    Jake's Magic Mirror (Done)
    20 Posts 11 Posters 20.4k Views 11 Watching
    • iMAGiCI Offline
      iMAGiC @MichMich
      @MichMich Yes, it’s Chinese version of your mirror, I like it, thank you very much. :)
      Choice * Judgment * Values
      • iMAGiCI Offline
        iMAGiC @Guest
        @builer Yes, I tried 2 way mirror and even Window Films(for car), still can’t reach what I need. :(
        • bheplerB Offline
          bhepler Module Developer
          I think the issue with your “black mirror” is more an issue with lighting in front of the mirror. Turn the monitor off and put the mirror in a bright area. Preferably with strong daylight. I predict the “black mirror” issue will resolve itself.
          iMAGiCI CatoC 2 Replies Last reply Reply Quote 0
          • iMAGiCI Offline
            iMAGiC @bhepler
            @bhepler thanks for your comment, but I think the problem is not comes from environment.
            I did a comparison table, as you can see, no one can use for vanity as my wife said.
            I may choose #4 for house decoration at end this year. but it is expensive and sensitive parts in Taiwan (you should know, the bad guy use it for “Candid camera” behind glass). And, I don’t know if I use #2 for vanity table my wife will accept…
            • CatoC Offline
              Cato Module Developer @bhepler
              @bhepler I’m afraid it’s probably not the issue. I had the same problem when I replaced a mirror on the bathroom. It was just too dark compared to the one it replaced. The lighting where the same…
              • iMAGiCI Offline
                iMAGiC
                Hi ~
                Time flies, my new house has been started decorating. Just bought 50" TV for wall mount perpetration and double check installation to avoid any problem.
                My Magicmirror will stay in a wide 700mm x height 2350mm chamber with 2 ways mirror in front.
                for safety reason and pi’s hdmi on/off function is not stable, I use a PIR to control TV power directly, the tv will automatically turned on when AC power is in, PIR sets turn on AC 30mins for every trigger.
                what thing will be inside of chamber:
                upper:
                airport express x4
                stereo amp x4
                Middle:
                pi3 x1
                50" TV x1
                wireless AC controller for LED lamp with a power supply x1
                Bottom:
                10bay NAS x1
                GbE HUB x2
                Router x1
                upper and bottom also have two “AC Infinity AIRPLATE T9, Quiet Cooling Fan System with Thermostat Control” to cooling this chamber.
                hope soon enough that I can show my magicmirror to you~
                share with you ~
                Regards,
                Jake
                • iMAGiCI Offline
                  iMAGiC
                  Hi Friends,
                  My new house finally done, thank you all for this cool staff.
                  This magicmiorr box includes many devices in there and also has a fish tank inside box.
                  MM’s display control by PIR and MM’s GPIO controls door lock to avoid children open it and a led power supply to light up TV wall.
                  Due to this system is dynamic shows many things, maybe I can make a clip when I available.
                  Cheers,
                  Jake
                  yawnsY Mykle1M 2 Replies Last reply Reply Quote 6
                  • yawnsY Offline
                    yawns Moderator @iMAGiC
                    @iMAGiC
                    wow mate, that looks very sexy!
                      Mykle1 Project Sponsor Module Developer @iMAGiC
                      @iMAGiC
                      Yeah, that’s hot!
                      • iMAGiCI Offline
                        iMAGiC
                        my mirror
                        Very cool 😼
