    MMM-voice
    voice control
    329 Posts 55 Posters 1.0m Views 50 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @pepemujica
      @pepemujica you have to enter voice mode first
        pepemujica @strawberry 3.141
        @strawberry-3.141 how do I do that? Is there any tutorial?
          @pepemujica saying the keyword followed by the mode you want to enter https://github.com/fewieden/MMM-voice#usage
            @strawberry-3.141 GOD!!! I’ve change a module and now I get error again ):
            Despite of that, I’ve said Magic Mirror Open Help, and nothing happen
              @pepemujica you still didnt enter the mode yet
                @strawberry-3.141 Could you give me an example please?
                  @pepemujica MAGIC MIRROR VOICE OPEN HELP
                    Advokaten
                    A fresh install of Jessie and MM and this module works without any problems whatsoever. Awesome!
                      @strawberry-3.141 Hi! I was verry busy with work. Any way, Is it possible to hide or show specific modules, such as show/hide clock or weather? Or to change profile with profileswitcher?
                      Kind regards
                        @pepemujica that is not possible atm
                          @strawberry-3.141 So, what’s the final purpose of this module, sorry I can’t get in to it
                            @pepemujica atm you can control the following modules (mmm-soccer, mmm-fuel, mmm-nhl and mmm-ip)
                            and some basic commands in the voice module itself
                            COMMANDS:
                            • HIDE MODULES
                            • SHOW MODULES
                            • WAKE UP
                            • GO TO SLEEP
                            • OPEN HELP
                            • CLOSE HELP
                              pawpawsoswag
                              im having a problem with this module i try to speak the magic mirror-> then go to command like “GO TO SLEEP” but nothing will happen also when i speak the command “Magic Mirror” then the mic flashing it does nothing
                                Advokaten @pawpawsoswag
                                @pawpawsoswag try saying “MAGIC MIRROR VOICE”
                                  pawpawsoswag @Advokaten
                                  @Advokaten still not working :(
                                    @pawpawsoswag MAGIC MIRROR VOICE OPEN HELP? Maybe pause a bit before saying “VOICE”?
                                      Rattenjunge8080
                                      maybe someone can help me…I installed this module and when I starting the Magic Mirror, everything seems to be fine.
                                      But since I installed this Module, my microfone and the audio output is not working anymore (I tested the microfone and the speaker before I installed this module).
                                      Iḿ using a USB-Dongle and like I sayed, everything was fine until I installed this module.
                                      When I choose the “Audio Device Setting”, I can choose between “bcm2385 ALSA” and “USB PnP Sound Device”. Both are not working anymore.
                                      Someone have some advise?
                                      Thank you very much.
                                      • cowboysdudeC Offline
                                        cowboysdude Module Developer @Rattenjunge8080
                                        @Rattenjunge8080 Did you get any install errors?
                                          Rattenjunge8080 @cowboysdude
                                          @cowboysdude no, there were no errors and the module is appearing in the UI of the Mirror.
                                          I think it has something to do with the pocketsphinx Software-> cause this problem seems to happend often for people using USB-Sound devices on Raspian Jesse. It changes the priority of the Sound devices for some reason…
                                            That’s odd because I had no issues myself. Delete the pocketsphinx and run npm install again
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
