting, but after that I will try cloning (have to do some research how to).
                I hope it will work!
                Thanks!
                Peter
                  @Peter type this in your terminal
                  cd ~/MagicMirror/modules
                  git clone https://github.com/fewieden/MMM-voice.git
                  then follow the instructions here
                    Peter @strawberry 3.141
                    @strawberry-3.141 cloning went well!
                    No step 6, so this was the right version.
                    I can see a microphone on the screen (with the word ERROR).
                    I still have to find out where the error comes from.
                    Thanks for all your help!
                    Peter
                      Peter
                      Errorlog:127
                      Debuglog: pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                      Why is it so hard to get this working?
                      Peter
                        @Peter said in MMM-voice:
                        Maybe this will help you. It has helped a few people get up and running.
                        Assuming you installed the dependencies as per the readme. At the end of the dependencies installation is a readout for your microphone entry in the config.js. You can see this readout again. in your terminal type: cat /proc/asound/cards. You can verify your microphone this way.
                        And this should remove the error that you are receiving. Close all your terminals.
                        Open a new terminal.
                        type: LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib and Enter
                        Then type: sudo ldconfig and Enter
                        Now try it. Good luck
                        P 4lice4 ArzegA 3 Replies Last reply Reply Quote 1
                          Peter @Mykle1
                          @Mykle1 magic!
                          It works!
                          Thanks!
                          Peter
                            @Peter
                            The real magic comes from Strawberry. :-)
                            Glad you got it working. :-)
                            • Cyberdale008C Offline
                              Cyberdale008
                              Hi folks, usually don’t post. Just read a lot. But I am a lil over my head here. ASE Certified Master Mechanic here, but dang this coding is tough!! This module works fantasic. However I would like to change this ( /opt/vc/bin/tvservice -p && sudo chvt 6 && sudo chvt 7 ) to this ( /opt/vc/bin/vcgencmd display_power 1 ) and ( /opt/vc/bin/tvservice -o’, null ) to this ( /opt/vc/bin/vcgencmd display_power 0 ) I just want the tv to go off, I don’t want the no signal or light off the screen to show up. Is this even possible. Thanks in advance for any help!!
                              • cowboysdudeC Offline
                                cowboysdude Module Developer @Cyberdale008
                                @Cyberdale008 sure it is…just to the node_helper and change it.
                                Look for these lines :
                                } else if (/(WAKE)/g.test(data) && /(UP)/g.test(data)) {
                                           exec('/opt/vc/bin/tvservice -p && sudo chvt 6 && sudo chvt 7', null);
                                           this.hdmi = true;
                                       } else if (/(GO)/g.test(data) && /(SLEEP)/g.test(data)) {
                                           exec('/opt/vc/bin/tvservice -o', null);
                                and make your changes :)
                                  AxLed Module Developer @strawberry 3.141
                                  @strawberry-3.141 said in MMM-voice:
                                  @strawberrxyy 3.141
                                  I tried to change the language to german / german voice recognition with some informations from here:
                                  https://mycroft.ai/documentation/language-support/german/
                                  but my skills a not good enough to get it working.
                                  3 more questions:
                                  Is there a command for commandline to test Pocketsphinx and its components, so maybe i can find out where i went in the wrong direction.
                                  Do i need for changing the language model only have to download certain files and bring them in the right structure or do i have to compile something afterwards?
                                  Where could i change the path to other language models in MMM-voice, i only found links to the .lm an .dic file but not to the .../model/en-us/ structure.
                                  AxLED
                                    @AxLed
                                    1. pocketsphinx_continuous
                                    2. You need to look for instructions where you downloaded those files
                                    3. you can specify the language model with the option -hmm in the node dependencie pocketsphinx-continuous-node
                                      maxbachmann
                                      In case you get it running in German can you share it?
                                      could really use this as well :)
                                      Max
                                        strawberry 3.141 Project Sponsor Module Developer @maxbachmann
                                        @maxbachmann even if he’s able to get german running are the commands and supported modules only working with english, to make this possible there is a big effort necessary, that I cannot put in anymore
                                        prs are highly welcome for this, but make sure to discuss possible implementations upfront, to avoid getting the pull request rejected
                                          maxbachmann
                                          oh I mean that in case he manages it he could share it :)
                                          I will probably go with the english voice control for now because there are already many working modules out there
                                          tbbearT 1 Reply Last reply Reply Quote 0
                                          • tbbearT Offline
                                            tbbear Module Developer @maxbachmann
                                            @maxbachmann
                                            Hi, the modules get signals to act and it realy doesnt matter in with language u use the voice.
                                            By the way i am also interested if u get it working in german
                                            Robert the Bear
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
