    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      pepemujica @strawberry 3.141
      @strawberry-3.141 Hi! I was verry busy with work. Any way, Is it possible to hide or show specific modules, such as show/hide clock or weather? Or to change profile with profileswitcher?
      Kind regards
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @pepemujica
        @pepemujica that is not possible atm
        P 1 Reply Last reply
          @strawberry-3.141 So, what’s the final purpose of this module, sorry I can’t get in to it
          • strawberry 3.141S
            @pepemujica atm you can control the following modules (mmm-soccer, mmm-fuel, mmm-nhl and mmm-ip)
            and some basic commands in the voice module itself
            COMMANDS:
            • HIDE MODULES
            • SHOW MODULES
            • WAKE UP
            • GO TO SLEEP
            • OPEN HELP
            • CLOSE HELP
              pawpawsoswag
              im having a problem with this module i try to speak the magic mirror-> then go to command like “GO TO SLEEP” but nothing will happen also when i speak the command “Magic Mirror” then the mic flashing it does nothing
              A 1 Reply Last reply
              • A
                Advokaten @pawpawsoswag
                @pawpawsoswag try saying “MAGIC MIRROR VOICE”
                  pawpawsoswag @Advokaten
                  @Advokaten still not working :(
                  • A
                    @pawpawsoswag MAGIC MIRROR VOICE OPEN HELP? Maybe pause a bit before saying “VOICE”?
                      Rattenjunge8080
                      maybe someone can help me…I installed this module and when I starting the Magic Mirror, everything seems to be fine.
                      But since I installed this Module, my microfone and the audio output is not working anymore (I tested the microfone and the speaker before I installed this module).
                      Iḿ using a USB-Dongle and like I sayed, everything was fine until I installed this module.
                      When I choose the “Audio Device Setting”, I can choose between “bcm2385 ALSA” and “USB PnP Sound Device”. Both are not working anymore.
                      Someone have some advise?
                      Thank you very much.
                      • cowboysdudeC
                        cowboysdude Module Developer @Rattenjunge8080
                        @Rattenjunge8080 Did you get any install errors?
                        R 1 Reply Last reply
                          Rattenjunge8080 @cowboysdude
                          @cowboysdude no, there were no errors and the module is appearing in the UI of the Mirror.
                          I think it has something to do with the pocketsphinx Software-> cause this problem seems to happend often for people using USB-Sound devices on Raspian Jesse. It changes the priority of the Sound devices for some reason…
                          • cowboysdudeC
                            That’s odd because I had no issues myself. Delete the pocketsphinx and run npm install again
                              @cowboysdude Didn’t worked. I think this module let my RPI crash (more like: changes in my system were made, which I cannot set back).
                              I will bet a backup and try again.
                              Thanks for your help!
                              • cowboysdudeC
                                @Rattenjunge8080 Yeah I’m not seeing that… it wouldn’t crash your system or RPI. It would have to change the Raspbian operating system to do that and it doesn’t touch that… so it’s very possible you could have an SD card going South…
                                  beck0r
                                  Hi there,
                                  could you have a look with us on this ?
                                  MMM-Voice libpocketsphinx.so.3: cannot open shared object file: No such file or directory[update]
                                  Thank you
                                  Kind Regards
                                  • cowboysdudeC
                                    cowboysdude Module Developer @beck0r
                                    @beck0r Same thing I would delete pocketsphinx and reinstall it…
                                    B 2 Replies Last reply
                                      beck0r @cowboysdude
                                      @cowboysdude
                                      I have removed the folder pocketsphinx with rm -r. This did not feel right ;)
                                      Since I’m quite new to linux… could you please describe me the proper way to remove the needed components?
                                      Sorry if I may have overlooked something around here. A lot of posts for a newcomer.
                                      Thank you very much
                                        beck0r @cowboysdude
                                        @cowboysdude
                                        Update:
                                        Ran bash dependencies.sh again and reinstalled sphinx but still the same output in the debug log.
                                        • cowboysdudeC
                                          You’re doing it correctly just not sure why you’re getting those results.
                                          I would, if I were you, delete the entire thing… start over. Something is getting corrupt.
                                          B 1 Reply Last reply
                                            beck0r @cowboysdude
                                            @cowboysdude
                                            I did that, still the same… here’s what “npm start dev” is showing me right now
                                            TypeError: this.sendSocketNotification is not a function
                                                at fs.appendFile (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:311:22)
                                                at /home/pi/MagicMirror/modules/MMM-voice/node_modules/graceful-fs/graceful-fs.js:43:10
                                                at FSReqWrap.oncomplete (fs.js:112:15)
                                            TypeError: Cannot read property 'debug' of undefined
                                                at PocketSphinxContinuous.handleData (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:247:28)
                                                at emitOne (events.js:96:13)
                                                at PocketSphinxContinuous.emit (events.js:188:7)
                                                at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous/index.js:39:11)
                                                at Socket.emit (events.js:188:7)
                                                at readableAddChunk (_stream_readable.js:176:18)
                                                at Socket.Readable.push (_stream_readable.js:134:10)
                                                at Pipe.onread (net.js:551:20)
                                            So if anybody has an idea let met know :)
                                            E 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
