    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      beck0r @cowboysdude
      @cowboysdude
      I did that, still the same… here’s what “npm start dev” is showing me right now
      TypeError: this.sendSocketNotification is not a function
          at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
          at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
          at FSReqWrap.oncomplete (fs.js:112:15)
      TypeError: Cannot read property 'debug' of undefined
          at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
          at emitOne (events.js:96:13)
          at PocketSphinxContinuous.emit (events.js:188:7)
          at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
          at Socket.emit (events.js:188:7)
          at readableAddChunk (_stream_readable.js:176:18)
          at Socket.Readable.push (_stream_readable.js:134:10)
          at Pipe.onread (net.js:551:20)
      So if anybody has an idea let met know :)
      • E
        ezarlive @beck0r
        @beck0r Same error here:
        1|mm | MMM-voice: Checking files.
        1|mm | MMM-voice: Starting pocketsphinx.
        1|mm | Whoops! There was an uncaught exception...
        1|mm | TypeError: this.sendSocketNotification is not a function
        1|mm | at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
        1|mm | at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
        1|mm | at FSReqWrap.oncomplete (fs.js:112:15)
        • E
          ezarlive
          Nothing to do with this module.
          It doesnt works :(
          Fails everytime.
          0|mm       | TypeError: Cannot read property 'debug' of undefined
          0|mm       |     at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
          0|mm       |     at emitOne (events.js:96:13)
          0|mm       |     at PocketSphinxContinuous.emit (events.js:191:7)
          0|mm       |     at Socket. (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
          0|mm       |     at Socket.emit (events.js:191:7)
          0|mm       |     at readableAddChunk (_stream_readable.js:178:18)
          0|mm       |     at Socket.Readable.push (_stream_readable.js:136:10)
          0|mm       |     at Pipe.onread (net.js:560:20)
          And …
            beck0r
            still the same ;-(
            • E
              ezarlive
              Updated to last github version seems to work!
                beck0r
                not for me… still the same error message in debug.log
                pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                • cowboysdudeC
                  cowboysdude Module Developer @beck0r
                  @beck0r said in MMM-voice:
                  Try getting rid of pocketsphinx and reinstalling it…
                  • tbbearT
                    tbbear Module Developer
                    im cant understand the problem i have:
                    First i can arecord and aplay without any problems with my usb audio device.
                    But when i try to use MMM-voice i always get:
                    (snipet from the debug file)
                    INFO: lm_trie.c(482): Building LM trie
                    INFO: ngram_search_fwdtree.c(74): Initializing search tree
                    INFO: ngram_search_fwdtree.c(101): 32 unique initial diphones
                    INFO: ngram_search_fwdtree.c(186): Creating search channels
                    INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 168
                    INFO: ngram_search_fwdtree.c(333): Created 32 root, 40 non-root channels, 5 single-phone words
                    INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                    INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Jan 6 2018, AT: 13:45:05
                    Error opening audio device plughw:0 for capture: Connection refused
                    FATAL: “continuous.c”, line 245: Failed to open audio device
                    Please help me !!!
                    Robert the Bear
                    tbbearT 1 Reply Last reply Reply Quote 0
                    • tbbearT
                      tbbear Module Developer @tbbear
                      @tbbear Its always the same, better look twice before asking. I found one old pulseaudio.h file and this was the problem. Everything works fine now and i can start to work on supporting my MMM-Openhab with MMM-voice.
                      Robert the Bear
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @tbbear
                        @tbbear said in MMM-voice:
                        Haha Robert. It ALWAYS happens that way, doesn’t it? :-)
                        Glad you found it now get to work. ;-)
                        • A
                          AxLed Module Developer
                          Hi Strawberry,
                          do you know, if i can change the language of MMM-voice with Pocketsphinx / Sphinxbase to german?
                          I found a webseite where i can create .dic and .lm files and they work somehow (i also changed the new words in different .js files of folder MMM-voice).
                          I am looking forward hearing from you.
                          Regards
                          AxLED
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @AxLed
                            @AxLed https://cmusphinx.github.io/wiki/faq/#q-which-languages-are-supported
                              Peter
                              I would like to have this module working, but up till now no succes.
                              It is a bit confusing.
                              It says MagicMirror/modules/MMM-voice/ installers as a directory, but after cloning it says: MMM-voice-master.
                              So I tried both directories; MMM-voice and MMM-voice-master.
                              Both did not work.
                              Do I have to see a voice symbol on the screen?
                              I tried the commands: Magic Mirror, Voice, go to sleep.
                              Nothing happens.
                              I have a USB microfone connected as microphone 1.
                              Installing the module seemed to be ok.
                              Only in the end: step 6/6; No such file or directory.
                              Any help would be appreciated.
                              Peter
                              Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @Peter
                                @Peter
                                I was in hospital for a few days. :-(
                                When you clone MMM-voice into your modules folder, the “installers” folder is inside of that. The readme in the repo gives directions for installation
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @Peter
                                  @Peter if you clone the repository the directory is called MMM-voice, only when you manually download it it will be name MMM-voice-master and that isnt cloning.
                                  it looks like youre trying to use an old version, as the current one (since august last year) had just 5 steps in the installer not 6
                                    Peter
                                    Mykle1: hope you are doing allright! You are a good help to me from the beginning of my project.
                                    Strawberry: you are right; I did not clone but downloaded!
                                    Maybe that is the problem.
                                    A working day is waiting, but after that I will try cloning (have to do some research how to).
                                    I hope it will work!
                                    Thanks!
                                    Peter
                                    • strawberry 3.141S
                                      @Peter type this in your terminal
                                      cd ~/MagicMirror/modules
                                      git clone https://github.com/fewieden/MMM-voice.git
                                      then follow the instructions here
                                        Peter @strawberry 3.141
                                        @strawberry-3.141 cloning went well!
                                        No step 6, so this was the right version.
                                        I can see a microphone on the screen (with the word ERROR).
                                        I still have to find out where the error comes from.
                                        Thanks for all your help!
                                        Peter
                                          Peter
                                          Errorlog:127
                                          Debuglog: pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
                                          Why is it so hard to get this working?
                                          Peter
                                          • Mykle1M
                                            @Peter said in MMM-voice:
                                            Maybe this will help you. It has helped a few people get up and running.
                                            Assuming you installed the dependencies as per the readme. At the end of the dependencies installation is a readout for your microphone entry in the config.js. You can see this readout again. in your terminal type: cat /proc/asound/cards. You can verify your microphone this way.
                                            And this should remove the error that you are receiving. Close all your terminals.
                                            Open a new terminal.
                                            type: LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib and Enter
                                            Then type: sudo ldconfig and Enter
                                            Now try it. Good luck
                                            P 4lice4 ArzegA 3 Replies Last reply Reply Quote 1
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
