    MMM-voice
    voice control
    329 Posts 55 Posters 995.3k Views 50 Watching
      Advokaten
      A fresh install of Jessie and MM and this module works without any problems whatsoever. Awesome!
        pepemujica @strawberry 3.141
        @strawberry-3.141 Hi! I was verry busy with work. Any way, Is it possible to hide or show specific modules, such as show/hide clock or weather? Or to change profile with profileswitcher?
        Kind regards
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @pepemujica
          @pepemujica that is not possible atm
            @strawberry-3.141 So, what’s the final purpose of this module, sorry I can’t get in to it
              @pepemujica atm you can control the following modules (mmm-soccer, mmm-fuel, mmm-nhl and mmm-ip)
              and some basic commands in the voice module itself
              COMMANDS:
              • HIDE MODULES
              • SHOW MODULES
              • WAKE UP
              • GO TO SLEEP
              • OPEN HELP
              • CLOSE HELP
                pawpawsoswag
                im having a problem with this module i try to speak the magic mirror-> then go to command like “GO TO SLEEP” but nothing will happen also when i speak the command “Magic Mirror” then the mic flashing it does nothing
                  Advokaten @pawpawsoswag
                  @pawpawsoswag try saying “MAGIC MIRROR VOICE”
                    pawpawsoswag @Advokaten
                    @Advokaten still not working :(
                      @pawpawsoswag MAGIC MIRROR VOICE OPEN HELP? Maybe pause a bit before saying “VOICE”?
                        Rattenjunge8080
                        maybe someone can help me…I installed this module and when I starting the Magic Mirror, everything seems to be fine.
                        But since I installed this Module, my microfone and the audio output is not working anymore (I tested the microfone and the speaker before I installed this module).
                        Iḿ using a USB-Dongle and like I sayed, everything was fine until I installed this module.
                        When I choose the “Audio Device Setting”, I can choose between “bcm2385 ALSA” and “USB PnP Sound Device”. Both are not working anymore.
                        Someone have some advise?
                        Thank you very much.
                        • 21
                        • 22
                        • 23
                        • 24
                        • 25
                        • 32
                        • 33
                        • 23 / 33
