    Jake's Magic Mirror (Done)
    20 Posts 11 Posters 21.1k Views 11 Watching
    • iMAGiCI Offline
      iMAGiC
      Hi all,
      Yes, sorry!! as you can see, it still under construction. I will use it on 37~50 inch monitor in my living room.
      I got “one way mirror” for testing today, I don’t really know how to call it eventually.
      In the photo, it looks great, but when I use my eyes to see it, it isn’t like a real mirror, something like “black mirror”?!
      Can anyone suggest me that what mirror or solution can fix this problem? or it can’t be a real mirror for everyday use my wife says…
      Thanks in advance !!!
      iMAGiCJAKE
      Choice * Judgment * Values
      1 Reply Last reply Reply Quote 4
        A Former User
        it is very impotant, that the black of your monitor is really dark. If the black is bad, the mirror can not do his job, because every light behind the mirror reduces the mirror effect. For a good result it is also important, that the monitor is bright, but your one looks very bright. I think, that it is very hard to find a perfect mirror. My mirror has also a black touch. Maybe it is normal, because it is no normal mirror.
        iMAGiCI 1 Reply Last reply Reply Quote 0
        • MichMichM Offline
          MichMich
          Offtopic: It’s so freaking cool to see a Chinese(?) version of my mirror! :)
          iMAGiCI MariaHTM 2 Replies Last reply Reply Quote 4
          • iMAGiCI Offline
            iMAGiC @MichMich
            @MichMich Yes, it’s Chinese version of your mirror, I like it, thank you very much. :)
            • iMAGiCI Offline
              iMAGiC @Guest
              @builer Yes, I tried 2 way mirror and even Window Films(for car), still can’t reach what I need. :(
              • bheplerB Offline
                bhepler Module Developer
                I think the issue with your “black mirror” is more an issue with lighting in front of the mirror. Turn the monitor off and put the mirror in a bright area. Preferably with strong daylight. I predict the “black mirror” issue will resolve itself.
                iMAGiCI CatoC 2 Replies Last reply Reply Quote 0
                • iMAGiCI Offline
                  iMAGiC @bhepler
                  @bhepler thanks for your comment, but I think the problem is not comes from environment.
                  I did a comparison table, as you can see, no one can use for vanity as my wife said.
                  I may choose #4 for house decoration at end this year. but it is expensive and sensitive parts in Taiwan (you should know, the bad guy use it for “Candid camera” behind glass). And, I don’t know if I use #2 for vanity table my wife will accept…
                  • CatoC Offline
                    Cato Module Developer @bhepler
                    @bhepler I’m afraid it’s probably not the issue. I had the same problem when I replaced a mirror on the bathroom. It was just too dark compared to the one it replaced. The lighting where the same…
                    • iMAGiCI Offline
                      iMAGiC
                      Hi ~
                      Time flies, my new house has been started decorating. Just bought 50" TV for wall mount perpetration and double check installation to avoid any problem.
                      My Magicmirror will stay in a wide 700mm x height 2350mm chamber with 2 ways mirror in front.
                      for safety reason and pi’s hdmi on/off function is not stable, I use a PIR to control TV power directly, the tv will automatically turned on when AC power is in, PIR sets turn on AC 30mins for every trigger.
                      what thing will be inside of chamber:
                      upper:
                      airport express x4
                      stereo amp x4
                      Middle:
                      pi3 x1
                      50" TV x1
                      wireless AC controller for LED lamp with a power supply x1
                      Bottom:
                      10bay NAS x1
                      GbE HUB x2
                      Router x1
                      upper and bottom also have two “AC Infinity AIRPLATE T9, Quiet Cooling Fan System with Thermostat Control” to cooling this chamber.
                      hope soon enough that I can show my magicmirror to you~
                      share with you ~
                      Regards,
                      Jake
                      • iMAGiCI Offline
                        iMAGiC
                        Hi Friends,
                        My new house finally done, thank you all for this cool staff.
                        This magicmiorr box includes many devices in there and also has a fish tank inside box.
                        MM’s display control by PIR and MM’s GPIO controls door lock to avoid children open it and a led power supply to light up TV wall.
                        Due to this system is dynamic shows many things, maybe I can make a clip when I available.
                        Cheers,
                        Jake
                        yawnsY Mykle1M 2 Replies Last reply Reply Quote 6
                        • yawnsY Offline
                          yawns Moderator @iMAGiC
                          @iMAGiC
                          wow mate, that looks very sexy!
                            Mykle1 Project Sponsor Module Developer @iMAGiC
                            @iMAGiC
                            Yeah, that’s hot!
                            • iMAGiCI Offline
                              iMAGiC
                              my mirror
                              Very cool 😼
                              • iMAGiCI Offline
                                iMAGiC
                                lights on
                                lights off
                                Apple music system integrated
                                update my livingroom’s magicmirror Video
                                thanks for watching
                                A 1 Reply Last reply Reply Quote 5
                                  Arthur @iMAGiC
                                  @iMAGiC very cool!!
                                  • MariaHTM Offline
                                    MariaHT @MichMich
                                    @MichMich You’ve inspired Makers all over the world! You’re awesome.
                                    • iMAGiCI Offline
                                      iMAGiC @Arthur
                                      @Arthur thanks
                                      • Z Offline
                                        zhangzuoqiang
                                        @iMAGiC 您好,看到您的作品很震撼,想请教一下您如何DIY像您这样的一面镜子,怎样能和您联系上?我邮箱zhangzuoqiang@aliyun.com,wx:z_zuoqiang,QQ:1939625304,期待您的回信,谢谢。
                                        • K Offline
                                          kclemen
                                          wow, amazing! What screen dit you use? Beautifull house too!
                                          • iMAGiCI Offline
                                            iMAGiC @kclemen
                                            @kclemen
                                            thank you, I use a 42" Infocus monitor and a 22" monitor.
