    Snilles Magic Mirror Project
    47 Posts 14 Posters 73.3k Views 20 Watching
    • SnilleS Offline
      Snille Module Developer
      @ceddirr I saw your questions about the project… Answers below. :)
      First, I forgot to say thank you for your kind words!
      Question: “Which order is it? At first the IR frame, then the one way mirror, and finally the screen, is it correct?”
      Answer: Correct, from the “front” the IR-Frame is first, placed directly on to the mirror and behind the mirror sits the screen. :)
      Question: “I can see that the custom css of the MMM-Memo is already written in css file from the module’s folder. But, how do you manage to use it, and have this look with your memos? Mine are just white and simple… Thank you =)”
      Answer: Well, I’m actually not doing so much in the CSS file. The only thing I set in the custom.css is the size of the Memo. The rest is “built in”.
      This is the CSS part (in my custom.css file):
      /* MMM-Memo -----------------------------------------*/
      .MMM-Memo .small {
      	font-family: "Roboto Condensed", sans-serif;
      .note {
        width: 500px;
        height: 200px;
      And this is in my config.js:
      	module: "MMM-Memo",
      	position: "upper_third",
      	classes: "default everyone",
      		memoTitle: "Flyginformation",
      		memoDisplayIfEmpty: false,
      		memoRotation: -4,
      		format: "YYYY-MM-DD - HH:mm",
      		memoWidth: 500,
      		memoDisplayHeader: true,
      		memoDisplayDuration: true,
      		memoDisplayId: true,
      		memoColorBackground: "LightGoldenrod",
      		memoDisplayNotification: true,
      You can see all the options for the config on the MMM-Memo’s git.
      There are lot’s and lot’s of options for colors and themes. :)
      • G Offline
        grillchips
        I’m about to pull the trigger on the IR touch frame but not really sure how thick it is. The description says it’s about 8.7mm, do you remember if that is somewhat correct for your panel? I don’t always trust Chinese specifications. :D
        Feels like the whole mirror frame needs to be quite thick to keep everything in place. The screen I have with the boards on the back is about 5.5cm already, adding the touch frame and mirror glas to that will make it REALLY thick and large…
        I know there’s slimmer screens out there but ~5-7cm depth might be what most of us have?
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS Offline
          Snille Module Developer @grillchips
          @grillchips Yes, it’s correct. I did not measure it exactly, but the description is correct. Give or take 0,5 mm I would say.
          • G Offline
            grillchips
            Sweet, thanks!
            Talked to one of the sellers on Aliexpress and it seems like a 21.5" touch screen needs the glass while larger ones only needs the frame. That shouldn’t make any noticeable difference in performance/feel/look, right?
            • SnilleS Offline
              @grillchips Hmm… I don’t see why they would need the glass? It’s basically an array of IR leds on two sides and another array of IR receivers on the opposite two sides. I’m using a 32" frame and that worked in mid air when I tested. :)
              • G Offline
                grillchips
                Great to hear how it works! First time with a touch frame/panel for me so I’m a bit nervous.
                This is what they sent me:
                “Thanks for your inquiry. Yes, 27 inch and above size , we can send without glass. 21.5inch and 24inch, We need to send glass.”
                Really doesn’t tell why but I guess it doesn’t matter then… :D
                • SnilleS Offline
                  @grillchips I don’t get the answer you got… Maybe they want to sell you a glass? :) Anyway, here is the store I bought mine from: https://www.aliexpress.com/store/922495?spm=a2g0s.9042311.0.0.9vCMC5
                  I think they have “all” the sizes. :)
                  • G Offline
                    grillchips
                    Yeah I have no idea what they’re talking about first. After a few further questions they linked me to the correct size but still with glass. Seems like smaller sizes need it while larger doesn’t…?
                    I also realized that the touch screen prices has gone up quite a lot lately, dammit. 1300SEK for the one I need. Oh well.
                    “Ingen minns en fegis” :)
                    • K Offline
                      korevaartje
                      Hi Snille,
                      i am currently trying to copy you setup but at the moment i am stuck.
                      somehow i cant get the .png’s to show up.
                      i have created a folder within the file structure of magicmirror called backgrounds . Here i save all images needed , placed my own icons and adressed correctly, i think.
                      are your png’s stored localy on the pi or remotly on a server?
                      is my way of adressing correct?
                      kind regards,
                      Jay
                      SnilleS ceddirrC 2 Replies Last reply Reply Quote 0
                      • SnilleS Offline
                        Snille Module Developer @korevaartje
                        Hi @korevaartje, If I remember correctly you need to use a URL to the picture. You cant use a “local” path. I’m currently loading all the pictures from an “internal” web server (that I use for lot’s of other stuff as well). And that made it easy to switch the pictures without having to change anything on the actual MM.
                        I hope that clarify’s it. :)
                        • ceddirrC Offline
                          ceddirr @korevaartje
                          @korevaartje ,
                          Personally I put my pictures on the css directory, and here is how I load them:
                          				"Cedric": {
                          					img: "/css/cedric.jpg",
                          					width: 60,
                          					height: 60
                          And every day I do a rsync save of the css directory, and the conf directory as well to my NAS server.
                          • SnilleS Offline
                            Added a video (two years later): https://youtu.be/2Hi9IDfrqPQ
                            The Mirror is used daily and I have upgraded from a RPi 3 to a NUC instead to get more CPU-Power to play with. :)
                            • cowboysdudeC Offline
                              Looks AWESOME! Great job!
                                DennisFaucher
                                Wow. Impressive. Thank you for providing so much detail in your post.
                                • SnilleS Snille referenced this topic on
                                • SnilleS Offline
                                  Snille Module Developer @Snille
                                  Updated almost all information about this project. My Mirror has been the “information HUB” (together with HA) of the family for many years now!
                                  Even the rest of the family(!) thinks it’s good!
                                  If you want to know more, ask away! :)
                                    justbob
                                    Very cool, I think I will borrow some of your ideas! :)
                                    SnilleS 1 Reply Last reply Reply Quote 1
                                    • SnilleS Offline
                                      Snille Module Developer @justbob
                                      @justbob Thank you! Great to hear, please do! Share your ideas when you are done. It’s always fun to see what others do. :)
                                      • G Offline
                                        gefy @Snille
                                        I am running both Magic Mirror and Home Assistant. My dream is to have a “button” on the screen so I can toggle between the two aplications. Is this just a dream or could it be done somehow?
                                          bolinoid
                                          Brilliant!
                                          • N Offline
                                            nowayto @Snille
                                            @Snille I’ve logged in just to say… you are incredible!
                                            That’s a very very great example of what a MM can do.
                                            It’s just up to our minds!
                                            Incredible, really.
                                            I’m really interested about the IR touch system, I think I’m not enough professional to set it up but it’ really interesting.
                                            I hope to have enough time in the future to learn/make one of this.
                                            Thank you so much to have explain your project so well at the community
                                            • 2 / 3
